Help! HVAC Heater Bypass Valve Broken
Postby Pegman [OP] » August 19th 2013, 1:19am
Gents,
I'm towing in western Canada. Today I overheated in a small town. I've located a coolant leak at the HVAC bypass valve the valve appears to have cracked at an upper male stem and the top of the valve has separated from the bottom. I'll try to move 600 yards to a repair shop tomorrow morning.
Is this a common failure? Am I correct to assume the entire valve is supposed to be one piece? Is it possible that there is another problem that caused increased coolant system pressure?
Appreciate any help.
http://www.partsmonkey.com/en/catalogue/2004/chevrolet/astro-van/v6-262ci-4.3l-f-i-vin-x/heater-core
Pegman
Years of Membership: Pegman has been a member for 9 full yearsPegman has been a member for 9 full yearsPegman has been a member for 9 full yearsPegman has been a member for 9 full yearsPegman has been a member for 9 full yearsPegman has been a member for 9 full yearsPegman has been a member for 9 full yearsPegman has been a member for 9 full yearsPegman has been a member for 9 full years
Alias (AKA): Pegman
Extra Info: RWD
  • Vapor canister purge valve solenoid
    by N6KB » June 6th 2020, 9:21pm in Engines
    June 6th 2020, 9:58pm
  • 04 EGR valve location?
    by offctr » August 29th 2020, 6:00pm in Engines
    September 2nd 2020, 9:45pm
    7
    17
    November 27th 2020, 6:13am
Re: Help! HVAC Heater Bypass Valve Broken
Postby chevymaher » August 19th 2013, 1:40am
Yea it used to be one piece and they fall apart. Nothing is wrong with your van.
There are many on the site who bypass them.
Postby Pegman [OP] » August 19th 2013, 1:52am
Seems like 6 or 7 lines coming from that valve. Can't imagine how I could bypass now. Hopefully tomorrows mechanic can do something. Thx
Pegman
Alias (AKA): Pegman
Extra Info: RWD
Postby redfury » August 19th 2013, 10:47pm
Bypass by removing the two lines coming from the engine, don't worry about the others. you've got two for the front, two for the back, and the two that come from the engine to supply the system and return it to the engine.
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Extra Info: LT 5.7L 4wd
Postby godmachine81 » September 5th 2013, 2:21am
The valve is only there to keep the heater core from getting hot when you don't run the heater. Most of the heater cores have a flap over them though so when the heat is not on the flap is closed. This makes the control valve just something that causes more trouble than it is worth to me and most people on the forum. If you bypass it as chevymaher mentioned, you most likely aren't going to notice any difference in your heating/cooling situation (unless the flap on the heater core isn't there or doesn't work)
To do so just remove the plastic valve assembly altogether, and place the two lines that come from the engine (one on the passenger side intake, the other on the water pump) directly to the two hose fittings on the firewall. If you have the rear heat you should already have two "T's" before where the valve was. The T's should be going to your rear heater core unit.
You just have a return line and sending line to each heater core. It doesn't matter which way you run the heater core hoses it will work as long as the coolant goes in (sending) and comes back out (returning). Just make sure that the way you route the hoses provides full circulation for your coolant and you will be good to go. Hope that makes sense :)
Proud owner of a 1995 Chevy Astro Mark III
godmachine81
Years of Membership: godmachine81 has been a member for 8 full yearsgodmachine81 has been a member for 8 full yearsgodmachine81 has been a member for 8 full yearsgodmachine81 has been a member for 8 full yearsgodmachine81 has been a member for 8 full yearsgodmachine81 has been a member for 8 full yearsgodmachine81 has been a member for 8 full yearsgodmachine81 has been a member for 8 full years
Topics: 7
Images: 18
Extra Info: Mark III 2WD 4.3L V6
It is currently November 27th 2020, 6:13am
djpigs
Comments: 40
Time: 11:23pm
Time: 12:43am
Attached by: Slime
Slime
Date: Nov 24 '20
Time: 11:11pm
K-TRON
Comments: 23
Date: Nov 16 '20
Time: 1:07am
Attached by: Devonian
Devonian
Date: Nov 13 '20
Time: 2:19am
Users browsing this forum: Google [Bot], Yandex [Bot] and 14 guests
