po1345 code new distributor
Postby squitch [OP] » November 4th 2009, 1:44am
I just installed a new accel ignition kit on my 2000 LS . billet distributor, coil wires. made for the 4.3 astro with new hall effect switch.
old distributor was worn.
now im getting po1345 code and lots of pinging.
from what ive read , a scan tool is needed to zero out the new distributor or timing . or sync the cam sensor and crank sensor.
can anyone shed some light on how this is done?
and where to get it done.
squitch
Years of Membership: squitch has been a member for 11 full yearssquitch has been a member for 11 full yearssquitch has been a member for 11 full yearssquitch has been a member for 11 full yearssquitch has been a member for 11 full yearssquitch has been a member for 11 full yearssquitch has been a member for 11 full yearssquitch has been a member for 11 full yearssquitch has been a member for 11 full yearssquitch has been a member for 11 full yearssquitch has been a member for 11 full years
  • distributor install help
    by Sp3cialNe3dz » October 1st 2020, 3:08am in Engines
    Last post by Bossman View the latest post
    October 1st 2020, 5:39am
  • Distributor install issue
    by Geek » November 11th 2020, 12:22pm in Engines
    Last post by Devonian View the latest post
    November 25th 2020, 2:19am
    77
    March 6th 2021, 10:04am
Re: po1345 code new distributor
Postby astro355 » November 4th 2009, 3:28am
squitch wrote:I just installed a new accel ignition kit on my 2000 LS . billet distributor, coil wires. made for the 4.3 astro with new hall effect switch.
What kind of hold-down bracket are you using for the distributor? Pics are best.
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby squitch [OP] » November 4th 2009, 5:41am
got rid of code with scan tool.
but engine sounds mecanically noisy
reading about 19 degrees advance at idle
cnat find what stock timing should read.
could it be 1 tooth advanced? and still idle smooth
squitch
Postby astro355 » November 4th 2009, 6:16am
Have you driven the van yet? Depending on what your definition of a smooth idle is, I suppose you could have somewhat of a smooth idle but you would have no power.
Which hold-down bracket are you using? Original or any aftermarket one, it does make a difference in the ease of timing.
astro355
Postby squitch [OP] » November 4th 2009, 1:39pm
accel clamp on dist.
squitch
Postby squitch [OP] » November 4th 2009, 5:07pm
new dist cant use stock hold down. going to start over and c if im off a tooth .
squitch
Postby astro355 » November 4th 2009, 7:52pm
Are you using a timing light?
Which distributor did you get? The accel distributor I have can be used with the factory hold down bracket.
astro355
Postby squitch [OP] » November 9th 2009, 2:06am
problem solved. i kept deleting the code and adjusting the distributor until it didmnt throw a code..
the idle timing of an astro is 17-20 degrees advance. i checked another 2000 and a 1999.
accell vt1 ignition kit
truck is running gr8.
thanks for your posts
squitch
It is currently March 6th 2021, 10:04am
Attached by: MHM
MHM
Comments: 22
Date: Mar 02 '21
Time: 2:20pm
Attached by: MHM
MHM
Comments: 22
Date: Mar 01 '21
Time: 7:27pm
Ken2.7
Date: Feb 24 '21
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Date: Feb 23 '21
Time: 8:41pm
