(I'm sure this has had to have been discussed before, but I searched and didn't find it. So formive me in advance if it has already been beat to death before.)Changed oil and filter yesterday with a 5 qt jug of pennzoil high mileage 10w30. Let the oil drain for at least 30 minutes after removing the drain plug and fileter. I used the larger filter for the s10 and filled the filter before installing it. Thinking I had read that the capacity was something like 4.7 qts, I left about what I thought was about 1/2 to 3/4 qt in the jug. Started, let run til up to operating temp, let sit for 10-15 minutes for everything to drain down. checked oil and it was right about at the bottom of the cross hatched area, so I added what I guessed to be about 1/2 qt and left about 1/2 pint to pint in the jug. drove it just a wee bit, let sir overnight, started this morning let come up to op temp, turned off let sit 5-10, checked again, and it was about 3/4 the way up the cross hatched area, so I put in the rest, and I watched it couldn't have been more than a pint, and now it reads about 1/4-3/8 inch above the crosshatched area-about where the red line is on this photo. I thought it would be safe to put the rest in anyway since I had spilled a wee bit on the filter and the larger filter's capacity.
Is this too much? Seems like I recall it being about there the last time I took it to a retail oil change place, figured they put in a full 5 qts, although I didn't notice it right away. When I did notice it, I opened the drain plug and let a bit out.
I didn't see any bubble on the dipstick after letting it warm up after the last oil was added.
I really don't want to do that now since I just put in a new magnetic plug with a new gasket.
1) I know it has had a full 5 qts minus the small amount I spilled when filling the filter. Is this too much enough so to worry about and
2) Can you put a tube down the oil filler tube and siphon some out? If so, what diameter-since only a small amount need to come out, would 3/8" work?
(I know I have seen gadjets to suck oil out for changing it, but wonder if there is a certain size restriction down there somewhere.)
3) I haven't driven it since adding the last little bit. Is it safe to drive a couple of miles to get a hose?
TIA
Charles
