I was reading on the old forum how people frequently had problems with the engine running rough and the cause was very often the distributor cap. It seems that people who purchased an off-brand distributor cap and rotor wound up having to replace it a year later.
Well, now I'm in that same situation. I got to the point where my van wouldn't even start. So, one day, I took the doghouse off, took the distributor cap off, and found each contact in there had quite a build up of white cakey stuff on it. So, I just took a little dremel wire brush and buffed them all off. It seemed to help quite a bit.
However, I still have the same problem with rough running, particularly when it is really damp and rainy outside. Now, I know that this was all replaced about a year ago from the guy I bought the van from, but he used off brand parts. Also, when I had the distributor cap off, I had to take off 3 wires from one side of the cap. I looked at the wire contacts on the inside of the boot, and noticed that there was actually some light rust forming on them! Now, I don't have any idea how THAT would have happened. The wires are in excellent shape (like new) and the boots were very tight. Anyhow, no matter. It looks like I am going to have to replace distributor cap, rotor, and wires before I get the van running tip top again. On the old forum, the comment mentioned was to only buy ACDelco parts in this regard. So my question is, forgive me for being green, but where do I go to buy ACDelco parts? Do I have to go to the dealer, or do some of the chain auto parts carry them? I've never gone out in search of a particular brand before, but if the ACDelco stuff will fix my problem, then that's what I want to get.
I'd also be interested in any recommendation on spark plug wires. I was also wondering if it might not be a good time to replace the coil as well. My van is a 1999 with 165,000 miles on it. The coil looks like it's seen better days. I know looks don't necessarily mean anything, but I just figured that perhaps as a preventive it might be good to go ahead and replace it. Of course, as an enthusiast, I would prefer to replace it with something better than original equipment! Any recommendations in that regard would be appreciated.
I just don't understand how moisture got inside the boots to cause the contacts on the end of the wire to rust. That is just weird.
So, I guess my question is:
Where do I go to get ACDelco parts?
What recommendations does anyone have regarding a replacement coil?
What recommendations does anyone have regarding spark plug wires?
Thanks,
Dave
