temp not working after swap
Postby 86shorty [OP] » March 9th 2010, 3:41am
Ok here goes.
I have a real nice 86 shorty cargo, the motor went so I found a 91 4.3 for a 100.00 and did the swap. turns out the new motor runs great but I have no temp gauge. I went through the steps out lined in the manual and even replaced the sending unit but still no workee.
any suggestions ??
Cheers
Brian
86shorty
Years of Membership: 86shorty has been a member for 11 full years86shorty has been a member for 11 full years86shorty has been a member for 11 full years86shorty has been a member for 11 full years86shorty has been a member for 11 full years86shorty has been a member for 11 full years86shorty has been a member for 11 full years86shorty has been a member for 11 full years86shorty has been a member for 11 full years86shorty has been a member for 11 full years86shorty has been a member for 11 full years
Alias (AKA): Brian
Re: temp not working after swap
Postby Astroplane » March 9th 2010, 6:06am
Which year sender did you use? This is on the drivers' cylinder head, correct?
Astroplane
Blue Status (L2)
Blue Status (L2)
Years of Membership: Astroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full years
Extra Info: LT RWD
Postby 86shorty [OP] » March 9th 2010, 7:01am
Yes thats the one
86shorty
Alias (AKA): Brian
Postby Astroplane » March 9th 2010, 7:35am
OK. I was wondering if the replacement sender is compatible with the gauge. When you replaced the sender, was it from the original motor? From the new motor? From the parts store?
Astroplane
Blue Status (L2)
Blue Status (L2)
Extra Info: LT RWD
Postby 86shorty [OP] » March 9th 2010, 7:46am
Yup the first sender was swapped over from the old motor, so I went to parts store and got a new one. the only difference was the way the wire hooked up it had a diff end but the guy at the store assured me that they are the same.
86shorty
Alias (AKA): Brian
Postby 86shorty [OP] » March 9th 2010, 7:51am
I should mention that the 91 motor didn't have same sensor, it looks like the one for that one is in one of the frost plugs.
86shorty
Alias (AKA): Brian
Postby 86shorty [OP] » March 9th 2010, 8:00am
here's a pic
86shorty
Alias (AKA): Brian
Postby 86shorty [OP] » March 9th 2010, 8:11am
And here;s the old one
86shorty
Alias (AKA): Brian
Postby Astroplane » March 9th 2010, 8:20am
I'm pretty sure the one in the pic is a block heater. The sender I'm talking about is a single wire. Located above that pic on the cylinder head between the spark plugs.
Astroplane
Blue Status (L2)
Blue Status (L2)
Extra Info: LT RWD
Postby Astroplane » March 9th 2010, 8:22am
Exactly. The second pic is the temp gauge sending unit. Now we are on the same page. Good pics!
Astroplane
Blue Status (L2)
Blue Status (L2)
Extra Info: LT RWD
Postby astro355 » March 9th 2010, 6:26pm
Astroplane wrote:Exactly. The second pic is the temp gauge sending unit. Now we are on the same page. Good pics!
Yeah, what he said. Any chance there is corrosion on the connector? Did you try unplugging and replugging it?
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby 86shorty [OP] » March 9th 2010, 7:08pm
That was the sender that I changed, so its brand new and has a new connector as well
B
86shorty
Alias (AKA): Brian
Postby astro355 » March 9th 2010, 7:14pm
Did any part of the wiring harness get snagged or damaged during the removal or installation?
Did you measure the ohms of the sensor or the continuity of the sensor wire?
astro355
Postby 86shorty [OP] » March 10th 2010, 1:35am
Ok guys just for fun I went and bought a after market temp gauge, hooked it up to the new sensor and every thing works !!! hmmmm I think maybe its a ground problem.
Shorty......
86shorty
Alias (AKA): Brian
Postby astro355 » March 10th 2010, 10:00am
86shorty wrote:Ok guys just for fun I went and bought a after market temp gauge, hooked it up to the new sensor and every thing works !!! hmmmm I think maybe its a ground problem.
Shorty......
Well, considering that the sender grounds itself when its screwed into the head, I'm not sure of it being a ground problem. If it was, the aftermarket gauge wouldn't get a reading either. But at least you know the sender is good.
astro355
It is currently August 13th 2020, 12:34pm
pmou
Comments: 43
Date: Jul 30 '20
Time: 3:31am
pmou
Comments: 43
Date: Jul 29 '20
Time: 11:58pm
Attached by: tonydobbs
tonydobbs
Date: Jul 29 '20
Time: 5:41pm
pmou
Comments: 43
Date: Jul 21 '20
Time: 7:13pm
pmou
Comments: 43
Date: Jul 20 '20
Time: 11:50pm
Users browsing this forum: Google Adsense [Bot] and 5 guests
