first post-'95 Astro running rough
Postby Need For Steve [OP] » January 27th 2010, 8:28am
first of all, it's good to be here! lookin' forward to gettin' to know you guys, and gettin' my old Man-van back on the highway :D
so yea, i have a '95 Astro that's been sitting for most of about 2.5 years; it was mine when i first got my license back in '06 and i parked it a year later when i got my Camaro, but that's another story :). for maybe a year or so before i received it, we had begun to experience an intermittent condition during which the van would idle a bit rough, and produce a bit of moisture from the exhaust as if it were running rough. under load and on the road, it would feel a bit down on power, and mileage suffered. it wouldn't do this all the time, just every now and then. we suspected everything from a timing issue to ignition or fuel system problems, but neither me nor my dad had the expertise or idealism to dig into this thing back then and find the problem. other than this, we've never had any other problem from the motor other than regular maintainance, just an average trooper Vortec.
well, this "rough running" issue intermittently continued, until, after i received it and had been driving it a while under normal conditions, it began to get worse. it began to run raggedy more often. sometimes it would be running perfectly fine when you shut it off, and upon restarting either hot or cold, it would sound like it was God-Awful sick. for a while it would only do it between starts, but later it would begin to "change" conditions while on the highway or at a stop light. it was really wierd, actually. you could kind of "feel" it when it went from running perfectly smooth (it still purrs like a fuzzy kitten when it wants to) to raggedy. it would be like a sudden change.
when the motor's in this "rough" condition, it feels very sluggish. it takes a good bit of motivation from the pedal to get any movement, even then it just sort of lunges ahead. but then, as soon as it came, the condition can just clear up, and literally like the flip of a coin, the exhaust note smooths out and the "shutter" calms to a restful purr. i'm stumped. it's the only problem we've ever had or are having with this motor, even after it sitting so long.
on to today, me and a friend of mine decided to start the old dog after class. we go out, hook up the cables, and after lettin' her sit for about 10 minutes, a few turns of the key (turned out to be a bad ground issue) and she fires right up just as pretty. idles nice and quiet with no engine noises at all, revs smooth. this engine is deff a keeper. we turn the van around and pull her into my yard, comes to a stop and it dies (once again, that dang ground). after failed jumping attempts and fixing the a-formentioned ground issue, she fires. what do ya know? it sounds rough. really rough. something i did notice after firing it again was a "ticking" sound coming from what seemed like the distributor area (i had the interior engine cover removed). it wasn't there 20 minutes before when the motor was running smooth, and after running for about 15 minutes the engine decided to smooth out, and the mysterious "tick" went away. hmmm...i'm wondering if it may be either A) a timing/ignition issue, or B) an injector issue, though i've never heard injectors tick loud enough to hear. i have a strange feeling this tick may be the key in figuring out what's going on. i mean, if it's an ignition or timing issue, then it would run raggedy right? almost as if it were running rather rich?
sorry for the long post guys, but i'm hoping someone can help me. all that stands between my old van and driving again are the lack of 3rd and 4th gear, and THIS engine issue. thanks in advance, guys!
Hey Hey, just call me Steve!
'95 Astro Extended Sport, 4.3, 3.23's, Glasspack exhaust, "the project"
'94 Buick Lesabre Limited 3.8 series I, the DD
Need For Steve
Years of Membership: Need For Steve has been a member for 11 full yearsNeed For Steve has been a member for 11 full yearsNeed For Steve has been a member for 11 full yearsNeed For Steve has been a member for 11 full yearsNeed For Steve has been a member for 11 full yearsNeed For Steve has been a member for 11 full yearsNeed For Steve has been a member for 11 full yearsNeed For Steve has been a member for 11 full yearsNeed For Steve has been a member for 11 full yearsNeed For Steve has been a member for 11 full yearsNeed For Steve has been a member for 11 full years
Alias (AKA): Steve
Extra Info: CS 4.3L RWD
  • Best route? Buy it pre-fixed, or buy it post-fixed?
    by Vander » January 5th 2021, 11:43pm in Engines
    January 6th 2021, 10:13pm
  • 2003 Astro seems to be running fine except
    by markmitch » October 18th 2020, 3:34pm in Engines
    October 19th 2020, 10:08pm
    76
    March 7th 2021, 12:39pm
Re: first post-'95 Astro running rough
Postby Big_kid » January 27th 2010, 2:10pm
Welcome aboard!
Anybody else thinking it's time to check the IAC and EGR? (do we even have an IAC in our vans?)
:chevy:
Firing on 7 Cylinders (L7)
Topics: 185
Images: 342
Extra Info: 2WD 5.7 V8
Postby honeycut33 » January 27th 2010, 2:19pm
Hello is there any codes that is making the engine light stay on. The automatice timing adjustment feature could be causeing the timing to jump in and out . Every astro that my family has ever had has had a miss and rough idle but ran strong on the road with plenty of power. My daughters 95 has a miss but runs out real strong and it has over 201,000 on it.
honeycut33
Years of Membership: honeycut33 has been a member for 11 full yearshoneycut33 has been a member for 11 full yearshoneycut33 has been a member for 11 full yearshoneycut33 has been a member for 11 full yearshoneycut33 has been a member for 11 full yearshoneycut33 has been a member for 11 full yearshoneycut33 has been a member for 11 full yearshoneycut33 has been a member for 11 full yearshoneycut33 has been a member for 11 full yearshoneycut33 has been a member for 11 full yearshoneycut33 has been a member for 11 full years
Postby Need For Steve [OP] » January 27th 2010, 8:18pm
hmm, i can see the automatic timing adjustment thingy. i gassed 'er up and let her run today for about 15 minutes. when she first started it ran smooth, but after running for about 5 minutes the idle went rough and the shake came back. i noticed there's a good bit of moisture coming from the exhaust, and the exhaust aroma is very strong. looking at it now, it seems to me like it's just running very rich. the cause is what's up, but it seems that the "condition" is rich running.
any ideas on what could cause an intermittent rich mixture?
Need For Steve
Alias (AKA): Steve
Postby astroturf » January 27th 2010, 10:34pm
Man, that has gotten to be the longest first post I've ever seen. Hope you get it fixed, and WELCOME to the forum. Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby Mr_Bowtie » January 27th 2010, 11:06pm
astroturf wrote:Man, that has gotten to be the longest first post I've ever seen. Hope you get it fixed, and WELCOME to the forum. Jim
X2 :rofl:
Welcome! :rockon:
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Van Model Year: 1985
Extra Info: 350 with 700r4
Postby jeff's93astro » January 27th 2010, 11:46pm
Welcome :thumbup:
95 Astro 5.3L RWD 3/3 drop
03 Suburban 5.3L 2wd 3/5 drop
jeff's93astro
Topics: 55
Images: 19
Extra Info: CS 4.3L V6 RWD
Postby Need For Steve [OP] » January 28th 2010, 2:02am
hahaha, sorry man. i just get so tired of folks showing up on forums with problems, and their first post is always "hey first post. car won't start! fix it for me! ahhH!" lol, figured i'd give some detailed info :D
and thanks for the welcomeZ! :banana:
oh, something that came to mind while i was out with the van earlier...i've heard that a worn distributor shaft can cause a rough running/ignition issue. i'm wondering if the mechanical "tick" sound i'm hearing is maybe the cam gear grinding on the shaft, or some problem with the shaft or inner workings of the distributor itself. after all, it's got 206K miles on it...makes sense if it's let go
Need For Steve
Alias (AKA): Steve
Postby Need For Steve [OP] » January 28th 2010, 2:58am
DOH! i completely missed the question about the CEL. there is NO CEL present at this time, so i guess that means whatever the problem is, isn't something that would set a light...does that narrow it down at all? :think:
Need For Steve
Alias (AKA): Steve
Postby Need For Steve [OP] » January 29th 2010, 10:50pm
ok, good news is i pulled the IAC, cleaned it up and got the idle smoothed out.
bad news is i took 'er out on the road to test the 3-4 clutches and i got an egr fault AND egr FAIL code...eff!
Need For Steve
Alias (AKA): Steve
It is currently March 7th 2021, 12:39pm
AppaTheAirBison
Time: 8:54pm
Attached by: MHM
MHM
Comments: 22
Date: Mar 02 '21
Time: 2:20pm
Attached by: MHM
MHM
Comments: 22
Date: Mar 01 '21
Time: 7:27pm
Ken2.7
Date: Feb 24 '21
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
