Fuel pump problems??
Postby 1992RS [OP] » March 2nd 2010, 7:25am
Well as alot of you know I have been having alot of problems with my astro :banghead: Well I got a little bit of extra cash to throw at it so I went out to the garage to see if I could start her up and do a little diagnosing work. But to my dismay she wont start and from what I can figure it is caused by the fuel pump as when i hit the key the fuel pump is making an awful racket sounds almost like a broken plastic gear grinding against another one, I dont know if there is in fact any thing in there like that but i cant even get a cough out of the engine now so i am assuming when I thought my fuel lines were frozen it may have damaged something in my fuel pump causing it to provide insufficient pressure to the injector(s) i tried it about ten times and didnt even get the faintest wiff of raw fuel from the intake or exhaust. so its time for a new pump or what?? :screaming:
Also previously when i tested fuel pressure with the key on engine off it would get 55psi most the time it would hold there but other times it would go from 55 to 0 in a matter of a few seconds? that i am assuming could be a stick injector or bad pressure reg right
1992 Astro RS
174,000 miles
Rebuilt top end
stock tranny
1992RS
Years of Membership: 1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years
Topics: 38
Alias (AKA): tony
Extra Info: RS 4.3v rwd
  • 94 Astro no start after fuel pump install
    by grimbeardsly » June 7th 2020, 1:16pm in Engines
    Last post by grimbeardsly View the latest post
    June 21st 2020, 2:18am
  • No start after new fuel pump
    by Mberry0614 » June 19th 2020, 5:21pm in Engines
    June 24th 2020, 10:29pm
    43
    November 28th 2020, 1:01pm
Re: Fuel pump problems??
Postby Astroplane » March 2nd 2010, 8:28am
1992RS wrote:it would go from 55 to 0 in a matter of a few seconds
The pressure has to be going somewhere fast. Unless you have had an issue with fuel fouled plugs or raw fuel smell, my bet is the check valve in the pump. Due to this frozen line issue, if you wind up replacing the pump, flush pressure line, replace filter, and check the return line to the tank before installing a new pump. If it is blocked, it could cause the new pump to fail. If this van will start or try to start with starting fluid, then the injector and regulator are probably OK. Keep the pressure gauge hooked up once you put the new pump in and make sure that initial pressure does not spike way past spec.
Astroplane
Blue Status (L2)
Blue Status (L2)
Years of Membership: Astroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full years
Extra Info: LT RWD
Postby 1992RS [OP] » March 2nd 2010, 9:34am
Well, I definately plan on swapping the pump, do you know where to find an affordable one??
I havent tried shooting in any starting fluid yet but that is now on my list of things to try next. It seems like when i turn on the key or after i try to start it the pump runs for about fifteen seconds to prime the system which before it was like 2-3 then it was 5-7 and so on til now it wont start. also dont know if this makes a difference but when i would be hard on the gas from a dead stop at say a light it almost felt as if it had no power like a 0-30 mph of like 10-12 seconds
1992 Astro RS
174,000 miles
Rebuilt top end
stock tranny
1992RS
Topics: 38
Alias (AKA): tony
Postby 1992RS [OP] » March 5th 2010, 6:25am
Well, I ordered my fuel pump from www.rockauto.com today so hopefully by the end of the weekend I will have my baby running again, its wierd I either hate it or love it, Astro's have that effect on people I guess.
1992 Astro RS
174,000 miles
Rebuilt top end
stock tranny
1992RS
Topics: 38
Alias (AKA): tony
Postby Astroplane » March 5th 2010, 8:08am
Once you have the old pump out, use a flashlight and take a good look inside the tank. Remove any water or debris. If fuel quality is in doubt, drain tank completely and use new fuel.
Astroplane
Blue Status (L2)
Blue Status (L2)
Extra Info: LT RWD
Postby 1992RS [OP] » March 5th 2010, 10:14am
You know I never would have thought to look in the tank, the last three times i have done a tank mostly on sables/taurus' i always was putting in a replacement so never checked. thanks for the tip
1992 Astro RS
174,000 miles
Rebuilt top end
stock tranny
1992RS
Topics: 38
Alias (AKA): tony
Postby astroturf » March 5th 2010, 11:50am
Which pump did you order from RockAuto? Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby astro355 » March 5th 2010, 4:27pm
What makes you think that the fuel lines were frozen in the first place? If they were frozen, you should never have read any pressure.
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby 1992RS [OP] » March 6th 2010, 5:43am
I ordered a cheapy, I know I shouldnt have but its what I could afford. The reason I thought the lines were froze was that it all the sudden would not start and it had been sitting in sub-zero weather for about 1.5 months with less than a eigth of a tank of gas so I assumed frozen lines especially when I ran my heater in the garage for a few hours it would sputter. but not start only try then die. so I figured oops I let the line freeze up.
1992 Astro RS
174,000 miles
Rebuilt top end
stock tranny
1992RS
Topics: 38
Alias (AKA): tony
It is currently November 28th 2020, 1:01pm
djpigs
Comments: 42
Date: Nov 26 '20
Time: 11:23pm
Date: Nov 26 '20
Time: 12:43am
Attached by: Slime
Slime
Date: Nov 24 '20
Time: 11:11pm
K-TRON
Comments: 23
Date: Nov 16 '20
Time: 1:07am
Attached by: Devonian
Devonian
Date: Nov 13 '20
Time: 2:19am
