First of a few posts here needing some assistance...
OK the background....the Safari i got has clocked over 210,000 miles and has been throwing a code for a while to do with the EGR valve (think it was "EGR Pintle Position Circuit Failure" and it was absoultely terrible to drive, no power, no acceleration etc...so i went out and spent loads of money
Fitted this no problem (have removed the one that was fitted on there before to clean it!) and the old one that came off was really chocked up with soot and was black and orrible, i cleaned what i could out of the hole in the engine block and cleaned the surface and refitted the new EGR valve.
Started up, cleared the code and no error codes being thrown now (hurrah), but, and its a big un, the van is "better" but its still realllly bad to drive in so much as it has very little acceleration, to start then it seems to get into a power range and the acceleration is tehre, but then it runs out of power and then has to struggle to change gear, then when it does it cant accelerate again.
Also the engine (according to a mate of mine) sounds very flat and has an "odd" low tone to it - he thinks air / fuel is wrong somehow...
In the past month i have changed Rotor arm, distrubutor cap, HT leads & plugs so they should all be fine, it will be this weekend getting a new air filter, fuel filter, oil change, oil filter, trans filter, trans fluid and coolant change but is there anything else anyone can think of that would cause it to be lacking in power and off song so to speak??
Cheers
ian
