Loads up at cold start up
Postby chris1224 [OP] » March 18th 2010, 4:42am
Yeah its me again... new day new problem. i got my v8 swap complete and loving my new found power,but the bugs are killin me. When i go out to start up my van it will start but i have to hold it half throttle while it sets here and loads up and rolls black. then all uf a sudden like a switch it smooths right and runs and idles great. Itslike a carb thats choke is stuck. Its like what ever controls the fuel mixture at start up is acting up.is it the sensor on the front intake that goes into the water passage beside the water neck? please help me work out this kink please. thanks chris :confused:
chris1224
Years of Membership: chris1224 has been a member for 11 full yearschris1224 has been a member for 11 full yearschris1224 has been a member for 11 full yearschris1224 has been a member for 11 full yearschris1224 has been a member for 11 full yearschris1224 has been a member for 11 full yearschris1224 has been a member for 11 full yearschris1224 has been a member for 11 full yearschris1224 has been a member for 11 full yearschris1224 has been a member for 11 full yearschris1224 has been a member for 11 full years
Extra Info: 5.7L tbi
Re: Loads up at cold start up
Postby Astroplane » March 18th 2010, 4:52am
chris1224 wrote:is it the sensor on the front intake that goes into the water passage beside the water neck?
Any codes? If there is a bad connection at the two wire ECT sensor it could be telling the ECM it is -40*. Check the plug and sensor terminals for corrosion and tight fit. Scanner with live data will show what the ECM is seeing at that moment. Any raw fuel smell from engine area before startup?
Astroplane
Blue Status (L2)
Blue Status (L2)
Years of Membership: Astroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full years
Extra Info: LT RWD
Postby chris1224 [OP] » March 18th 2010, 4:59am
there are no codes and no gas smell.
chris1224
Postby astro355 » March 18th 2010, 1:44pm
What is the fuel pressure at startup?
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby chris1224 [OP] » March 18th 2010, 4:59pm
not sure ... what you thinkin, to much pressure at start up? why would the pressure be diff. it dont just clear up. it is just like a switch. from loading to clear.like something electrical.
chris1224
Postby astro355 » March 19th 2010, 2:23am
chris1224 wrote:not sure ... what you thinkin, to much pressure at start up? why would the pressure be diff. it dont just clear up. it is just like a switch. from loading to clear.like something electrical.
I'm thinking the fuel pressure isn't high enough. Weak fuel pumps can take a while to build pressure. You could always spray some starting fluid into the throttle body the next time to start it when its cold and see if the problem goes away.
astro355
Postby Astroplane » March 19th 2010, 4:00am
I was going to tell you to remove the fuse for the injectors at first start to see if its' flooded, but you don't smell fuel.
Astroplane
Blue Status (L2)
Blue Status (L2)
Extra Info: LT RWD
Postby astro355 » March 19th 2010, 9:10am
Astroplane wrote:I was going to tell you to remove the fuse for the injectors at first start to see if its' flooded, but you don't smell fuel.
Exactly why I think the pressure is low.
astro355
Postby chris1224 [OP] » March 20th 2010, 3:12am
thanks guys ill try both of those in the morning there is something else tho when it is warmed up it wants to idle to low. some times the SES light comes on and it idles fine it will stay on for a little then goes off and it idles back down. i think im just goin to take it in to the shop and have it looked at by someone with the right tools to check it out im tired of the guess work i know yall are to but i do appreciate all the help/
chris1224
Postby Astroplane » March 20th 2010, 4:29am
chris1224 wrote:it sets here and loads up and rolls black.
astro355 wrote:Exactly why I think the pressure is low
Maybe I'm misreading this. :shrug:
chris1224 wrote:i think im just goin to take it in to the shop and have it looked at by someone with the right tools to check it out im tired of the guess work i know yall are to but i do appreciate all the help/
Please follow up and let everyone know what you find. :thumbup:
Astroplane
Blue Status (L2)
Blue Status (L2)
Extra Info: LT RWD
It is currently April 13th 2021, 2:24am
kvargas1356
Date: Apr 11 '21
Time: 10:20pm
Attached by: jfunkngroove
Comments: 17
Date: Apr 10 '21
Time: 10:38pm
MmusicmanMmusicman is online!
Date: Apr 08 '21
Time: 8:52pm
Comments: 17
Date: Apr 08 '21
Time: 1:55am
Date: Mar 22 '21
Time: 2:11pm
Users browsing this forum: No registered users and 24 guests
