10 mpg runs fine
10 mpg runs fine
Postby Taffy25 [OP] » December 6th 2009, 8:43pm
Im currently getting about 10 mpg, no missing, no black smoke, seems fine to drive, its got all new leads, plugs, cap, rotor, air filter, fuel filter, i had to gap the plugs at 60 thou to get it to stop missing even though the fan cowl said .35 and i cant find any fuel leaks at all, engine vacuum is just over 18 in park.
Im guessing the o2 sensor and coolant temp sensor could be the problem but is there anything else i have over looked?
Thanks in advance Taff
Taffy25
Years of Membership: Taffy25 has been a member for 11 full yearsTaffy25 has been a member for 11 full yearsTaffy25 has been a member for 11 full yearsTaffy25 has been a member for 11 full yearsTaffy25 has been a member for 11 full yearsTaffy25 has been a member for 11 full yearsTaffy25 has been a member for 11 full yearsTaffy25 has been a member for 11 full yearsTaffy25 has been a member for 11 full yearsTaffy25 has been a member for 11 full yearsTaffy25 has been a member for 11 full years
Topics: 37
Extra Info: vin z 2.5 D rwd
  • 2003 Astro seems to be running fine except
    by markmitch » October 18th 2020, 3:34pm in Engines
    Last post by dcsleeperdcsleeper is online! View the latest post
    October 19th 2020, 10:08pm
    February 26th 2021, 10:53am
Re: 10 mpg runs fine
Postby astro355 » December 7th 2009, 6:56am
Hello,
why are you guessing its the temp or oxygen sensor? You have the wrong gap. What kind of plugs are you using? Having the wrong gap will make you lose power and eat a lot of gas. By using the wrong gap, you maybe covering up the real problem.
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby Taffy25 [OP] » December 7th 2009, 11:54am
Champions ( i know you can facestab me later) i bought them when i did the head gaskets before i found this site, they were recomended by usa automotives......
You cant drive it with 35 thou gap you get random missfires across all cylinders (you take a lead off any plug and it makes not alot of diffrence)
I have swapped out all the old ignition components i changed to check i havent bought something bad ( i always do a full service on every car i buy, but i keep the old components if they were working for spares)
o2 and coolant temp sensor both affect the amont of fuel put into the motor as i said its a guess.
This morning it started missing like hell as i pulled away from the house, as soon as i took my foot off the gas and put it back on it was fine hasnt done it since, but its never did that before.
Thanks for the reply astro
Forgot to mention the old plugs were gapped at .60 to.
Taffy25
Topics: 37
Postby moneymaker » December 7th 2009, 3:10pm
I've seen others on this forum saying there gap has to run 60 gap. According to an old chiltons book 85-90 vin e 4cyl ran .060 gap. 85-88 vinz tbi ran .040 gap. 89 and up vin z ran .035 gap. Looks like vin b? High output 4.3? Ran .035 gap. I would correct the gap, and check resistance in the wires and ig coil.
moneymaker
Years of Membership: moneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full yearsmoneymaker has been a member for 11 full years
Topics: 7
Postby kevreif » December 8th 2009, 12:59am
i had my van start getting really bad fuel mpg. i pulled a trailor for 200 miles and got 7 mpg! i know something was bad! i had gotten like 13mpg and thought it was just my foot causing bad milage. 92 chevy highout multiport FI. my mechanic found a broken return line in the aluminum intake, basally every bit of fuel the fuel pump could pump was going into the motor. it would started a little hard, and had a small hesitation when gassing it suddenly. other then that it seemed to run ok. i had just bought the van and didn't know much better. ran like a champ after it was fixed. not sure if that could be your problem but it seems like it would have to be major to drop mpg to 10. mine went from about 13 to 17-20. hope this was some help
kevreif
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: kevreif has been a member for 12 full yearskevreif has been a member for 12 full yearskevreif has been a member for 12 full yearskevreif has been a member for 12 full yearskevreif has been a member for 12 full yearskevreif has been a member for 12 full yearskevreif has been a member for 12 full yearskevreif has been a member for 12 full yearskevreif has been a member for 12 full yearskevreif has been a member for 12 full yearskevreif has been a member for 12 full yearskevreif has been a member for 12 full years
Topics: 9
Postby rev_les » December 8th 2009, 6:01am
Check your distributor gear, when they're worn it causes a random misfire, and it's a common problem on some of these engines. If you're having to gap at .060 to stop a misfire,there's another issue somewhere that you need to locate.
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full years
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby Taffy25 [OP] » December 8th 2009, 10:23am
Thanks for the replys, guess ill have to check the coil, i cant find any vacuum leaks anywhere, used a piece of hose to listen and sprayed crap loads of ez start all over anywhere that could leak, lol my gallons are bigger than yours by about a litre if i remember right so its thirsty, its the absense of black smoke thats getting me.
Taffy25
Topics: 37
Postby Leeann_93 » December 8th 2009, 11:13pm
1.2 US gallon = 1.0 Imperial gallon = 4.546 litres
Definitely check the distributor. Your gap is way to big...
Postby Taffy25 [OP] » December 10th 2009, 10:26am
Distributer has plenty of play in it, its probally the one it rolled from the factory with, looks like the problem was there before i bought it though with the plugs already being gapped that way.
Taffy25
Topics: 37
Postby astro355 » December 11th 2009, 10:29am
Taffy25 wrote:Thanks for the replys, guess ill have to check the coil, i cant find any vacuum leaks anywhere, used a piece of hose to listen and sprayed crap loads of ez start all over anywhere that could leak, lol my gallons are bigger than yours by about a litre if i remember right so its thirsty, its the absense of black smoke thats getting me.
Its only produces black smoke if the engine is running rich. It can run way lean and also give you bad fuel mileage. Point being is that you will not be able to find the problem with the plugs gapped wrong.
astro355
Postby Taffy25 [OP] » December 13th 2009, 1:09pm
Got code 42 today, ses came on so i pulled over and checked it, ses didnt light back up on the way home but the missing is getting alot worse when its cold.
Still waiting on my ohm/multimeter to arrive so i cant really check anything at the moment.
Taffy25
Topics: 37
It is currently February 26th 2021, 10:53am
Ken2.7
Date: Feb 24 '21
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Date: Feb 23 '21
Time: 8:41pm
Attached by: WinnieVan
WinnieVan
Date: Feb 23 '21
Time: 8:07am
Ken2.7
Date: Feb 22 '21
Time: 11:43pm
Users browsing this forum: Yandex [Bot] and 6 guests
