Problems and more problems, cranks but won't start
Postby 0dysseus [OP] » June 15th 2014, 3:05pm
Hey guys. I've had a major pain in the butt with this Van over the last month. Its a 98 RWD, with 110,000 miles. After many little things that had to be done (i picked it up cheap about 4 months ago), I had recently had fuel delivery problem while driving from FL to MA, where it crapped out on me while driving, after the next 3-4 times of this happening (always while driving and then starting up again 3-12 hours afterwards like nothing was wrong), i had a mechanic test the fuel pressure which in the diagnosis had dropped from 55 to 30, i said thanks, during the night i started it up and drove it to autozone, bought a fuel pump and put it in, problem fixed for the next 1000 miles. Now, it rained last night, it was a damp morning, i'm about to go to the beach and slam, it turns over but then immediately, rumbles and quits. This has never happened before even with the fuel pump issue- I'm really confused, what the hell is going on here? Thanks for your time, all comments sincerely appreciated
0dysseus
Years of Membership: 0dysseus has been a member for 6 full years0dysseus has been a member for 6 full years0dysseus has been a member for 6 full years0dysseus has been a member for 6 full years0dysseus has been a member for 6 full years0dysseus has been a member for 6 full years
Extra Info: 4.3 V6 RWD
  • 2000 astro stalls and now won't start
    by Tonedeft » May 3rd 2020, 2:06am in Engines
    Last post by Tonedeft View the latest post
    May 3rd 2020, 10:28pm
  • wants to turn over but wont catch the start
    by wildbluerambler » September 17th 2020, 1:37am in Engines
    September 17th 2020, 5:39am
    45
    October 27th 2020, 4:54pm
Re: Problems and more problems, cranks but won't start
Postby JPBJustin » June 15th 2014, 3:38pm
Any codes?
1997 GMC Safari - 4.3 L V-6 AWD - VIN W
JPBJustin
Years of Membership: JPBJustin has been a member for 11 full yearsJPBJustin has been a member for 11 full yearsJPBJustin has been a member for 11 full yearsJPBJustin has been a member for 11 full yearsJPBJustin has been a member for 11 full yearsJPBJustin has been a member for 11 full yearsJPBJustin has been a member for 11 full yearsJPBJustin has been a member for 11 full yearsJPBJustin has been a member for 11 full yearsJPBJustin has been a member for 11 full yearsJPBJustin has been a member for 11 full years
Images: 13
Extra Info: 4.3L V6 AWD
Postby RECox286 » June 15th 2014, 10:11pm
did the(cel, ses) light come on ? any codes set ?
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby redfury » June 15th 2014, 10:33pm
could be the connection behind the battery that is getting shorted due to the moisture in the air, it's one of the weird trouble spots electrically. If it ran great after the fuel pump, then you are having problems when the moisture level rises, then you have a problem with a connection somewhere. One thing to check would be to do a resistance check on the coil, just to rule that out.
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Extra Info: LT 5.7L 4wd
Postby CreepiE » June 21st 2014, 3:47am
My 99 GMC Safari has been doing the same thing....all winter it was fine, now rain, humidity etc. Gonna check the distributor cap and rotor for moisture, then the coil....
CreepiE
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: CreepiE has been a member for 11 full yearsCreepiE has been a member for 11 full yearsCreepiE has been a member for 11 full yearsCreepiE has been a member for 11 full yearsCreepiE has been a member for 11 full yearsCreepiE has been a member for 11 full yearsCreepiE has been a member for 11 full yearsCreepiE has been a member for 11 full yearsCreepiE has been a member for 11 full yearsCreepiE has been a member for 11 full yearsCreepiE has been a member for 11 full years
Topics: 21
Location: So close to Wisconsin I can smell the Cheese!
Extra Info: 4.3L V6 Cargo
Postby The Drummer » June 21st 2014, 4:06am
yep what he said , cap and rotor ,did it on mine this spring , also had the coolent sensor go bad , had to floore it to start cause sensor was saying minus 40 instead of embient temperatur ,otherwise it would crank but not start .
''USE THE TORQUE LUKE ''
and beware of trees ,them nasty wooden things are evil .
The Drummer
Years of Membership: The Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full years
Topics: 16
Images: 42
Extra Info: SLT 4.3 AWD
Postby Canyonero » June 21st 2014, 4:08am
I've had similar issues a few times… Sounds like no spark….
The ignition system is prone to moisture. Last time for me, it was the coil shorting out after a rain.
a new coil helped…. new plug wires and plugs really helped, better starts, better MPG, more power and smoother idle.
While you're in there, cap and rotor is always a good idea.
Canyonero
Years of Membership: Canyonero has been a member for 6 full yearsCanyonero has been a member for 6 full yearsCanyonero has been a member for 6 full yearsCanyonero has been a member for 6 full yearsCanyonero has been a member for 6 full yearsCanyonero has been a member for 6 full years
Topics: 30
Van Model Year: 2002
Extra Info: LT 4.3 V6 AWD
Postby CreepiE » June 21st 2014, 3:55pm
Went to local NAPA and picked up new cap and rotor. Said there is a TSB regarding issues. One is A/C line runs over distributor and condensates, introducing moisture. Also, drill out weep ports in distributor as they become clogged.
CreepiE
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 21
Postby RECox286 » June 21st 2014, 8:05pm
Does it want to start if you spray go juice (ether) down the intake ?
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Postby CreepiE » June 22nd 2014, 1:16am
No go on the cap, rotor, or coil. Is there a ground for the injectors? It acts like a loose ground....maybe?
CreepiE
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 21
Postby markmitchmarkmitch is online! » June 22nd 2014, 2:55am
spray some wd 40 inside the cap and wipe it out this will stop condensation inside the cap.
Old mudders trick. Just a thought my van is gen one so I have no clue on gen 2s
Firing on 5 Cylinders (L6)
Topics: 608
Images: 20
Extra Info: RS V8
Postby Herman Wiegman » June 22nd 2014, 3:39am
Odesseus,
A bunch of good advice so far... the harness area behind the battery, the cap n' rotor, plug wires, ignition circuit.
Are you dead sure it was due to the moisture? Have you tried starting the van after some dryer weather?
You could always run around with a blow torch or hair dryer and try removing moisture and see if that helps.
Or alternately, run around with a spray bottle and see if moisture stops your van from running.
Otherwise,
did the rain run into your tank? (poor gas quality, try starter fluid right down the intake tube)
is there spark? (put a timing light on the main wire to the distributor)
is there air flow? (both input and output/exhaust)
is the engine mechanically ok? (compression check, any funky noises? low on coolant? )
Herminator
Herminator, Niskayuna, NY.......1999 Safari 4.3L SLE (RWD)
Eaton Gov Lok LSD 3.23:1.........Timbren bump stops
Monster 4L60E rebuild ..............Electric fan & FelPro gaskets
10922
Herman Wiegman
Years of Membership: Herman Wiegman has been a member for 7 full yearsHerman Wiegman has been a member for 7 full yearsHerman Wiegman has been a member for 7 full yearsHerman Wiegman has been a member for 7 full yearsHerman Wiegman has been a member for 7 full yearsHerman Wiegman has been a member for 7 full yearsHerman Wiegman has been a member for 7 full years
Images: 89
Alias (AKA): Herminator
Extra Info: 4.3L RWD
It is currently October 27th 2020, 4:54pm
AstroTan
Date: Oct 21 '20
Time: 8:02pm
Attached by: Sparkydog
Sparkydog
Comments: 13
Date: Oct 20 '20
Time: 4:01pm
Sparkydog
Comments: 0
Date: Oct 13 '20
Time: 8:49pm
Comments: 61
Date: Oct 09 '20
Time: 2:58am
hankheat
Date: Oct 07 '20
Time: 6:30pm
Users browsing this forum: Yandex [Bot] and 33 guests
