98 Safari Starter wiring
Postby U2gether [OP] » March 18th 2009, 3:36pm
'98 Safari V6 AWD. had the starter removed by someone. Sat for 4 months and while idle a rodent chewed wiring harness in the area of battery. I've put in a new starter and repaired the wiring harness (matched up the colors etc.)
The starter spins but seems like the electrics are not getting power, coil, ignition - somewhere. Just wonder if I wired the starter wrong. Anyone have a picture of a wired starter - or maybe can give a novice a description of what goes where.
Thanks
U2gether
Years of Membership: U2gether has been a member for 11 full yearsU2gether has been a member for 11 full yearsU2gether has been a member for 11 full yearsU2gether has been a member for 11 full yearsU2gether has been a member for 11 full yearsU2gether has been a member for 11 full yearsU2gether has been a member for 11 full yearsU2gether has been a member for 11 full yearsU2gether has been a member for 11 full yearsU2gether has been a member for 11 full yearsU2gether has been a member for 11 full years
  • 4.3 Starter Bolts
    by Slime » November 6th 2020, 6:31pm in Engines
    December 1st 2020, 1:43am
  • 2000 GMC Safari turns over fires intermittent no start
    by Isuzuguru » September 21st 2020, 5:20am in Engines
    Last post by Isuzuguru View the latest post
    September 29th 2020, 1:16am
    33
    February 25th 2021, 12:22pm
Re: 98 Safari Starter wiring
Postby Matrixx » March 18th 2009, 4:29pm
Hi U2gether
Welcome to the Forum
Could you be more specific on what you mean by "the starter spins". Does it turn the motor over when it spins? Thanks.:)
Matrixx
Postby U2gether [OP] » March 18th 2009, 5:04pm
Hello,
Thanks for the reply - the starter turns the motor just fine - sounds like it wants to start by is not getting fire. I can smell gas.
U2gether
Postby Matrixx » March 18th 2009, 5:27pm
Hi U2gether
When something like this happens U2, the basics need to be applied (Fuel-Air-Spark) to find the area that is causing this no start condition. I would pull the dog house off and check for spark at the distributor first (coil side then spark plug side).
Please keep us updated thanks.:)
Matrixx
Postby U2gether [OP] » March 18th 2009, 6:32pm
Thanks again, My concern is that I wired the starter wrong, that is why I was asking for help with the wires and maybe a picture if someone had one. Anyone? Thanks in advance
U2gether
Postby m3k1 » March 19th 2009, 4:18am
Matrixx wrote:Hi U2gether
Matrixx is correct.
Chances are it would try to fire up while the engine was cranking but die after you let off the key. You can check for spark pretty easy, then maybe ether pull a plug to see if its wet it fuel, or try spraying some fuel into the intake being careful not to spill it on the engine or getting to much in the intake. It should not take much fuel to at least see if it a fuel problem. I would check the spark first though (Not as messy).
I have a 98 AWD but it does not have the engine or sub-frame installed ATM. :2:
98 AWD Astro Passenger Van
98 RWD GMC Safari Passenger Van
2000 RWD GMC Safari Utility Van
m3k1
Years of Membership: m3k1 has been a member for 12 full yearsm3k1 has been a member for 12 full yearsm3k1 has been a member for 12 full yearsm3k1 has been a member for 12 full yearsm3k1 has been a member for 12 full yearsm3k1 has been a member for 12 full yearsm3k1 has been a member for 12 full yearsm3k1 has been a member for 12 full yearsm3k1 has been a member for 12 full yearsm3k1 has been a member for 12 full yearsm3k1 has been a member for 12 full yearsm3k1 has been a member for 12 full years
Alias (AKA): mechone
It is currently February 25th 2021, 12:22pm
Ken2.7
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Date: Feb 23 '21
Time: 8:41pm
Attached by: WinnieVan
WinnieVan
Date: Feb 23 '21
Time: 8:07am
Ken2.7
Date: Feb 22 '21
Time: 11:43pm
cron
