first post not but the last.
I recently bought a 94 GMC Safari van from a private seller. it has the vortec V6 4.3L in it and a automatic transmission.
My questions are and I have searched this site before for answers but I need someones opinion.
I live in Florida and right now its hot just like everywhere else.
I bought this van with 122,xxx miles on it. it had been sitting for about 2 years before I bought it with a bad transmission. I had a new tranny installed as well as an egr valve,airtex fuel pump and sending unit. I drove it for about 2 months and it started becomming hotter and hotter as the summer days went by. I can drive this van about 30 miles and not have any problem but if i drive for more than an hour it will start to hesitate and buck and then after a series of bucks it will stall out. now when I pull over I can slip it in neutral and (with the key on) try to recrank the engine. It will not start. however if i turn the key off and crank the engine it will fire right up like nothing is wrong with it. it has always cranked and started on the first turn of the key. tthen I can drive for 3-5 minutes and it will buck and hesitate agian and stall out with the same results as i mentioned.
I have checked for spark,it has good crisp blue spark
has a new fuel pump in it although it is not a delphi or ac delco pump.
it has all the ovious things replaced, spark plugs,wires,cap,button,fuel filter,and ignition module
distributer gear is good
I have not replaced the coil,since I though if it was bad it would do it all the time.
I have not checked fuel pressures since I dont have a gauge, but Im working on that.
the plug at the fuel pump and the fuel pump ground at the frame look good.
Im at witts end here, im on a very limited budget, 2 kids and work public service for the state of florida.
I cant troubleshoot by changing parts. I am mechanically inclined so if you tell me somthing dont think i wont understand it. any info on what else to look at would greatly help. I have read that these vans are fuel pump brand bias'ed should i start checking fuel pressures or should I start checking the coil?
thanks, Ranger
