Proper operating temp 2003
Postby astroman97 [OP] » August 9th 2014, 3:31am
astroman97 wrote:My 2003 seems to run at 100 Celsius all the time hot IMHO...my 97 and 98 run just above 40-60...I figured the rad was plugged or clutch fan were not working correctly so I swapped it them with the 98 and installed a new thermostat everything but water pump...still runs at 100 was thinking a lower temp thermostat as mentioned ..as I will be replacing the transmission soon (heat is not a transmissions friend) would love to see it run cooler any other suggestions? :confused:
astroman97
Years of Membership: astroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full years
Topics: 78
Images: 2
Extra Info: Also 97 both 2wd
Re: Proper operating temp 2003
Postby Leeann_93 » August 9th 2014, 3:36am
That's better ;)
Now, 100°C is approx 212°F, which is the normal operating range for these engines. The thermostats are 195°, but they don't actually start to open until that and aren't fully open until 205°-210°. So this van is running completely normal. Your other vans are actually running a bit cool, which will help the engine build up carbon deposits and run a little less efficiently.
As for your transmission, if you regularly haul heavy loads or tow, definitely add a tranny cooler.
Now if the temp starts climbing above 100°C, you've got a problem.
Postby astroman97 [OP] » August 9th 2014, 3:45am
Def transmission cooler will be added when the rebuild goes in....guess I was thinking the 100temp contributed to the transmission failure ...though not completely gone yet def notice it less responsive than the 97 with a rebuilt transmission less than 10k ago..I just touch the gas and it lays rubber..the 2003 seems to sorta over rev a touch as it would with transmission slip ..thinking that would be where the loss of HP would be too?
astroman97
Topics: 78
Images: 2
Postby Corsemoto » August 9th 2014, 3:56am
Corsemoto wrote:Wow, blast from the past!
Since then I've replaced fan clutch and with Jet Programmer plugged in, it shows temp is right around 200° or so even though the dash gauge reads higher so nothing to worry about.
I should add, I've also done a full cooling system flush/fill, new radiator, hoses, thermostat and transmission cooler.
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
It is currently March 7th 2021, 12:34pm
AppaTheAirBison
Time: 8:54pm
Attached by: MHM
MHM
Comments: 22
Date: Mar 02 '21
Time: 2:20pm
Attached by: MHM
MHM
Comments: 22
Date: Mar 01 '21
Time: 7:27pm
Ken2.7
Date: Feb 24 '21
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Users browsing this forum: Google [Bot] and 12 guests
