tdc
tdc
Postby damnadodge [OP] » June 10th 2014, 7:16pm
so the timing gear dots facing each other is number one tdc? about to put the cover on and dont want to rotate no more before plugging in the dizzy.
damnadodge
Years of Membership: damnadodge has been a member for 8 full yearsdamnadodge has been a member for 8 full yearsdamnadodge has been a member for 8 full yearsdamnadodge has been a member for 8 full yearsdamnadodge has been a member for 8 full yearsdamnadodge has been a member for 8 full yearsdamnadodge has been a member for 8 full yearsdamnadodge has been a member for 8 full years
Topics: 26
Images: 72
Van Model Year: 1990
Re: tdc
Postby damnadodge [OP] » June 10th 2014, 8:43pm
nobody knows.... would make it much easier if i knew that without a doubt the dots lined up was tdc number one
damnadodge
Topics: 26
Images: 72
Re: tdc
Postby icebrrg3rd » June 10th 2014, 9:28pm
Answered in your Stem Seal thread, what I think is both dots @ 12 o'clock is TDC firing for cyl. #1, look at the other thread to see what else I mentioned.
-Andrew
icebrrg3rd
Firing on 5 Cylinders (L3)
Topics: 49
Alias (AKA): Andrew
Van Model Year: 1991
Re: tdc
Postby damnadodge [OP] » June 10th 2014, 11:12pm
no one knows. youre kidding me right. the intake manifold is on and now i am going to have to jack up the freakin van, take off the tire and pull the number one plug (cant get the wire off, of course) just to see if i am tdc on number one. surely someone knows for sure.
damnadodge
Topics: 26
Images: 72
Re: tdc
Postby damnadodge [OP] » June 10th 2014, 11:30pm
so now i got the plug out but m finger is not long enough to reach the hole and even if i could reach i cannot see the sprockets. the hits just keep coming.
damnadodge
Topics: 26
Images: 72
Re: tdc
Postby chevymaher » June 10th 2014, 11:51pm
It isnt fun. It isnt easy. I had someone turn the engine over. Just tap tap tap. While I held a old spark plug with black tape on the end in the number one hole. Untill I heard the compression. Then I lined up the mark on the harmonic balance that just past up. And the multiplier target is there are 2 marks on the harmonic balance. The other one is for another cylinder for whatever reason.
Re: tdc
Postby Astrofarian » June 11th 2014, 12:01am
dots together is TDC on # 1 cylinder. If the covers are off, see if the valves are closed by looking @ the rocker arms...that's your valve timing. That ensures your valves open and close at the proper "time" relative to the piston's position in its stroke. Your IGNITION timing is a separate issue...drop the distributor in with the rotor pointing in the general are of #1 cyl.....move the housing back and forth until it fires....prob more to it that I am omitting but that's the basic idea. Patience...tough when you're getting close and tired/frustrated but it pays to do it once properly rather than having to redo it....which sounds like your mindset as well. Try calling out Chevymaher in Shoptalk maybe? Sorry couldn't help more....
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Re: tdc
Postby damnadodge [OP] » June 11th 2014, 1:43am
are you absolutely positive that dots facing each other is tdc #1? finally got the plug out and it seemed like compression was while both dots faced at 12 oclock.
damnadodge
Topics: 26
Images: 72
Re: tdc
Postby damnadodge [OP] » June 11th 2014, 2:46am
after extensive reading it seems that icebrrrg is right. dots facing each other is #1tdc but on the exhaust stroke. both at 12 oclock appears to be #1 compression stroke. it seems both facing each other is #4 compression stroke. thanks, anymore input would sure be helpful because i am about to adjust the valves tomorrow.
damnadodge
Topics: 26
Images: 72
It is currently November 27th 2020, 9:41am
djpigs
Comments: 41
Time: 11:23pm
Time: 12:43am
Attached by: Slime
Slime
Date: Nov 24 '20
Time: 11:11pm
K-TRON
Comments: 23
Date: Nov 16 '20
Time: 1:07am
Attached by: Devonian
Devonian
Date: Nov 13 '20
Time: 2:19am
