NEW in the neighbor hood (TBI issue) any ideas?
Postby slammin89safari [OP] » December 12th 2009, 11:43pm
so here i have a 89 safari 4.3 sweet ride!! other than i cant get it to run correctly..
originaly had a bit of a misfire.. which was from the stuck intake valve on NO. 5...
got that fixed ...then it ran realy rich..
so i hooked it up on the scanner.. it was rich because the CTS was bad..
then was verry picky where it wanted to run in the throttle.. so i ran it again.. GRRR.. TPS WAS BAD...
then still had a crappy o2 reading.. turns out the t-stat was bad too..and timing was way too far adv.
now with all these new parts. i have a nice clean cone shaped inj. spray..
consistant.. and appears to be responsive to the throttle when applyed anyhow. now i have also redone the exhaust...
cat was junk...
but now it idles a bit rough... and wants to die when warmed up as well when it is put in gear..
i dont know where to go from here...
im putting a video up on youtube here soon..
this thing is pretty cool though 67k on it original..
sweet iron slate int.
im going to lower it about 4-6"s on older billet 17in boyds period correct system..
sony cassete deck w/ remote and 10disc control. dennon changer old kicker 6"
in the doors for mids infinity dash and rear pillars 2 pioneer impp 12's and 2 kicker 12's
old school fosgate 150watt x2 for the subs and a toshiba 4ch for fills
its going to be freekin awesome..but i dont want to progress with any of that if i cant get it to run..
it sucks.. i can build anything metal wood or fiberglass..but when it comes to this inj. stuff im as bit lost..
once i know what im looking for i can fix it but..... theres our problem i dont know enough about these yet...
anyhow thanks guys
http://www.youtube.com/watch?v=m49-dE0nEtE
-Rich
ispyder9 at yahoo dot com
slammin89safari
Years of Membership: slammin89safari has been a member for 11 full yearsslammin89safari has been a member for 11 full yearsslammin89safari has been a member for 11 full yearsslammin89safari has been a member for 11 full yearsslammin89safari has been a member for 11 full yearsslammin89safari has been a member for 11 full yearsslammin89safari has been a member for 11 full yearsslammin89safari has been a member for 11 full yearsslammin89safari has been a member for 11 full yearsslammin89safari has been a member for 11 full yearsslammin89safari has been a member for 11 full years
  • ideas for diagnosing intermittent stall
    by osopolar » October 1st 2020, 4:07am in Engines
    October 8th 2020, 10:51pm
  • TBI Injectors,, same part for each side?
    by bowtie262 » September 11th 2020, 2:51am in Engines
    September 14th 2020, 3:45am
    7
    14
    March 9th 2021, 1:39am
Re: NEW in the neighbor hood (TBI issue) any ideas?
Postby jeff's93astro » December 13th 2009, 12:40am
check egr valve it could be sticking
95 Astro 5.3L RWD 3/3 drop
03 Suburban 5.3L 2wd 3/5 drop
jeff's93astro
Topics: 55
Images: 19
Extra Info: CS 4.3L V6 RWD
Postby slammin89safari [OP] » December 13th 2009, 6:55pm
jeff's87astro wrote:check egr valve it could be sticking
EGR is cool... i checked it moves ez...
i did more tuning lastnight..
reset timing and such.. now i can get it rollin a bit..
but i have to feather the throttle.. if i hold it steady in gear it just dies out..
but its good in Neutral or park... just runs a little rough..
if i floor it.. then it just slowly dies as if it isnt getting enough fuel.. but if i ease out of the pedal it gets a quick burst of energy then dies out again..eesh :banghead:
slammin89safari
It is currently March 9th 2021, 1:39am
OldSchoolNoe
Comments: 25
Date: Mar 07 '21
Time: 7:10pm
AppaTheAirBison
Date: Mar 06 '21
Time: 8:54pm
Attached by: MHM
MHM
Comments: 22
Date: Mar 02 '21
Time: 2:20pm
Attached by: MHM
MHM
Comments: 22
Date: Mar 01 '21
Time: 7:27pm
OldSchoolNoe
Comments: 25
Date: Mar 01 '21
Time: 12:53am
