by Shaynelle [OP] » January 3rd 2009, 2:46am
by astro355 » January 3rd 2009, 6:34am
by Big_kid » January 3rd 2009, 3:09pm
by Leeann_93 » January 3rd 2009, 11:40pm
by astro355 » January 4th 2009, 12:42am
Leeann_93 wrote:It also might not be a block heater issue - how old is your battery? It might not have enough CCA any more, if it ever did, for Winnipeg.
by allwhite1100 » January 4th 2009, 12:56am
by Shaynelle [OP] » January 4th 2009, 3:23am
by maximus7001 » January 4th 2009, 1:20pm
by lesterl » January 5th 2009, 2:48am
by Shaynelle [OP] » November 18th 2010, 4:12pm
by Shaynelle [OP] » December 4th 2011, 4:01pm
by strangerock » December 4th 2011, 5:35pm
by Shaynelle [OP] » December 6th 2011, 4:10pm
by Phantom » December 6th 2011, 4:45pm
Shaynelle wrote:Thanks, all checked and all good. We had a guy come by last night and he thinks it may be the distributor belt. Sounds expensive to replace though... engine has to come out?
by RECox286 » December 6th 2011, 11:04pm
by Jasen » December 6th 2011, 11:26pm
by Shaynelle [OP] » December 7th 2011, 4:17am
Phantom wrote:Shaynelle wrote:Thanks, all checked and all good. We had a guy come by last night and he thinks it may be the distributor belt. Sounds expensive to replace though... engine has to come out?
A distributor belt? The distributor has no belts ,,,,the only belt on the engine is the serpentine belt which is only one belt that drives all accessories , a/c , alternator water pump fan blade ..it can be replaced in a few minutes , no need to remove engine
your starter may be old and drawing more juice which is straining the electrical system , and easy replace
basics test ,, check for good spark , if you have good spark , then it be fuel related , could be a blown fuse , sorry to hear pf people doing you wrong
your problem does not sound serious , why would engine need to come out , just because it won't start ,,,some missing info , no reason to remove engine unless to want to rebuild it or replace it
The only thing that can be compared to this is the possibility that the timing chain has jumped a couple teeth throwing the timing off , which can make it harder to start , it can be compensated for by turning the dist a little to adjust timing to make it run , but you would have likely noticed performance problems while driving around in the van , and it can be replaced without removing the engine , seems that your mechanic wants to pad the bill by doing things that are not needed
kinda sounds like you gonna get ripped off ,,, can you explain in more detail?
Jasen wrote:I'm pretty sure the distributor belt is hooked to the distributor pulley and in turn the belts runs to the squirrel wheel. Check that your squirrel is not dead or been replaced with a mouse. A mouse does not have long enough legs to spin your distribute at proper speeds for freeway driving.
In other words. I'm with those guys ^
RECox286 wrote:I wonder if your "guy" has any land for sale in Fla ? After he does your Distributor Belt, send him over here.
Geez ! ( Lord give these people strength. Dunno, maybe it's a Canada thing ? )
Bob
by Leeann_93 » December 7th 2011, 4:22am
by Phantom » December 7th 2011, 3:02pm
Shaynelle wrote:Sorry, that info was second hand via my husband. I have never heard of a distributor belt before either, but I do know enough to know that I don't know it all... I just confirmed with hubby if he was told "distributor belt" and he shrugged and said "some kind of belt" and I also confirmed if the guy said the engine may have to come out and hubby said "thats what he (meaning mechanic) said".
I doubt this guy is going to rip us off as they work together. This of course doesn't guarantee he won't rip us off, but I highly doubt it. I imagine it's more of a miscommunication thing. He's going to call us back probably this evening or tomorrow evening once he's had a chance to do some diagnostics and figure out for certain what it is (keeping in mind the guy stopped by after work to see if he could get the van started, and he stressed his initial thoughts on what it could be may not be the case), so once I know more I can post.
by RECox286 » December 7th 2011, 3:48pm
It is currently February 26th 2021, 10:54am
Engines Forum |
Engine Repairs, Modifications, Diagnostics, Tuning, Upgrading, Questions. <a href="https://ad.doubleclick.net/ddm/trackclk/N8334.275400VERTICALSCOPEINC./B20209277.204028354;dc_trk_aid=407011718;dc_trk_cid=94070067;dc_lat=;dc_rdid=;tag_for_child_directed_treatment="target="_blank"><img src="https://tpc.googlesyndication.com/pagead/imgad?id=CICAgKDrrqWwMRCAARgcKAEyCN4sAjjtai4k" border="0" align="right"> <IMG SRC="https://ad.doubleclick.net/ddm/trackimp/N8334.275400VERTICALSCOPEINC./B20209277.204028354;dc_trk_aid=407011718;dc_trk_cid=94070067;ord=;dc_lat=;dc_rdid=;tag_for_child_directed_treatment=?" BORDER="0" HEIGHT="1" WIDTH="1" ALT="Advertisement"> |
Moderator: chevy57bert |
Previous topic Next topic |
Sponsors |
