Fuel Trim Readings & O2 Sensors
Postby Mmusicman [OP] » September 19th 2013, 2:58am
I'm using my first OBD2 live data reader, along with a basic OBD2 Lite Program (text only), and trying to make hay out of the readings to determine what issue I may have. I'm currently getting 10-12mpg (used to get 15+ same van).
I've swapped a few things, so I'm pretty sure what is not the problem.
Fuel trim avg readings on highway as high as +6 to +7. Bank 1 Sensor 3 seems to read low most of the time, but sometimes stays in the 8's. I'm not sure which one this is, but I want to replace it. The two manifod O2 sensors seem correct.
Any tips or reading suggestions appreciated.
Firing on 5 Cylinders (L5)
Topics: 71
Images: 49
Re: Fuel Trim Readings & O2 Sensors
Postby wayne228 » September 19th 2013, 4:15am
Hi, You want fuel trim as close to 0 as possible. Without further info ( miles on van, any codes and so on...) it is hard to say whats up, but you can not go wrong with a new quality (OEM) cap and rotor. Depending on miles you may also look at plugs. A fuel filter is another possible one on the list if you have not changed it, along with a good quality air cleaner. Wires and more come in if your getting a code. Good luck
wayne228
Years of Membership: wayne228 has been a member for 7 full yearswayne228 has been a member for 7 full yearswayne228 has been a member for 7 full yearswayne228 has been a member for 7 full yearswayne228 has been a member for 7 full yearswayne228 has been a member for 7 full yearswayne228 has been a member for 7 full years
Topics: 10
Images: 15
Van Model Year: 2002
Extra Info: AWD LS 4.3L V6
Postby Zebediah III » September 19th 2013, 4:49am
Seems way too lean to me.
Zebediah III
Images: 16
Extra Info: 383 Crate Motor
It is currently September 21st 2020, 1:21pm
Isuzuguru
Comments: 0
Date: Today
Time: 5:20am
Maddog
Comments: 31
Date: Sep 18 '20
Time: 11:15pm
Maddog
Comments: 31
Date: Sep 18 '20
Time: 10:47pm
Maddog
Comments: 31
Date: Sep 18 '20
Time: 10:43pm
Maddog
Comments: 31
Date: Sep 18 '20
Time: 10:40pm
Users browsing this forum: No registered users and 15 guests
