Lousy gas mileage!
Lousy gas mileage!
Postby Wiper [OP] » June 4th 2009, 2:45pm
Hi
I'm having a gas mileage problem...at 102 liters - it drives only approx. 300 Km - and the idle are very unstable...
I also just returned from a guy that had a computer on the van and a Exchaust measurement.
It read error code 35+44 - and had a very bad CO2.
So I'm thinking that's the "Air Control Valve" that has a problem - so I will now also try to change this.
But can someone tell me where I can find a "step by step guide" for doing that (picture guide) and a engine layout picture...?
Wiper
Years of Membership: Wiper has been a member for 12 full yearsWiper has been a member for 12 full yearsWiper has been a member for 12 full yearsWiper has been a member for 12 full yearsWiper has been a member for 12 full yearsWiper has been a member for 12 full yearsWiper has been a member for 12 full yearsWiper has been a member for 12 full yearsWiper has been a member for 12 full yearsWiper has been a member for 12 full yearsWiper has been a member for 12 full yearsWiper has been a member for 12 full years
Topics: 47
Extra Info: CL V6 RWD
Re: Lousy gas mileage!
Postby RichinMD » June 4th 2009, 3:28pm
First thing, what is the year of the vehicle and/or what type engine do you have? I am looking in my manual and code 35 (assuming you have an OBD I system) is an Idle speed control error (carbureted engine) or an Idle Air Control error (fuel injected).
Code 44 is lean exhaust.
If you had just one or the other of these codes, I would recommend changing the associated parts, but it sounds to me like you need a tune up and to check your timing.
1995 Astro, 175k miles, VIN W, 2WD, Tow Pkg
RichinMD
Years of Membership: RichinMD has been a member for 11 full yearsRichinMD has been a member for 11 full yearsRichinMD has been a member for 11 full yearsRichinMD has been a member for 11 full yearsRichinMD has been a member for 11 full yearsRichinMD has been a member for 11 full yearsRichinMD has been a member for 11 full yearsRichinMD has been a member for 11 full yearsRichinMD has been a member for 11 full yearsRichinMD has been a member for 11 full yearsRichinMD has been a member for 11 full years
Extra Info: 2wd vin W
Postby astro355 » June 4th 2009, 3:34pm
Sounds like a vacuum leak to me.
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby RichinMD » June 4th 2009, 3:37pm
Yeah, that's the first thing it says to troubleshoot for the lean exhaust.
RichinMD
Postby astro355 » June 4th 2009, 3:39pm
Well, considering that the OP has lousy gas mileage, a lean exhaust code and the IAC code, that's where I would start.
astro355
Postby Wiper [OP] » June 4th 2009, 7:14pm
Hi
what is OP ?
It's a Astro 1995 fuel enjected vortech engine
vacuum leak are very difficult to find (for me).....all the lines according to the vacuum diagram are checked...
35+38+44 are all the error codes.
Previously changed - map sensors, oxygen sensor, pcv valve, egr etc... it runs - but not 100% perfect...
Wiper
Topics: 47
Postby astro355 » June 4th 2009, 11:49pm
OP = original poster
The easiest way to find a vacuum leak is to use a small bottle of propane, like the ones you would use for those mini camping grills. You would attach a rubber hose to the end of it. With the van running, you would open the valve on the propane and then move the end of the rubber hose over each vacuum hose, then over all gasket areas (throttle body, intake, etc) and any other areas that seperate the intake charge from the outside atmosphere.
If/when you find the leak, the propane will be sucked in the leak and the idle will increase. It will sound like you stepped on the gas a little. You really can't just look at vacuum lines and such to determine if its leaking or not.
astro355
Postby toddb » June 5th 2009, 12:09am
Astro355 forgot to mention to make sure you are smoking a big fat one while performing the propane test. j/k
1997 Safari 2WD 3:73 locking. 300,000 km - almost full load.
2000 Safari AWD 3:73 locking. 275,000 km - Full load.
toddb
Years of Membership: toddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full years
Postby gtkane » June 5th 2009, 4:15am
toddb wrote:Astro355 forgot to mention to make sure you are smoking a big fat one while performing the propane test. j/k
I thought that's how you find propane leaks...he,he!
User album #4...check it out!
gtkane
Alias (AKA): Astruck
Extra Info: nasty 4.3
Postby astro355 » June 5th 2009, 5:17am
gtkane wrote:I thought that's how you find propane leaks...he,he!
Quoted for truth.
astro355
Postby Wiper [OP] » June 17th 2009, 10:02pm
Hi
I've repalced the Idle air valve - no change - still getting a code 44
I havn't been able to find any small bottle of propane, used for this mini camping grills - so instead I used some fuel an diesel engine start (on a aerosol) - but no response from the engine with that...;0(
so I'll guess I have to get that propane somehow...
Wiper
Topics: 47
Postby astro355 » June 18th 2009, 12:18am
You need to find that leak before you change parts. Please use the propane.
astro355
Postby webcat » June 18th 2009, 1:08am
A hillbilly told me you could use starter fluid instead of propane ! I dont know if this is true .
webcat
Firing on 3 Cylinders (L3)
Topics: 253
Alias (AKA): Larry aka Rambo
Extra Info: g10 5.7L vortec
Postby astro355 » June 18th 2009, 3:03am
Starter fluid doesn't work as well as propane. Propane works better because its a gas (as opposed to a liquid) and is easily carried by air.
astro355
Postby webcat » June 18th 2009, 3:49am
Learn something every day , someday i'll be pretty smert !
webcat
Topics: 253
Postby Mr_Bowtie » June 18th 2009, 10:40pm
This is the first I have heard of using propane too. Thats awesome.....I will never use carb cleaner again. Good tip 355! 8-)
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Years of Membership: Mr_Bowtie has been a member for 12 full yearsMr_Bowtie has been a member for 12 full yearsMr_Bowtie has been a member for 12 full yearsMr_Bowtie has been a member for 12 full yearsMr_Bowtie has been a member for 12 full yearsMr_Bowtie has been a member for 12 full yearsMr_Bowtie has been a member for 12 full yearsMr_Bowtie has been a member for 12 full yearsMr_Bowtie has been a member for 12 full yearsMr_Bowtie has been a member for 12 full yearsMr_Bowtie has been a member for 12 full yearsMr_Bowtie has been a member for 12 full years
Topics: 74
Images: 29
Van Model Year: 1985
Extra Info: 350 with 700r4
Postby gwd » June 19th 2009, 5:57pm
The propane bottle in the plumber soldering kit would work also. Just open the nozzle a bit and wave over all connections, hoses and manifold mating surfaces.
gwd
Years of Membership: gwd has been a member for 12 full yearsgwd has been a member for 12 full yearsgwd has been a member for 12 full yearsgwd has been a member for 12 full yearsgwd has been a member for 12 full yearsgwd has been a member for 12 full yearsgwd has been a member for 12 full yearsgwd has been a member for 12 full yearsgwd has been a member for 12 full yearsgwd has been a member for 12 full yearsgwd has been a member for 12 full yearsgwd has been a member for 12 full years
Postby Wiper [OP] » June 20th 2009, 5:09pm
Hi
I was going to change the Throttle Posistion Sensor today (got i by a mistake - so why not change it?)
Anyway when I removed the different hoses etc. I disscovered that a little line/hose was just hanging underneath the TPS - found out that it was:
"tube - fuel vapor canister purge" no 36 on this image (need login first):
http://www.autozone.com/autozone/repair ... 52800a8026
So mounted that (and not the new TPS - I'll maybe do that tomorrow) went for a drive (3 miles) to buy propane and the SES was "quiet" all the way - The car acted as the PCM had to make some adjustment - how long are the PCM to "reset" itself?
Got the propane can (only thing I could buy, was a little "weed burner" with a handle and a long hose/burner- (and not that kind of weed guys..;0)...) anyway did the propane inspection at the different hoses and intakes and the car didn't respond in the Idle run. - So I'll assume everything are correct now and I'll have to see how it goes on a full tank now...
thank you guys for all the feedback!
Wiper
Topics: 47
Postby Wiper [OP] » July 27th 2009, 10:43pm
just a follow up:
It was the ignition that was way off...got i adjusted and now I drive aproxx. 800 km on a full tank.... :swerve:
Wiper
Topics: 47
Postby astro355 » July 27th 2009, 11:27pm
What tipped you off that it was the ignition being off?
astro355
It is currently April 21st 2021, 9:39am
Date: Today
Time: 1:09am
Comments: 13
Date: Apr 17 '21
Time: 9:03pm
Comments: 13
Date: Apr 16 '21
Time: 6:08pm
kvargas1356
Date: Apr 11 '21
Time: 10:20pm
Attached by: jfunkngroove
jfunkngroove
Comments: 17
Date: Apr 10 '21
Time: 10:38pm
