Recommended block heater
Postby Kirkus [OP] » November 12th 2014, 3:45pm
Hi all,
I haven't been too active here lately because I haven't been doing too much to The Bus except driving it and preventative/routine stuff. For you all that are in cold weather, I need a recommendation for an engine block heater. I'd rather not mess with a freeze plug heater or a dipstick heater. Have you all had any luck with heaters?
Thanks in advance!
Jerome The Bus is his name and taking care of Kirkus is his game. :layrubber: 1992 GMC Safari XT 4.3L 262 RWD At least 300,000 Mi Orig eng and tranny
Kirkus
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: Kirkus has been a member for 10 full yearsKirkus has been a member for 10 full yearsKirkus has been a member for 10 full yearsKirkus has been a member for 10 full yearsKirkus has been a member for 10 full yearsKirkus has been a member for 10 full yearsKirkus has been a member for 10 full yearsKirkus has been a member for 10 full yearsKirkus has been a member for 10 full yearsKirkus has been a member for 10 full years
Topics: 12
Alias (AKA): Kirk
Extra Info: 262 Z
Re: Recommended block heater
Postby redfury » November 14th 2014, 6:14am
Depends on what you want out of the heater and how much you want to spend. The easiest install would be a lower radiator hose heater. Splice it in with 2 clamps and plug it into the house...you'll lose some coolant, it's gonna be a mess, but it's the easiest. Not sure what the diameter of it is off hand though.
Now, if you want to put something in that will give you immediate heat when you drive away...then you are looking at a much nicer and more expensive recirculation heater...it'll heat up the entire engine and coolant so that there is hardly any wait for full heat. Great for those days you have to make a short run, or you have a short run to work every day and don't want to install a remote starter and waste all that gas.
circulation heater http://www.amazon.com/Kats-13100-Alumin ... BO8X9K#Ask
Lower hose heater http://www.amazon.com/Kats-14600-Lower- ... 6YHBX97MMP
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Extra Info: LT 5.7L 4wd
Postby Astrofarian » November 14th 2014, 6:33am
Your LAPS will have a listing for an inline heater that fits into the heater hose; much easier than cutting a perfectly good rad hose and around $50. We've used them on farm tractors for years and never had any issues. They are around 1500watts if I recall correctly.
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
It is currently August 12th 2020, 8:02am
pmou
Comments: 43
Date: Jul 30 '20
Time: 3:31am
pmou
Comments: 43
Date: Jul 29 '20
Time: 11:58pm
Attached by: tonydobbs
tonydobbs
Date: Jul 29 '20
Time: 5:41pm
pmou
Comments: 43
Date: Jul 21 '20
Time: 7:13pm
pmou
Comments: 43
Date: Jul 20 '20
Time: 11:50pm
