by 98cirider [OP] » September 19th 2009, 2:20am
by ghostrider1061 » September 19th 2009, 8:54pm
by Bertscova » September 19th 2009, 10:07pm
by Leeann_93 » September 19th 2009, 10:32pm
by 98cirider [OP] » March 4th 2010, 9:29pm
by Leeann_93 » March 4th 2010, 10:32pm
by 98cirider [OP] » March 4th 2010, 11:23pm
Leeann_93 wrote:Refresh my memory - what kind/capacity of battery do you have and have you had it tested?
by Leeann_93 » March 4th 2010, 11:51pm
by Astroplane » March 5th 2010, 8:04am
by 98cirider [OP] » March 5th 2010, 6:29pm
Astroplane wrote:Check fuel pump relay. It may be using the oil pressure sender as a backup which requires oil pressure greater than 4 psi.
by astro355 » March 5th 2010, 11:28pm
by Astroplane » March 6th 2010, 3:44am
98cirider wrote:How do I check the fuel pump relay?
98cirider wrote:So, you are saying that GM used enough sophisticated technology to have the oil pressure sender step in as a back up to a failed fuel pump relay?
by astro355 » March 6th 2010, 3:54am
Astroplane wrote:98cirider wrote:How do I check the fuel pump relay?
Wiring diagram helps. You can jump the Gray and Orange wire terminals on the vehicle connector and see if the pump runs. You may be able to swap with A/C relay to test.98cirider wrote:So, you are saying that GM used enough sophisticated technology to have the oil pressure sender step in as a back up to a failed fuel pump relay?
Very simple design. Some drivers may not even notice the relay has failed except for extended cranking.
by Astroplane » March 6th 2010, 4:32am
astro355 wrote:I have run mine off of just the oil pressure sender and didn't have extended cranking.
by 98cirider [OP] » March 8th 2010, 6:22pm
astro355 wrote:Astroplane wrote:Check fuel pump relay. It may be using the oil pressure sender as a backup which requires oil pressure greater than 4 psi.
The real question is does the OP hear the fuel pump kick on when the ignition is turned to the start position?
I would put a fuel pressure gauge on the van and see what that looks like. If it takes a couple extra seconds for the fuel pump to build the pressure, I would want to know.
To the OP, does it matter if the engine is cranking or you're just setting there with the ignition in the start position letting the fuel pump build pressure? If you are not sure, try it once. Instead of cranking the engine the next time you try and start it, just turn the ignition on and wait. Then try and start the van.
by Astroplane » March 9th 2010, 7:07am
by Astroplane » March 9th 2010, 7:27am
98cirider wrote:Does this point the diagnosis in any specific direction?
by 98cirider [OP] » March 9th 2010, 5:10pm
Astroplane wrote:98cirider wrote:Does this point the diagnosis in any specific direction?
As astro355 said, a test gauge would let you see what is actually happening during your 3 step test. Try cycling the key to ON three times before you start it. It sounds like the pump is holding its' prime, but taking time to build pressure. Even though you have no CEL, have you checked for codes?
by astro355 » March 9th 2010, 5:14pm
by astro355 » March 9th 2010, 5:15pm
Astroplane wrote:astro355 wrote:I have run mine off of just the oil pressure sender and didn't have extended cranking.
I'll bet your engine is in better health than most. 4 psi doesn't take long to reach the sender.
It is currently March 6th 2021, 10:19am
Engines Forum |
Engine Repairs, Modifications, Diagnostics, Tuning, Upgrading, Questions. <a href="https://ad.doubleclick.net/ddm/trackclk/N8334.275400VERTICALSCOPEINC./B20209277.204028354;dc_trk_aid=407011718;dc_trk_cid=94070067;dc_lat=;dc_rdid=;tag_for_child_directed_treatment="target="_blank"><img src="https://tpc.googlesyndication.com/pagead/imgad?id=CICAgKDrrqWwMRCAARgcKAEyCN4sAjjtai4k" border="0" align="right"> <IMG SRC="https://ad.doubleclick.net/ddm/trackimp/N8334.275400VERTICALSCOPEINC./B20209277.204028354;dc_trk_aid=407011718;dc_trk_cid=94070067;ord=;dc_lat=;dc_rdid=;tag_for_child_directed_treatment=?" BORDER="0" HEIGHT="1" WIDTH="1" ALT="Advertisement"> |
Moderator: chevy57bert |
Previous topic Next topic |
Sponsors |
Users browsing this forum: No registered users and 17 guests
