Does anyones astro.......
Postby slidewayz89 [OP] » February 13th 2010, 7:47am
KInda buck when you first drive it like at a constant speed almost idle 25-40 mph mines does cant figure out why after like 30 minutes of driving it runs just fine WTF!!!
slidewayz89
Years of Membership: slidewayz89 has been a member for 10 full yearsslidewayz89 has been a member for 10 full yearsslidewayz89 has been a member for 10 full yearsslidewayz89 has been a member for 10 full yearsslidewayz89 has been a member for 10 full yearsslidewayz89 has been a member for 10 full yearsslidewayz89 has been a member for 10 full yearsslidewayz89 has been a member for 10 full yearsslidewayz89 has been a member for 10 full yearsslidewayz89 has been a member for 10 full years
Topics: 5
  • Where does this spring go?!
    by Cjn115 » June 30th 2020, 10:30pm in Engines
    Last post by augidog View the latest post
    September 10th 2020, 4:24pm
  • Problems with Astro van 1991 wont keep running
    by Astro1991noob » April 14th 2020, 7:20pm in Engines
    April 14th 2020, 8:44pm
    26
    October 1st 2020, 4:31am
Re: Does anyones astro.......
Postby astro355 » February 13th 2010, 8:10am
I assume that it is not setting any codes.
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby Astroplane » February 13th 2010, 8:11am
Last tune-up? Sounds like ignition coil shorting to the mounting bracket, distributor cap, or single cylinder misfire. How long has this been happening? Does it get worse when it is wet outside?
Astroplane
Blue Status (L2)
Blue Status (L2)
Years of Membership: Astroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full years
Extra Info: LT RWD
Postby astro355 » February 13th 2010, 8:20am
Astroplane wrote:Last tune-up? Sounds like ignition coil shorting to the mounting bracket, distributor cap, or single cylinder misfire. How long has this been happening? Does it get worse when it is wet outside?
If his symptom lasted permanently, I would think that.
But it goes away after about 30 minutes. I have never seen an ignition misfire that went away like that. How long does it take the van to warm up? Usually with an engine that surges, I looking for a vacuum leak (or a component used to control or monitor vacuum leaks and/or air flow). Possibly the ever failing IAC?
astro355
Postby slidewayz89 [OP] » February 13th 2010, 8:29am
Okay there is no codes and what is an iac???
slidewayz89
Topics: 5
Postby Astroplane » February 13th 2010, 8:46am
30 minutes should be plenty of time for the engine to reach operating temperature, especially driving on the road. I'm thinking 'buck' is felt in the drivers' seat more than 'surge'. I'm also assuming that this happens at a lower rpm right after a shift and engine load is more.
Astroplane
Blue Status (L2)
Blue Status (L2)
Extra Info: LT RWD
Postby slidewayz89 [OP] » February 13th 2010, 8:54am
exactly man lower rpm almost idle cruising speed
slidewayz89
Topics: 5
Postby Astroplane » February 13th 2010, 9:00am
slidewayz89 wrote:Okay there is no codes
How about misfire history?
slidewayz89 wrote:what is an iac???
Idle Air Control
Astroplane
Blue Status (L2)
Blue Status (L2)
Extra Info: LT RWD
Postby Astroplane » February 13th 2010, 9:05am
Does it do this worse during damp conditions or does it seem like a timer goes off right at the 30 minute mark every time?
Astroplane
Blue Status (L2)
Blue Status (L2)
Extra Info: LT RWD
Postby slidewayz89 [OP] » February 13th 2010, 9:31am
no exact time just after a long while it stops
slidewayz89
Topics: 5
Postby astro355 » February 13th 2010, 7:23pm
Astroplane wrote:30 minutes should be plenty of time for the engine to reach operating temperature, especially driving on the road. I'm thinking 'buck' is felt in the drivers' seat more than 'surge'. I'm also assuming that this happens at a lower rpm right after a shift and engine load is more.
Absolutely, 30 minutes should be plenty of time for any engine to warm up but the OP still has not answered that question.
astro355
Postby Gus_Mahn » February 14th 2010, 5:24pm
If it were mine, I'd put a GM cap and rotor on it along with a PCV valve and fuel filter into it and see if it improves. You could also remove the doghouse and lightly spray the cap, wires, and coil with water to look for spark leakage. It will be more visible if you test it at night. Any visible spark mean that that component must be changed.
Gus_Mahn
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: Gus_Mahn has been a member for 11 full yearsGus_Mahn has been a member for 11 full yearsGus_Mahn has been a member for 11 full yearsGus_Mahn has been a member for 11 full yearsGus_Mahn has been a member for 11 full yearsGus_Mahn has been a member for 11 full yearsGus_Mahn has been a member for 11 full yearsGus_Mahn has been a member for 11 full yearsGus_Mahn has been a member for 11 full yearsGus_Mahn has been a member for 11 full yearsGus_Mahn has been a member for 11 full years
Topics: 10
It is currently October 1st 2020, 4:31am
hankheat
Time: 2:53pm
bradyalderin
Time: 1:53pm
Attached by: Sparkydog
Sparkydog
Date: Sep 29 '20
Time: 3:38pm
stentstent is online!
Comments: 60
Date: Sep 28 '20
Time: 11:32pm
bradyalderin
Date: Sep 27 '20
Time: 11:43pm
Users browsing this forum: No registered users and 24 guests
