first things first, I have a 96 Chevy Astro van with roughly a hundred ninety five thousand miles 4. 3 v 6 RWD van.several days ago I was driving on the highway for roughly 5 minutes when I lost all of pressure and engine shutdown. I pulled over on the side off the highway and realized that the oil pressure coolant line has popped off the radiator. And you would not start at that point I had a vehicle towed home and let sit for the night until the next day.
the next day I did a complete tune up including oil 10w 30 spark plugs oil filter radiator flush. After completing all this I attempted to start the van engine started a little rough but it started and ran a good. Oil pressure was around 40 to 50 psi at idle. At idle the oil pressure on a normal day is 40 to 50 psi running 5w 30 well. So I decided to install 10w 30 due to the fact that I lost all oil all over the highway. Just in case I cause slight damage to the engine figuring that would help lube bearings and so forth. Now I have a heavy in extremely loud knocking in the engine and when the engine comes up to operating temperature I go from 40 psi oil pressure to anywhere from 20 to 10 psi. I am a fairly experience mechanic ase certified with several other mechanics on call for any questions I have. I unfortunately cannot figure out where this noise is coming from. With a stethoscope I listen to several points on the motor and I cannot determine exactly where the noise is coming from but it sounds like it's coming from the lower end. If anybody has any advice I would greatly appreciate it.
