Background:
280,000 miles
New fuel pump (4th in lifetime), spider,dist., cap, rotor, wires, plugs, timing chain, oil pump, coil, etc. done 10k miles ago.
Van had been running fantastic, but now hesitates at cruising speed at light throttle. Could this be once again ANOTHER fuel pump??? Once I get a chance I'll throw a pressure gauge on it and drive it around and try and replicate the problem to see if the pressure drops. Does anyone make a pressure gauge extension hose??
If this is the FP, it will be the van's 5th! I don't replace things lightly, and every pump was verified as a failure. Stupid van
