Swapping vortec 4.3 into a non vortec 4.3 engine bay
Postby akforceten [OP] » September 7th 2014, 5:03am
Ok I have acquired a 1995 GMC safari awd van with a bad motor. I also acquired a 1996 vortec 4.3 L motor in good shape.it has 185-190 compression an oil psi was 30 to 70.i got the harness an computer with trans . since the 95 is non vortec van i need to figure out how to mate the 96 harness to the 95 van so the search is on for wiring diagrams i guess
98638 100250
akforceten
Years of Membership: akforceten has been a member for 11 full yearsakforceten has been a member for 11 full yearsakforceten has been a member for 11 full yearsakforceten has been a member for 11 full yearsakforceten has been a member for 11 full yearsakforceten has been a member for 11 full yearsakforceten has been a member for 11 full yearsakforceten has been a member for 11 full yearsakforceten has been a member for 11 full yearsakforceten has been a member for 11 full yearsakforceten has been a member for 11 full years
Topics: 32
Images: 128
Alias (AKA): akforceten
Extra Info: SLE 4x4 7 inch lift
  • Non-Splice Fuel Pump (It's a Bosch)
    by OldSchoolNoe » February 16th 2021, 7:39am in Engines
    March 11th 2021, 10:58pm
  • 1998 astro stalling issue, engine codes
    by dougzooka » November 28th 2020, 4:13am in Engines
    Last post by ptysiek View the latest post
    November 28th 2020, 5:22pm
    83
    April 22nd 2021, 9:51pm
Re: Swapping vortec 4.3 into a non vortec 4.3 engine bay
Postby chevymaher » September 7th 2014, 3:05pm
Wow you sure like doing things the hard way. 95 is a vortec 1st design.
If the 95 had block problems and not head issues. Easiest solution is put the 95 heads and intake on the 96 block and just put it in.
To wire the van for the 96 engine you need the wiring and computer. And as a added bonus your transmission will no longer work. You would need a 96 trans.
Topics: 91
Postby akforceten [OP] » September 7th 2014, 4:02pm
yea I'm a gluten for punishment. well the 95 motor has a cracked head so swapping heads is not happening . i do have the wiring an computer and trans from the 96 . this has been a leaning experiment
98638 100250
akforceten
Topics: 32
Images: 128
Postby T.Neff » September 7th 2014, 4:26pm
Get the factory service manuals for both yrs off of Ebay.Your going to need the electrical supplement manual for both yrs as well.
T.Neff
Years of Membership: T.Neff has been a member for 9 full yearsT.Neff has been a member for 9 full yearsT.Neff has been a member for 9 full yearsT.Neff has been a member for 9 full yearsT.Neff has been a member for 9 full yearsT.Neff has been a member for 9 full yearsT.Neff has been a member for 9 full yearsT.Neff has been a member for 9 full yearsT.Neff has been a member for 9 full years
Topics: 21
Postby akforceten [OP] » September 14th 2014, 2:13am
Well i have made progress in making a stand alone harness. I have gotten all battery power leads figured out an the keyed on ignition power sources so the fuse block that is under the hood has complete power. The next task is to test it an see if everything will start an run.
98638 100250
akforceten
Topics: 32
Images: 128
It is currently April 22nd 2021, 9:51pm
Time: 1:09am
Comments: 13
Date: Apr 17 '21
Time: 9:03pm
Comments: 13
Date: Apr 16 '21
Time: 6:08pm
kvargas1356
Date: Apr 11 '21
Time: 10:20pm
Attached by: jfunkngroove
jfunkngroove
Comments: 17
Date: Apr 10 '21
Time: 10:38pm
Users browsing this forum: No registered users and 21 guests
