by cell315 [OP] » January 20th 2009, 5:38am
by Matrixx » January 20th 2009, 7:13am
by astro355 » January 20th 2009, 10:38am
by Matrixx » January 20th 2009, 11:01am
by astro355 » January 23rd 2009, 5:23am
by cell315 [OP] » January 24th 2009, 1:53am
Matrixx wrote:Hi cell315
The pressure drop is to much over that time period cell315, 2 pounds in 10 minutes (or close to that) is the given specs. for pressure requirements. I don't "think" that is your problem though. If you have a heat gun and you know it starts every time when it's warm out and heat related, maybe hit the Temp Sensor (next to the thermostat housing) on the front of the motor as well as the EGR valve (front Intake by thermostat housing), Fuse Block, and Computer. If you still don't get any results, then hit the Crank Shaft Position Sensor located on the lower part of the crank shaft pulley on the passenger side on the front of the motor. You get access to it under the front of the vehicle. Maybe even start hitting plug-ins leading to the motor from the computer.
If everything with the heat gun fails, then you will need to start pulling wires off to make sure your getting spark from the coil to the cap and then from the cap to the spark plugs to start with. This is not my normal recommendations, but if it's heat related and you have a heat gun I'm sure you will at least find the area where to start looking anyways. The process of elimination is important here. Hope this helps, please keep us updated, Thanks.
by cell315 [OP] » January 24th 2009, 1:56am
astro355 wrote:Do you have any access to a decent scan tool?
Two things I would be curious about are if the injectors are firing and if there is a signal coming from the crank position sensor.
by cell315 [OP] » January 24th 2009, 2:07am
Just another suggestion as well with the heat gun, is to hit the ignition switch with it and see what happens. Don't over heat it though. If it's been sitting for a long period of time, then dampness and corrosion could have entered into it as well. Just a thought. Astro355 has some good suggestions as well. Mine are a bit unorthodox for this particular post, but I feel it will find the problem (or problem area) quicker as you say it is heat related (worth a try anyways). Please keep us updated, Thanks.
by cell315 [OP] » January 24th 2009, 2:14am
astro355 wrote:I have given this a little more thought. You have tested for fuel pressure but you don't actually know if the injectors are fired. What you could do to test it is get some propane. While the van is being turned over, put some propane down the intake. If it starts, you would then know that you are not getting any fuel into the cylinders. I would used a propane torch or anything else that has a valve on it so you can control the flow of propane.
by Matrixx » January 24th 2009, 2:51am
by astro355 » January 24th 2009, 3:15am
cell315 wrote:
Hi astro355,
No, I don't have anything except a bare-bones code reader. Is that what you meant?
Thanks for your input.
by cell315 [OP] » February 16th 2009, 9:23pm
Thanks for the update. Can you be more specific to the location of that 5 wire plug-in (and the color of the wires) you say you heated then fired right up? I can look it up and let you what it is exactly. I was raised on points and carbs as well, this new system can be overwhelming at times.
Once you understand the method on how this electronic stuff is set up, it isn't hard to figure out what goes where, their is an order to it. Just takes time to understand it. If you could let me know on the question I asked that would be great, then I can give you an answer to it, Thanks.
by astro355 » February 16th 2009, 10:05pm
by cell315 [OP] » February 17th 2009, 5:47am
astro355 wrote:I would have to tell you that the temp sensor you unplugged is at fault. If its sending a faulty signal back to the ecm, the ecm may think that its a lot colder than it really is and be running way too rich.
by astro355 » February 17th 2009, 1:55pm
by Matrixx » February 17th 2009, 3:16pm
It is currently March 1st 2021, 8:27am
Engines Forum |
Engine Repairs, Modifications, Diagnostics, Tuning, Upgrading, Questions. <a href="https://ad.doubleclick.net/ddm/trackclk/N8334.275400VERTICALSCOPEINC./B20209277.204028354;dc_trk_aid=407011718;dc_trk_cid=94070067;dc_lat=;dc_rdid=;tag_for_child_directed_treatment="target="_blank"><img src="https://tpc.googlesyndication.com/pagead/imgad?id=CICAgKDrrqWwMRCAARgcKAEyCN4sAjjtai4k" border="0" align="right"> <IMG SRC="https://ad.doubleclick.net/ddm/trackimp/N8334.275400VERTICALSCOPEINC./B20209277.204028354;dc_trk_aid=407011718;dc_trk_cid=94070067;ord=;dc_lat=;dc_rdid=;tag_for_child_directed_treatment=?" BORDER="0" HEIGHT="1" WIDTH="1" ALT="Advertisement"> |
Moderator: chevy57bert |
Previous topic Next topic |
Sponsors |
Users browsing this forum: Google [Bot] and 13 guests
