by castle_Rock [OP] » August 7th 2009, 10:53pm
by ghostrider1061 » August 8th 2009, 12:45am
by rev_les » August 8th 2009, 1:05am
by castle_Rock [OP] » August 9th 2009, 10:15pm
by astro355 » August 10th 2009, 1:19am
by castle_Rock [OP] » August 10th 2009, 3:21pm
by GaryZ » August 10th 2009, 3:39pm
by astro355 » August 10th 2009, 9:02pm
castle_Rock wrote:Van seems to be running fine now, I figured I'd wait a couple days before checking the stick, since its brand new fluid, I wont be able to get a good reading since it leaves a streak on the stick - I then checked today after I drove 15 miles home, and I do not see anything on the stick, I even wiped it off clean and stuck it back in while the engine was running. Nothing.
When driving around 50-55 miles an hour, after about 5 minutes, the van seems to "surge" it acts like its not getting enough gas to the engine, almost like to delivers gas, then cuts it off, delivers, cuts it off. I usually drive with the cruise control on and you can both hear the engine rev up for a split second and the vehicle speeds up then slows back down, this just occurred after changing the filter and gasket, fuel lines are fine except need to be replaced. Any ideas? It also only does this while in regular Drive mode, if you shift into the [D] it does not occur.
by rev_les » August 11th 2009, 11:15pm
by castle_Rock [OP] » August 19th 2009, 3:03pm
by astro355 » August 19th 2009, 7:27pm
by castle_Rock [OP] » August 19th 2009, 7:49pm
by astro355 » August 19th 2009, 10:17pm
It is currently March 1st 2021, 7:51pm
Engines Forum |
Engine Repairs, Modifications, Diagnostics, Tuning, Upgrading, Questions. <a href="https://ad.doubleclick.net/ddm/trackclk/N8334.275400VERTICALSCOPEINC./B20209277.204028354;dc_trk_aid=407011718;dc_trk_cid=94070067;dc_lat=;dc_rdid=;tag_for_child_directed_treatment="target="_blank"><img src="https://tpc.googlesyndication.com/pagead/imgad?id=CICAgKDrrqWwMRCAARgcKAEyCN4sAjjtai4k" border="0" align="right"> <IMG SRC="https://ad.doubleclick.net/ddm/trackimp/N8334.275400VERTICALSCOPEINC./B20209277.204028354;dc_trk_aid=407011718;dc_trk_cid=94070067;ord=;dc_lat=;dc_rdid=;tag_for_child_directed_treatment=?" BORDER="0" HEIGHT="1" WIDTH="1" ALT="Advertisement"> |
Moderator: chevy57bert |
Previous topic Next topic |
Sponsors |
Users browsing this forum: Google Adsense [Bot], MHM and 26 guests
