hard starts
hard starts
Postby dpurdee [OP] » September 17th 2014, 9:57pm
hi all, i have an 02 astro lt trim 2wd. van does not start without having to pump gas.
After starting and drivin to run errands it starts fine and runs like a champ.. but once it sits for a day or two it will not start unless i pump accelerator. it turns over fine and when key is in the on position i hear the whirling of fuel pump for about 2 seconds. so far i've changed fuel filter but problem still continues. anyone here have the same problem and care to share information? im all ears.
dpurdee
Years of Membership: dpurdee has been a member for 6 full yearsdpurdee has been a member for 6 full yearsdpurdee has been a member for 6 full yearsdpurdee has been a member for 6 full yearsdpurdee has been a member for 6 full yearsdpurdee has been a member for 6 full years
Van Model Year: 2002
Extra Info: lt 4.3l v6 rwd
  • Hard Cold Start and Rough Idle. No Codes. Diagnosis?
    by AstroTan » October 17th 2020, 5:26am in Engines
    Last post by AstroTan View the latest post
    December 31st 2020, 5:53pm
    March 1st 2021, 6:03pm
Re: hard starts
Postby Leeann_93 » September 17th 2014, 11:20pm
You need to check fuel pressure at the schrader valve on the back of the driver's side head.
KOEO (Key On, Engine Off), what is your fuel pressure? What is it 10 mins later?
Now try it again….and again. Is it consistent? Is it the same when the engine is hot as when it's cold?
Re: hard starts
Postby dpurdee [OP] » September 18th 2014, 1:31am
Thanks for info. I will check fuel press. Drove it to work today, and at end of my shift it staryed rite up no problem and I'm sure engine was cold. But if I let it sit couple days then I have the no start problem. So I'm guessing I have to find out what's making it lose fuel pressure.
dpurdee
It is currently March 1st 2021, 6:03pm
Ken2.7
Date: Feb 24 '21
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Date: Feb 23 '21
Time: 8:41pm
Attached by: WinnieVan
WinnieVan
Date: Feb 23 '21
Time: 8:07am
Ken2.7
Date: Feb 22 '21
Time: 11:43pm
Users browsing this forum: Google [Bot], MHMMHM is online! and 22 guests
