Running great but can not get this thing to stop leaking. I'v had the cooler lines leak and fixed those, but the oil still seems to be coming from the lower timing cover/crank seal area. I've replaced the cover/seal with new QUALITY timing covers 3 times now. Every time I put in a new QUALITY oil pan gasket and put the proper sealant at the factory repair manual specified sites. Still, after a bit of time this B I T C H starts leaking again(hard to say exactly where as by the time I find it the residue is sprayed all over)
By the 3rd time "fixing" this I have become extremely anal about cleaning the surfaces and correct torquing of the cover/pan. I've even put some sealant around the o-ring on the crank sensor just in case that was not sealing. I lube the crank seal before putting on the balancer and all seems right with the world...till it starts leaking again.
At this point, all I can think of is that the HB sealing surface is out of round and deforming the crank seal allowing oil to leak past it. Frankly I can't believe that is the case, but it is the only part of the assembly that I have not changed out, well, the oil pan is still the old one but I checked it with a straight edge and it was fine.
Any ideas?? I just don't want to get back down there and change that **** again, but I know I'll have to
WHY DON'T I SELL THIS STUPID THING? Seriously I have no idea why I keep it. Ha.
