Once the engine is a couple miles after fully warm (per the temp gauge), it stops misfiring and runs well for 190M.
I'm in Minnesota, its still kind of cold here too 30 to 40F (April 23). I will know what warm weather does to this in a couple weeks I suppose, (70F soon?)
I'm trying to figure out if its a fuel problem, ignition, sensor or CAT.
Its been very damp here too, why I was thinking this was an ignition dampness problem that goes away once the engine compartment dries out from engine heat. But today it was 40 and dry and still misfired until the engine was warm.
It misses at all engine speeds when engine is cool. Feels like multiple cylinders effected. Once warm it runs fine at all speeds, or at least the misfiring is not noticeable.
I installed new plugs, wires and cap about 20m ago, just for the he// of it. Ran great. MAS and EGR are about 30m old.
Aftermarket Magnaflow CAT (cheap weld in) was installed and tripped the PO420 code after 8K on it. The PO420 code doesn't seem to effect the driveability, the PO300 trips after I feel the engine misfiring multiple times. I have read the codes and cancelled them to figure out when they come on many, many times now. I realize I need an OEM cat, but I don't think that is my main drivability issue causing the cold misfiring.
I had a shop change the manifold valley gaskets 4 months ago, coolant was leaking externally drivers side front of valley. Van drove great after that until a month ago. With 2 vehicles, I dont drive this much, trying to find the problem.
So, I'll see how it drives tomorrow morning (30 and dry) vs tomorrow afternoon (40 and rain).
I have not pulled the doghouse to inspect anything like the dist/or plugs wires yet (or the water bottle spray test). Hate the thought of changing plugs since I did that 20m ago.
If this was a fuel problem, it wouldn't matter cold engine or warm right? Again, Its only is noticeable cold.
Any ideas or questions to help figure this out?
thanks in advance
