dtc 13. volt readings. o2 part #
Postby norway_astro [OP] » August 11th 2014, 11:13pm
Hi . I got dtc 13 on my astro . I belive this code was "no conection to o2 sensor . My wire from o2 to ecm is ok. And when i start up the car the o2 sensor makes 0.121 volts and climbing ..
What value should i have when its ok?
I read there is diffrent o2 sensors , wich one should i get if i need one ?
norway_astro
Years of Membership: norway_astro has been a member for 6 full yearsnorway_astro has been a member for 6 full yearsnorway_astro has been a member for 6 full yearsnorway_astro has been a member for 6 full yearsnorway_astro has been a member for 6 full yearsnorway_astro has been a member for 6 full years
Van Model Year: 1991
Extra Info: 4.3
Re: dtc 13. volt readings. o2 part #
Postby Lumpy » August 12th 2014, 8:28am
First, verify that you really need one.
Reset your ECM by disconnecting the battery for a couple minutes, then re-connect. Then check codes, then drive it around for 20-30 miles, check codes again.
It grounds through the bung that it's screwed in to on the Y pipe. Make sure it's clean and seated. And make sure your Y pipe is well grounded.
Replace it, if needed, with whatever the LAP shows as appropriate for your year van. I think you have only one O2 sensor, UPstream of the CAT. They always want to know "Is it upstream or downstream of the cat?".
Postby norway_astro [OP] » August 13th 2014, 8:09pm
resetting didnt help.
yeas i only have one , didnt see any ground wire on the exhaust , but i meashured good connection to the ground . i will add a jumpcable to test if theres any diffrence .
any one have the part # for the o2 ?
norway_astro
Extra Info: 4.3
It is currently August 5th 2020, 7:19am
pmou
Comments: 38
Date: Jul 30 '20
Time: 3:31am
pmou
Comments: 38
Date: Jul 29 '20
Time: 11:58pm
Attached by: tonydobbs
tonydobbs
Date: Jul 29 '20
Time: 5:41pm
pmou
Comments: 38
Date: Jul 21 '20
Time: 7:13pm
pmou
Comments: 38
Date: Jul 20 '20
Time: 11:50pm
Users browsing this forum: Google [Bot] and 4 guests
