by fowler [OP] » March 15th 2010, 8:32pm
by astro355 » March 15th 2010, 9:14pm
by fowler [OP] » March 15th 2010, 9:21pm
by astro355 » March 15th 2010, 9:24pm
by fowler [OP] » March 15th 2010, 11:04pm
by Masstro » March 16th 2010, 5:21am
by rev_les » March 17th 2010, 5:57am
by fowler [OP] » March 18th 2010, 5:50pm
by rev_les » March 19th 2010, 1:12am
by astro355 » March 19th 2010, 2:02am
by rev_les » March 19th 2010, 2:23am
astro355 wrote:I'm not so convinced that its an ignition problem. I would really want to know what those fuel pressure readings are. I worked on a Bonneville years ago that had a very intermittent stumble that was caused by a crankshaft position sensor that was on its way out.
by astro355 » March 19th 2010, 2:24am
rev_les wrote:astro355 wrote:I'm not so convinced that its an ignition problem. I would really want to know what those fuel pressure readings are. I worked on a Bonneville years ago that had a very intermittent stumble that was caused by a crankshaft position sensor that was on its way out.
I agree with you, I'm just trying to help rule out things before he goes plopping down cash. That crank pos. sensor can cause you to pull hair out too, definitely something in need of checking, as well as the OP seeing the fuel pressure with his own eyes......especially with the qualifications that dealership's mechanics seem to have.
by rev_les » March 19th 2010, 2:34am
by astro355 » March 19th 2010, 2:38am
rev_les wrote:Exactly....makes you wonder if the engine running right might fix the transmission problem. My first indicator several times on some of my GM's that I was gonna lose a fuel pump, is they suddenly act like the transmission's keeling over.....Or it may have a trans problem too.
by rev_les » March 19th 2010, 2:52am
fowler wrote:So I ended up taking it back to the dealer as I had paid $100 for them to tell me they "thought" it was the catalytic converter. So with this second go round, they basically tell me it's my transmission. I asked them how my transmission would cause a p300 code and the service manager made up some **** about the engine vibrations etc....blah blah blah. Needless to say, I will never take it back to the dealer or purchase a vehicle from them due to this incident.
So I called a couple transmission places today to get an idea of the cost on a rebuild (since I am having a trans issue with shifting from 2-3). I explained to the first shop the issue and he told me I need to figure out the misfire issue first, as the trans won't cause a misfire.
So I'm still at the same place I started. I have noticed that once the Astro is warmed up, I do not get the stutter at 20mph anymore, yet the stutter still happens consistently after the 50mph mark. My plan is to replace all the plugs and wires this weekend with Delco parts and test the distributor to see if there is any play in the gear. I'm also gonna check out the EGR valve and see what it looks like and clean it up if there is carbon on it. I'll check to see if there is any slop in the cap when I replace it again this weekend.
by astro355 » March 19th 2010, 2:57am
rev_les wrote:fowler wrote:So I ended up taking it back to the dealer as I had paid $100 for them to tell me they "thought" it was the catalytic converter. So with this second go round, they basically tell me it's my transmission. I asked them how my transmission would cause a p300 code and the service manager made up some **** about the engine vibrations etc....blah blah blah. Needless to say, I will never take it back to the dealer or purchase a vehicle from them due to this incident.
This one !
by rev_les » March 19th 2010, 3:04am
by fowler [OP] » March 21st 2010, 10:23pm
by Leeann_93 » March 21st 2010, 10:53pm
It is currently February 26th 2021, 7:53pm
Engines Forum |
Engine Repairs, Modifications, Diagnostics, Tuning, Upgrading, Questions. <a href="https://ad.doubleclick.net/ddm/trackclk/N8334.275400VERTICALSCOPEINC./B20209277.204028354;dc_trk_aid=407011718;dc_trk_cid=94070067;dc_lat=;dc_rdid=;tag_for_child_directed_treatment="target="_blank"><img src="https://tpc.googlesyndication.com/pagead/imgad?id=CICAgKDrrqWwMRCAARgcKAEyCN4sAjjtai4k" border="0" align="right"> <IMG SRC="https://ad.doubleclick.net/ddm/trackimp/N8334.275400VERTICALSCOPEINC./B20209277.204028354;dc_trk_aid=407011718;dc_trk_cid=94070067;ord=;dc_lat=;dc_rdid=;tag_for_child_directed_treatment=?" BORDER="0" HEIGHT="1" WIDTH="1" ALT="Advertisement"> |
Moderator: chevy57bert |
Previous topic Next topic |
Sponsors |
Users browsing this forum: Astrojohn, Yandex [Bot] and 29 guests
