Eliminating PCV VALVE on 87 ASTRO
Postby coppermtn [OP] » December 1st 2009, 5:53pm
So since i live where emissions do not matter 9,000+ ft. I am removing the pcv valve and running a breather. I have already gutted the charcoal canister when i put in a fuel cell. Will removing the pcv on my valve cover do anything to the fuel mileage or run quality? It runs well for this altitude just seeing what should change once i try firing it up. I was going to cap the lines just as i did with the lines to the efi unti from the canister.
87 4.3 V6 auto. SFA dana 44 ox locked, 5.13 gears, prorock dana 60 detroit rear. Stak 3 speed t-case. Tom woods shafts. 37 inch krawlers.
coppermtn
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: coppermtn has been a member for 11 full yearscoppermtn has been a member for 11 full yearscoppermtn has been a member for 11 full yearscoppermtn has been a member for 11 full yearscoppermtn has been a member for 11 full yearscoppermtn has been a member for 11 full yearscoppermtn has been a member for 11 full yearscoppermtn has been a member for 11 full yearscoppermtn has been a member for 11 full yearscoppermtn has been a member for 11 full yearscoppermtn has been a member for 11 full years
Topics: 13
Alias (AKA): soup kitchen
  • 04 EGR valve location?
    by offctr » August 29th 2020, 6:00pm in Engines
    September 2nd 2020, 9:45pm
  • valve rocker stud, bolt.
    by djpigs » September 11th 2020, 4:02am in Engines
    September 11th 2020, 5:53am
    95
    January 22nd 2021, 4:34pm
Re: Eliminating PCV VALVE on 87 ASTRO
Postby astro355 » December 1st 2009, 7:49pm
I would leave the PCV valve alone. It helps remove crankcase pressure from your engine among other things. Replacing it with a breather will make it harder to the engine to remove back pressure and negatively impact your power output. After all, we are talking about a daily driver.
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby Mr_Bowtie » December 1st 2009, 9:36pm
X2 on keeping the PCV valve! Helps keep your motor clean.
Got any pics of your rig? 8-)
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Van Model Year: 1985
Extra Info: 350 with 700r4
Postby jeff's93astro » December 2nd 2009, 9:31am
bad idea i had a gm product. pcv valve vac line bust so there was no vaccumn going to it and it started leaking oil around the oil pan gasket and front seal cause of the crankcase pressure
95 Astro 5.3L RWD 3/3 drop
03 Suburban 5.3L 2wd 3/5 drop
jeff's93astro
Topics: 55
Images: 19
Extra Info: CS 4.3L V6 RWD
Postby guyonearth » December 2nd 2009, 4:54pm
So, you can't just put a new hose on it? Leaving it off will affect how the engine runs and dump alot of blowby out. It will smell like you have an exhaust leak. I've driven old cars that had a vent pipe for the crankcase fumes from the engine and it's sickening, there's always smoke under the car.
guyonearth
Years of Membership: guyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full years
Topics: 5
Alias (AKA): DeanC
Postby coppermtn [OP] » December 8th 2009, 9:50pm
well its the plastic piece that goes into the valve cover thats broke. From the valve cover to where? I replaced my round air filter assembly with an airraid assembly, does it go into the round air filter assembly or the "throttle body" assembly. should of took a pic before tearing everything up.
coppermtn
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 13
Postby moneymaker » December 8th 2009, 10:58pm
To the front of the throttle body. Almost in the middle towards the bottom. It will have the large nipple! Yes, I said nipple!
moneymaker
Years of Membership: moneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full years
Topics: 7
It is currently January 22nd 2021, 4:34pm
Date: Jan 10 '21
Time: 7:37pm
roachmon
Date: Jan 10 '21
Time: 4:04am
roachmon
Date: Jan 09 '21
Time: 6:34am
OldSchoolNoe
Comments: 9
Date: Jan 01 '21
Time: 8:46pm
pmou
Comments: 71
Date: Dec 31 '20
Time: 4:12am
