Trouble Starting - 2002 4.3L Safari
Postby oneilldm [OP] » March 11th 2013, 10:44pm
My van use to start up on the first twist of the key. Now it can take two or three tries.
If I've been driving and I stop and run into the store... it seems to start normally when I come back out. It's usually only after the car has been sitting a while. Although... sometime when I come to a red light that I know is going to make me sit there for a couple of minutes... I'll cut the engine off. It will start back up ok but when I go to accelerate it starts to bog out.
Other than the fuel pump and filter... is there anything else that people have found that causes this problem with this engine?
Thanks
2002 GMC Safari SLE 2WD
oneilldm
Years of Membership: oneilldm has been a member for 7 full yearsoneilldm has been a member for 7 full yearsoneilldm has been a member for 7 full yearsoneilldm has been a member for 7 full yearsoneilldm has been a member for 7 full yearsoneilldm has been a member for 7 full yearsoneilldm has been a member for 7 full years
Topics: 12
Van Model Year: 2002
Extra Info: SLE
  • 4.3L V6 Hesitant To Start When hot - Fuel Pressure Test
    by K-TRON » November 5th 2020, 4:42am in Engines
    November 17th 2020, 3:05am
  • starting issues, backfire. 2000 Astro 4.3
    by popehentai » December 13th 2020, 2:47pm in Engines
    Last post by Astrojohn View the latest post
    February 3rd 2021, 6:06pm
    49
    February 27th 2021, 1:04pm
Re: Trouble Starting - 2002 4.3L Safari
Postby oneilldm [OP] » March 31st 2013, 12:21am
Update - Today my Check Engine Light came on. I'm getting p0171 & p0174 codes (... too lean).
Any suggestions where to start? Common vacuum leak...?
oneilldm
Topics: 12
Extra Info: SLE
Postby chevymaher » March 31st 2013, 12:22am
Fuel pressure check.
Postby Corsemoto » March 31st 2013, 1:38am
I second that emotion
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby 2002Safari » April 1st 2013, 4:44am
Check your fuel filter, as it may be causing low fuel pressure.
Take a look at http://repairpal.com/OBD-II-Code-P0171-and-P0174
2002Safari
Years of Membership: 2002Safari has been a member for 13 full years2002Safari has been a member for 13 full years2002Safari has been a member for 13 full years2002Safari has been a member for 13 full years2002Safari has been a member for 13 full years2002Safari has been a member for 13 full years2002Safari has been a member for 13 full years2002Safari has been a member for 13 full years2002Safari has been a member for 13 full years2002Safari has been a member for 13 full years2002Safari has been a member for 13 full years2002Safari has been a member for 13 full years2002Safari has been a member for 13 full years
Topics: 10
Extra Info: SLT AWD
It is currently February 27th 2021, 1:04pm
Ken2.7
Date: Feb 24 '21
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Date: Feb 23 '21
Time: 8:41pm
Attached by: WinnieVan
WinnieVan
Date: Feb 23 '21
Time: 8:07am
Ken2.7
Date: Feb 22 '21
Time: 11:43pm
Users browsing this forum: No registered users and 24 guests
cron
