420code
420code
Postby Cologne [OP] » December 27th 2009, 12:48pm
taking my ride into shop soon for a 420 code. What should i b aware of?
98 GMC Safari/ Cargo van AWD (200k miles) With Big AssFat Wheels = P295/50R-15 Proxes
Image cutout back of front wells + 4" bump stops.
CARBON IS THE KILLER! Know this...
Cologne
Years of Membership: Cologne has been a member for 13 full yearsCologne has been a member for 13 full yearsCologne has been a member for 13 full yearsCologne has been a member for 13 full yearsCologne has been a member for 13 full yearsCologne has been a member for 13 full yearsCologne has been a member for 13 full yearsCologne has been a member for 13 full yearsCologne has been a member for 13 full yearsCologne has been a member for 13 full yearsCologne has been a member for 13 full yearsCologne has been a member for 13 full yearsCologne has been a member for 13 full years
Topics: 27
Re: 420code
Postby evil_motors » December 27th 2009, 3:35pm
looks like your van was getting high :obscene-smokingpimp: :obscene-smokingred: :obscene-smokingsombrero: :obscene-smokingweed: :obscene-smokingjoint:
1992 GMC Safari XT , Rhinolined interior, Fatmat walls and celing, Racing seats, Satin Black Dash, Taplock, Clear Corners, Check out my continuing thread with all my mods and lots of pictures.
https://www.astrosafari.com/viewtopic.php?f=9&t=3769
evil_motors
Years of Membership: evil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full years
Topics: 26
Extra Info: XT RWD
Re: 420code
Postby rev_les » December 27th 2009, 6:52pm
bad catalytic converter. p0420 is catalytic converter efficiency below threshold. Make sure you have good fuel,no engine miss,etc. It amazes me that with no cat at all, I very rarely have that code pop up!Before you go to replacing the cat, make sure the engine's well tuned and running right.
I'd erase the code and see how long it takes to pop up again.
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full years
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Re: 420code
Postby Cologne [OP] » December 28th 2009, 4:59am
lol! Thanks for the reply u guys.
My egr & cat only have about 30K on them. But my No. 1 cyl. fouls flugs pretty fast. Im going to change it out again tomarow before i take it in. I have been fouling that plug for a long time but never got a 420 code. I always got a missfire code.
Thanks again. PS HAPPY HOLLIDAYS :)
Cologne
Topics: 27
Re: 420code
Postby Cologne [OP] » February 7th 2010, 1:51pm
Took it in to shop. They told me its the cat. ? I didnt replace it because its pretty new along with muffler. Any other ideas?
Cologne
Topics: 27
Re: 420code
Postby gtkane » February 7th 2010, 2:33pm
Every shop will tell you that it's the cat, because it is. Now you have to repair the source of the fouling plug because that is what killed the cat.
Converters never die...they are allways murdered.
User album #4...check it out!
gtkane
Alias (AKA): Astruck
Extra Info: nasty 4.3
Re: 420code
Postby astro355 » February 7th 2010, 4:52pm
gtkane wrote:Every shop will tell you that it's the cat, because it is. Now you have to repair the source of the fouling plug because that is what killed the cat.
Yep, what he said. Can you take a picture of the fouled plug?
If not, do you lose coolant or oil?
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Re: 420code
Postby Bread Van » March 21st 2010, 11:43pm
Run a couple of bottles of RXP through the system and find out what caused the fouling (actually reverse that order). I've had great luck with the RXP unless the cat is plugged or crumbling. If it's stubborn put 3 cans of RXP in a full tank of premium prior to a long trip.
Bread Van
Years of Membership: Bread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full years
Topics: 36
Alias (AKA): mapper
Extra Info: AWD 2 inch lift
Re: 420code
Postby Cologne [OP] » August 14th 2013, 12:31am
I finally found the source of all the probs Ive had. This post is pretty old and I cant remember what I did for the 420 code. But I did put a high flow cat on since this post. So that might have been the fix then. BUT! Ive learned the hard way that Carbon build up was the source of most all my problems. And it was all like domino's. One thing ruined another thing and so on and so on...
CARBON! is the killer. It fouled plugs that killed cat. It fouled EGR valve and finally clogged EGR valve intake passage on the manafold.
Ive spent over a thousand bucks on parts because of a smog device. !!!!! :screaming: :banghead:
Now just spent $1000. to have manifold cleaned up. It was a carbon garden.
Cologne
Topics: 27
It is currently February 25th 2021, 11:18am
Ken2.7
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Date: Feb 23 '21
Time: 8:41pm
Attached by: WinnieVan
WinnieVan
Date: Feb 23 '21
Time: 8:07am
Ken2.7
Date: Feb 22 '21
Time: 11:43pm
Users browsing this forum: Yandex [Bot] and 15 guests
