no start
no start
Postby ALaneef [OP] » June 18th 2013, 8:32pm
I have this problem after I replace the cap and the rotor
https://www.youtube.com/watch?v=wyEwBka ... ata_player
ALaneef
Years of Membership: ALaneef has been a member for 9 full yearsALaneef has been a member for 9 full yearsALaneef has been a member for 9 full yearsALaneef has been a member for 9 full yearsALaneef has been a member for 9 full yearsALaneef has been a member for 9 full yearsALaneef has been a member for 9 full yearsALaneef has been a member for 9 full yearsALaneef has been a member for 9 full years
Topics: 10
  • 94 Astro no start after fuel pump install
    by grimbeardsly » June 7th 2020, 1:16pm in Engines
    Last post by grimbeardsly View the latest post
    June 21st 2020, 2:18am
  • No start after new fuel pump
    by Mberry0614 » June 19th 2020, 5:21pm in Engines
    June 24th 2020, 10:29pm
    9
    38
    October 29th 2020, 3:11am
Re: no start
Postby chevymaher » June 19th 2013, 12:02am
All the wires are one off. They are retarding the timing.
In the pic all wires should move to the next terminal. In a counterclockwise direction.
firing order.jpg (12.86 KiB) Viewed 1132 times
Re: no start
Postby Y2KSAFARI » June 19th 2013, 1:21am
Hi, it looked to me like there was visible stray arcing (blue flash) on two of the attempts to start the engine.
The more noticeable one appears about 17 seconds into the video.. the high voltage appeared to be jumping to the the wiring bundle? to the right of the distributor in the video.
For the spark to jump to a nearby ground, there may be a problem between that point and the spark plug gap.. the wire may have a bad/broken spot there, the spark plug gap may be set too wide, or the spark plug end of the wire might not be fully seated with a good connection between the cable terminal and the spark plug terminal (another gap too large).
As chevymaher suggested, the timing seems to be wrong, there don't appear to be any plugs firing on the compression stroke.
Let us know what you find to correct the problem.
ALaneef wrote:I have this problem after I replace the cap and the rotor
Y2KSAFARI
Years of Membership: Y2KSAFARI has been a member for 7 full yearsY2KSAFARI has been a member for 7 full yearsY2KSAFARI has been a member for 7 full yearsY2KSAFARI has been a member for 7 full yearsY2KSAFARI has been a member for 7 full yearsY2KSAFARI has been a member for 7 full yearsY2KSAFARI has been a member for 7 full years
Topics: 5
Extra Info: Passenger AWD SLE
It is currently October 29th 2020, 3:11am
kade225
Time: 11:27pm
djpigs
Date: Oct 27 '20
Time: 10:01pm
AstroTan
Date: Oct 21 '20
Time: 8:02pm
Attached by: Sparkydog
Sparkydog
Comments: 13
Date: Oct 20 '20
Time: 4:01pm
Sparkydog
Comments: 0
Date: Oct 13 '20
Time: 8:49pm
