Proper Coolant Temp?
Postby jrfiero [OP] » March 24th 2014, 1:42pm
I searched! Really. I saw one reference asking if these vans use a 195 degree tstat -
I just bought a 2003 Astro SLT and it seems to run a little cool, midway between the numbers on the gauge, and the heat isn't what I would expect. I will get a manual but don't have one yet (where is a good source?)
So, what is the temp supposed to be? Is a 195 tstat correct?
Thanks,
Jonas
jrfiero
Years of Membership: jrfiero has been a member for 6 full yearsjrfiero has been a member for 6 full yearsjrfiero has been a member for 6 full yearsjrfiero has been a member for 6 full yearsjrfiero has been a member for 6 full yearsjrfiero has been a member for 6 full years
Extra Info: SLT AWD
  • coolant leak detective
    by fourwheelwheelie » July 18th 2020, 9:29pm in Engines
    August 13th 2020, 11:53pm
  • Coolant PH test strip advice?
    by rlyoung » July 27th 2020, 4:16pm in Engines
    July 27th 2020, 10:59pm
    11
    December 1st 2020, 3:43pm
Re: Proper Coolant Temp?
Postby BigWheelinBubba » March 24th 2014, 6:59pm
It should run anywhere between 190-220 on average.
BigWheelinBubba
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: BigWheelinBubba has been a member for 6 full yearsBigWheelinBubba has been a member for 6 full yearsBigWheelinBubba has been a member for 6 full yearsBigWheelinBubba has been a member for 6 full yearsBigWheelinBubba has been a member for 6 full yearsBigWheelinBubba has been a member for 6 full years
Van Model Year: 1991
Extra Info: LT1 4L60E RWD
Postby Philly758 » March 24th 2014, 8:42pm
My scangauge usually reads 197 on warmup until the thermostat opens then it drops down to about 188 on average (at least that is what it has been all winter, if that makes a difference).
:auto-gmcredsmiley:
2000 GMC Safari SLE, AWD - 150k+
- Lifted with 22-687 leaf springs and 2" blocks
- Cooper AT3 30x9.5's on Cragar Soft 8's
- Hellwig Rear Sway Bar
- TruCool Trans Cooler
- Corvette Servo
- Moog steering
- Bilstein HD's
- 3.73 G80
Philly758
Years of Membership: Philly758 has been a member for 10 full yearsPhilly758 has been a member for 10 full yearsPhilly758 has been a member for 10 full yearsPhilly758 has been a member for 10 full yearsPhilly758 has been a member for 10 full yearsPhilly758 has been a member for 10 full yearsPhilly758 has been a member for 10 full yearsPhilly758 has been a member for 10 full yearsPhilly758 has been a member for 10 full yearsPhilly758 has been a member for 10 full years
Topics: 36
Extra Info: SLE AWD
Postby Mmusicman » March 24th 2014, 9:59pm
195 is correct
Firing on 6 Cylinders (L5)
Topics: 73
Images: 49
Postby WoodButcher » March 25th 2014, 12:48am
195 is the thermostat according to hoyle. I got my van at 125,000 mi and until I changed the thermostat it ran cool if the dash gauge were to be believed about 150 -160. Around 150,000 I the water pump went so I put in a 185 because it always ran good but not 195 deg. Like Philly I use an Ultraguage and have similar temps, she runs around 188 - 192 all year long and I've got over 275,000 miles on her now.
WoodButcher
Firing on 5 Cylinders (L6)
Topics: 30
Images: 513
Alias (AKA): Bruce
Extra Info: 5.7L RWD
Postby c.zhou57 » March 28th 2014, 6:54am
Grab a scan tool to verify the reading if your car is OBD2. The dash gauges are not too accurate.
I thought my van was running too cool, and the dash was showing somewhere between the two numbers just like you... somewhere around 180 instead of 195. I put in 2 different thermostats without any change. Finally picked up a cheap bluetooth scan tool and saw that my temps were constantly at 194-197 range the whole time.
c.zhou57
Years of Membership: c.zhou57 has been a member for 7 full yearsc.zhou57 has been a member for 7 full yearsc.zhou57 has been a member for 7 full yearsc.zhou57 has been a member for 7 full yearsc.zhou57 has been a member for 7 full yearsc.zhou57 has been a member for 7 full yearsc.zhou57 has been a member for 7 full years
Van Model Year: 1996
Postby Clevis » March 30th 2014, 5:13pm
Agreed, I just looked at my scantool reading and it's hotter than the gauge
Clevis
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: Clevis has been a member for 6 full yearsClevis has been a member for 6 full yearsClevis has been a member for 6 full yearsClevis has been a member for 6 full yearsClevis has been a member for 6 full yearsClevis has been a member for 6 full years
Images: 8
Extra Info: 140k
Postby RECox286 » March 30th 2014, 11:11pm
Only trust the dash gage when it is SCREAMING at you. Otherwise, it's good to go (usually).
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
It is currently December 1st 2020, 3:43pm
Attached by: icebrrg3rd
icebrrg3rd
Date: Today
Time: 12:16am
djpigs
Comments: 42
Date: Nov 26 '20
Time: 11:23pm
Date: Nov 26 '20
Time: 12:43am
Attached by: Slime
Slime
Date: Nov 24 '20
Time: 11:11pm
K-TRON
Comments: 23
Date: Nov 16 '20
Time: 1:07am
