Seafoam - Safe to use on Astro
Postby woodhaven22 [OP] » May 22nd 2009, 12:25pm
Good-day,
I'm having problems and was posted to use Seafoam, which might correct the problem. I did some research and some foks say not to use it.
Has anyone used seafoam on their Van
We have a Astro AWD 2001 4.3L.
Another question -> do we use the hose from the PCV or Booster Brake? People say to use the booster brake hose for a better application.
Thanks for any help with this
woodhaven22
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: woodhaven22 has been a member for 12 full yearswoodhaven22 has been a member for 12 full yearswoodhaven22 has been a member for 12 full yearswoodhaven22 has been a member for 12 full yearswoodhaven22 has been a member for 12 full yearswoodhaven22 has been a member for 12 full yearswoodhaven22 has been a member for 12 full yearswoodhaven22 has been a member for 12 full yearswoodhaven22 has been a member for 12 full yearswoodhaven22 has been a member for 12 full yearswoodhaven22 has been a member for 12 full yearswoodhaven22 has been a member for 12 full years
Topics: 34
  • 2003 Astro seems to be running fine except
    by markmitch » October 18th 2020, 3:34pm in Engines
    Last post by dcsleeperdcsleeper is online! View the latest post
    October 19th 2020, 10:08pm
  • 2000 Chevy Astro No Fuel Pressure
    by Disarobbry » November 10th 2020, 5:25pm in Engines
    February 28th 2021, 2:12am
    9
    50
    April 11th 2021, 10:31am
Re: Seafoam - Safe to use on Astro
Postby Gary » May 22nd 2009, 12:45pm
I think you will find the answer to this question to vary as much as the question which do you like the most a RWD vs a AWD.For me,the question is more a mater of application.It depends on what issue your trying to resolve and the van your using it for.I am not big on a fix in a gar.To me it is a temporary band-aid to a repair you end up doing anyways and in some cases removes a build-up that is taking up the space of worn parts creating more problems than it solves and releases that sludge to be circulate threw-out the rest of the engine during the cleaning being done. :2:
Gary
Dearly Departed
Firing on 4 Cylinders (L3)
Topics: 136
Extra Info: high top
Postby ihatemybike » May 22nd 2009, 1:44pm
I have used SeaFoam in the intake to cure the cylinder misfire from sticky poppets and had great results. I don't use it as a regular gasoline additive though.
Aaron
Prev Astros:99,97,00,94,87,86
ihatemybike
Firing on 6 Cylinders (L2)
Topics: 68
Postby Leeann_93 » May 22nd 2009, 3:33pm
^ same here. Cleaned up sticky poppets and cleaned out a lot of carbon - I think I stunk and smoked up the neighborhood for a mile around...the Bravada ran a TON better after, too (same engine as in my Astro).
Postby tefuller1 » May 22nd 2009, 3:41pm
I have had the same results. I smoked the whole neighborhood but i ran like a champ. I have done this on all my vehicle with great results. I also use it in my mowers, snowblowers, and chainsaws.
2001 Astro LT AWD 152,000 miles.
tefuller1
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: tefuller1 has been a member for 12 full yearstefuller1 has been a member for 12 full yearstefuller1 has been a member for 12 full yearstefuller1 has been a member for 12 full yearstefuller1 has been a member for 12 full yearstefuller1 has been a member for 12 full yearstefuller1 has been a member for 12 full yearstefuller1 has been a member for 12 full yearstefuller1 has been a member for 12 full yearstefuller1 has been a member for 12 full yearstefuller1 has been a member for 12 full yearstefuller1 has been a member for 12 full years
Postby Mr_Bowtie » May 22nd 2009, 4:11pm
What vacuum hose should one dump a little of this in? My Van could use it! Thanks.
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Van Model Year: 1985
Extra Info: 350 with 700r4
Postby ihatemybike » May 22nd 2009, 9:02pm
I remove the air cleaner assembly and slowly pour it into the intake.
Aaron
ihatemybike
Topics: 68
Postby davesyo » May 23rd 2009, 2:31am
I did this one time on my 01 and added it slowly through the throttle body with no problems .
davesyo
Years of Membership: davesyo has been a member for 13 full yearsdavesyo has been a member for 13 full yearsdavesyo has been a member for 13 full yearsdavesyo has been a member for 13 full yearsdavesyo has been a member for 13 full yearsdavesyo has been a member for 13 full yearsdavesyo has been a member for 13 full yearsdavesyo has been a member for 13 full yearsdavesyo has been a member for 13 full yearsdavesyo has been a member for 13 full yearsdavesyo has been a member for 13 full yearsdavesyo has been a member for 13 full yearsdavesyo has been a member for 13 full years
Postby Leeann_93 » May 23rd 2009, 2:56am
Yep, through the intake, ie throttle body.
Postby adibv5 » May 23rd 2009, 4:55pm
you guys do this on idle? or higher rpms. i would think my van with stall or die if put liquid in the air intake.
adibv5
Years of Membership: adibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full years
Postby Mr_Bowtie » May 23rd 2009, 5:21pm
I believe you want to do it at idle, dump as much in there until it dies, let it sit for a few minutes then start it up and let it smoke out. I think you can also put it in through a vacuum line that runs to the intake. :mrgreen:
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Postby woodhaven22 [OP] » May 23rd 2009, 11:13pm
I can't find the boost vacum hose for the seafoam.
Does anyone know where this is located.
2001 AWD Astro 4.3L
Thanks
woodhaven22
Fueling (5/8 tank)
Fueling (5/8 tank)
Topics: 34
Postby ihatemybike » May 24th 2009, 2:39am
2001 does not have vacuum boost brakes, hence no vacuum boost hose.
Remove the air box, pull the intake hose/elbow off the throttle body, if you disconnected the MAF sensor plug it back in, Grumpy wouldn't run without it, start engine, follow direction on can and slowly pour in throttle body.
Aaron
ihatemybike
Topics: 68
Postby Gary » May 24th 2009, 12:21pm
Guys,not to be the nay sayer of another point of view,but when you say you see all this smoke,isn't that liquidized carbon you see coming out and isn't that a kin to liquidized sand paper leaving parts never to be the same?.Just a thought.I mean there is two sides to every point of view and all I am trying to do is present another side. :2:
Gary
Dearly Departed
Topics: 136
Postby ihatemybike » May 24th 2009, 3:31pm
Isn't gasoline is a liquidized carbon? Isn't smoke considered gaseous state?
If I had a van run worse after a Seafoam treatment I'd be concerned, but thus far they have all run better after.
Aaron
ihatemybike
Topics: 68
Postby Outlaw50 » May 25th 2009, 12:58pm
I have been running Sea Foam mixed in my gasoline for mowers, quads, chainsaws, weedeaters, outboards...etc for about 20 years and have never had problems with it. I have taken a few carbs apart over the years on these engines and found them to be spotless inside.
I run it in a tank full of gas in the van about every 6 months. It works well to clean the injectors and keeps the fuel system free of moisture.
***Mark***
1993 Astro w/189,000 miles ..........scrapped......
1998 Astro LS w/152,000 miles.......the Cadillac!........lol
Outlaw50
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: Outlaw50 has been a member for 12 full yearsOutlaw50 has been a member for 12 full yearsOutlaw50 has been a member for 12 full yearsOutlaw50 has been a member for 12 full yearsOutlaw50 has been a member for 12 full yearsOutlaw50 has been a member for 12 full yearsOutlaw50 has been a member for 12 full yearsOutlaw50 has been a member for 12 full yearsOutlaw50 has been a member for 12 full yearsOutlaw50 has been a member for 12 full yearsOutlaw50 has been a member for 12 full yearsOutlaw50 has been a member for 12 full years
Topics: 12
Alias (AKA): Mark
Extra Info: Nice ride
Postby Big_kid » May 25th 2009, 2:01pm
We use it at the small engine shop on occasion. We've had no problems with it.
Topics: 185
Images: 344
Extra Info: 2WD 5.7 V8
Postby rev_les » June 9th 2009, 4:46am
i unhook the vacuum line at the rear of the intake, put on a piece of surrogate vacuum line with an inflation needle you use to air up balls with put into it. get the motor hot,rev it up pretty good, dip it in the seafoam can and it meters it into the vacuum line . works for steamcleaning with water too. Shops de-carbon cars regularly with no ill effects. "aside from the smoke cloud ticking off neighbors" :rofl:
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full years
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby GaryZ » June 9th 2009, 5:11pm
Gary wrote:Guys,not to be the nay sayer of another point of view,but when you say you see all this smoke,isn't that liquidized carbon you see coming out and isn't that a kin to liquidized sand paper leaving parts never to be the same?.Just a thought.I mean there is two sides to every point of view and all I am trying to do is present another side. :2:
I am pretty sure most of the smoke is the burning Seafoam and not carbon.
I only recently got hooked on Seafoam. The stuff is amazing.
'98 Astro AWD, white with gray interior,
3.42:1 diffs, 235/70 x 15 tires,
195,000 miles on original engine and trans
'99 Kawasaki ZX11D
'85 Yamaha Venture Royale with 1300 engine & Vmax cams
GaryZ
Years of Membership: GaryZ has been a member for 12 full yearsGaryZ has been a member for 12 full yearsGaryZ has been a member for 12 full yearsGaryZ has been a member for 12 full yearsGaryZ has been a member for 12 full yearsGaryZ has been a member for 12 full yearsGaryZ has been a member for 12 full yearsGaryZ has been a member for 12 full yearsGaryZ has been a member for 12 full yearsGaryZ has been a member for 12 full yearsGaryZ has been a member for 12 full yearsGaryZ has been a member for 12 full years
Postby 'cudapaul » June 10th 2009, 5:10am
Sorry to hear about you newest addiction, Gary!!!!!!!!!!!!!
'cudapaul
Years of Membership: 'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years
Alias (AKA): 'cudapaul
Extra Info: LT AWD
It is currently April 11th 2021, 10:31am
Attached by: jfunkngroove
jfunkngroove
Comments: 17
Time: 10:38pm
Date: Apr 08 '21
Time: 8:52pm
jfunkngroove
Comments: 17
Date: Apr 08 '21
Time: 1:55am
Date: Mar 22 '21
Time: 2:11pm
Attached by: PinVanMan
PinVanMan
Date: Mar 21 '21
Time: 11:32pm
Users browsing this forum: No registered users and 17 guests
cron
