Engine Removal 1997 Safari
Postby Customcomp [OP] » September 14th 2009, 12:16pm
I am new to the Astrosafari forum - Hello from Canada! I am replacing an engine in my son's 1997 Safari van. The engine bottom end failed and loss oil pressure. I have read a few posts and have identied my van as one with a welding in radiator support. I need to know where to get the bracket for cutting the support. Any ideas? As I am a home DIY'er I am going to remove the engine through the front as I do not have a shop with a lift. How much do I have to take offf to get the engine out this way? Thx rich
Customcomp
Years of Membership: Customcomp has been a member for 11 full yearsCustomcomp has been a member for 11 full yearsCustomcomp has been a member for 11 full yearsCustomcomp has been a member for 11 full yearsCustomcomp has been a member for 11 full yearsCustomcomp has been a member for 11 full yearsCustomcomp has been a member for 11 full yearsCustomcomp has been a member for 11 full yearsCustomcomp has been a member for 11 full yearsCustomcomp has been a member for 11 full yearsCustomcomp has been a member for 11 full years
  • How HIGH for subframe and engine removal?
    by Rod's Trucks » December 2nd 2020, 5:00am in Engines
    December 3rd 2020, 6:11am
  • 2003 alternator bracket removal
    by PinVanMan » March 21st 2021, 1:32am in Engines
    Last post by stent View the latest post
    April 6th 2021, 9:08pm
    44
    April 13th 2021, 1:30am
Re: Engine Removal 1997 Safari
Postby ASTROJOE LT1 » September 14th 2009, 1:00pm
Good Morning Rich and Welcome to our forum. We will all see if we can help you through your engine removal. I don't think they make a bracket to patch up the radiator support after you cut it. . There are members here that have taken the engine out the front and ones that have dropped the subframe so I am sure you will get quite a few opinions.Mine is an older model but this picture shows about how much you have to remove.
89 ASTRO CL Shorty,95 Corvette LT1 Engine,4L60E, 3.42 Gears with a Torsen Posi,Black on Gray ( Original Color )
ASTROJOE LT1
Years of Membership: ASTROJOE  LT1 has been a member for 13 full yearsASTROJOE  LT1 has been a member for 13 full yearsASTROJOE  LT1 has been a member for 13 full yearsASTROJOE  LT1 has been a member for 13 full yearsASTROJOE  LT1 has been a member for 13 full yearsASTROJOE  LT1 has been a member for 13 full yearsASTROJOE  LT1 has been a member for 13 full yearsASTROJOE  LT1 has been a member for 13 full yearsASTROJOE  LT1 has been a member for 13 full yearsASTROJOE  LT1 has been a member for 13 full yearsASTROJOE  LT1 has been a member for 13 full yearsASTROJOE  LT1 has been a member for 13 full yearsASTROJOE  LT1 has been a member for 13 full years
Images: 8
Extra Info: 95 LT1 Engine
Postby Customcomp [OP] » September 14th 2009, 9:30pm
Thanks Astrojoe - What a sweet ride. The Haynes book shows the brackets to assist cutting the rad support but I have searched and come up dry. Help anybody!
Customcomp
Postby ihatemybike » September 14th 2009, 9:45pm
What about undoing the wiring harness and other connections unbolting the sub-frame and lifting the front of the van off. I've seen pics where people support the front of the van using an engine hoist and then wheel the sub-frame out from underneath.
Aaron
Prev Astros:99,97,00,94,87,86
ihatemybike
Firing on 6 Cylinders (L2)
Topics: 68
Postby Customcomp [OP] » September 15th 2009, 2:28am
Thanks for the reply Ihatemy bike. I have seen this method detailed on this site but it requires more hoisting equipment than I have. All I have is a hydraulic engine hoist. I really need the cutting brackets. someone has to have used them.
Customcomp
Postby cool95astro » April 1st 2015, 6:08pm
I have a 95 astro the first time I changed engines I cut the core header next to where the sides of the radiator go when I was done I welded it back in a saw makes a thin cut easy to mig back in.
cool95astro
Years of Membership: cool95astro has been a member for 6 full yearscool95astro has been a member for 6 full yearscool95astro has been a member for 6 full yearscool95astro has been a member for 6 full yearscool95astro has been a member for 6 full yearscool95astro has been a member for 6 full years
Extra Info: 350 v8
It is currently April 13th 2021, 1:30am
kvargas1356
Date: Apr 11 '21
Time: 10:20pm
Attached by: jfunkngroove
jfunkngroove
Comments: 17
Date: Apr 10 '21
Time: 10:38pm
Date: Apr 08 '21
Time: 8:52pm
jfunkngroove
Comments: 17
Date: Apr 08 '21
Time: 1:55am
Date: Mar 22 '21
Time: 2:11pm
Users browsing this forum: No registered users and 24 guests
