Engine Oil Cooler Lines
Postby coult45 [OP] » February 3rd 2015, 9:40pm
So I went to pull off my leaky oil cooler lines today. After buying some new pick tools, the radiator connections went off easy. As did the connecting bolt to the oil filter. But, theres another bolt, which attaches a metal "ring" to the engine block. After watching youtube, and reading my FSM, this was supposed to be super easy.
Turns out both youtube and the FSM have instructions that follow the RWD model, i have the AWD so there is a giant front differential in the way of my bolt! I ended up removing the front driveshaft, hoping I'd have better luck getting a wrench up there, but its all pretty tight. I can sort of fit some wrenches, the video says its a 10mm, but that doesn't seem right, could it be a standard size bolt?
Either way, I cut off the ends near the filter side so i could pull the lines out without undoing that engine block bolt.
My question is, can I just move that engine block bolt/holder out of the way and run the lines from the rad to the filter? Or should I really try and find a way to get the lines bolted to the engine block? Any help getting to this bolt / what size it is? And any tips on re-routing the new lines back in would be great, definitely bent the crap out of the old, leaky ones..
On another note, I've thought about doing the cooler line delete. Any thoughts about the delete?
coult45
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: coult45 has been a member for 7 full yearscoult45 has been a member for 7 full yearscoult45 has been a member for 7 full yearscoult45 has been a member for 7 full yearscoult45 has been a member for 7 full yearscoult45 has been a member for 7 full yearscoult45 has been a member for 7 full years
Topics: 22
  • Oil Cooler Line
    by singlefinastro » September 9th 2020, 6:40pm in Engines
    Last post by singlefinastro View the latest post
    September 10th 2020, 1:23am
  • Lost oil ptessure, oil all over motor
    by equitube » September 26th 2020, 1:51am in Engines
    September 26th 2020, 3:25am
    40
    March 1st 2021, 5:11pm
Re: Engine Oil Cooler Lines
Postby RECox286 » February 3rd 2015, 10:17pm
If there wasn't a reason for it to be there...
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby chevymaher » February 3rd 2015, 11:04pm
I deleted mine after they leaked and blew my engine up.
It is a good thing to have "IF" they don't leak. But it would be fine without them.
Postby Lumpy » February 3rd 2015, 11:39pm
My 89 doesn't have an OEM oil cooler. I keep reading where everyone seems to have trouble with the hoses and connections with their OEMs. Is it always at the filter adaptor? What if we REMOVED the OEM adaptor and something aftermarket?
I can't ever remember having leaks in my VW external oil coolers and filters. Nor in any Frud Wambulance (nearly always aftermarket).
Postby tanvanmanwithaplan » February 3rd 2015, 11:51pm
I just had mine replaced a few days ago at a local mechanic because it is a messy job and I'm glad I did now. They said for my AWD the easiest way they could find to do it was unbolt the subframe on one side and let it hang off the van somehow. It sounds scary but it's on there and the van is driving great.
By the way if you buy the dorman replacement ones they are $44 on Amazon which is way cheaper than OE
2001 AWD Astro LT 112k mi 4" lift inprog
tanvanmanwithaplan
Years of Membership: tanvanmanwithaplan has been a member for 6 full yearstanvanmanwithaplan has been a member for 6 full yearstanvanmanwithaplan has been a member for 6 full yearstanvanmanwithaplan has been a member for 6 full yearstanvanmanwithaplan has been a member for 6 full yearstanvanmanwithaplan has been a member for 6 full years
Topics: 13
Van Model Year: 2001
Extra Info: LT4.3LV6AWD
Postby coult45 [OP] » February 3rd 2015, 11:55pm
tanvanmanwithaplan wrote:I just had mine replaced a few days ago at a local mechanic because it is a messy job and I'm glad I did now. They said for my AWD the easiest way they could find to do it was unbolt the subframe on one side and let it hang off the van somehow. It sounds scary but it's on there and the van is driving great.
Woah! That was the answer i was looking for.... Maybe ill run it without lines and when I find a chunk of time put them in. The $44 dorman lines should arrive tomorrow.
And lumpy, mine are only leaking where the metal and rubber tubing meet. The connection at the filter is dry as a whistle.
coult45
Fueling (5/8 tank)
Fueling (5/8 tank)
Topics: 22
Postby tanvanmanwithaplan » February 4th 2015, 12:06am
My shop only chRged me $100 for the oil change and putting the lines on, well worth it for this job if you ask me.
Also another option is just fixing the leak by cutting the tubing off and putting new hoses with clamps. 97cargocrawler has a write up on that.
tanvanmanwithaplan
Topics: 13
Postby 1998kingbong » February 4th 2015, 1:03am
100 bucks -sold! I cut the new lines and put them together with a compression coupling. Be careful, but after around an hour of trying to install the new ones I gave up. 4 years later and no leaks
1998kingbong
Years of Membership: 1998kingbong has been a member for 7 full years1998kingbong has been a member for 7 full years1998kingbong has been a member for 7 full years1998kingbong has been a member for 7 full years1998kingbong has been a member for 7 full years1998kingbong has been a member for 7 full years1998kingbong has been a member for 7 full years
Topics: 19
Extra Info: awd 165000
Postby Lumpy » February 4th 2015, 6:14am
1998kingbong wrote:100 bucks -sold! I cut the new lines and put them together with a compression coupling. Be careful, but after around an hour of trying to install the new ones I gave up. 4 years later and no leaks
Flat tops scheme the trout finding an open to the blue. Or dirt times curtains. Squirrel television shoes of the best ranger.
Postby 1998kingbong » February 4th 2015, 12:45pm
lump, am I blabbing again?
1998kingbong
Topics: 19
It is currently March 1st 2021, 5:11pm
Ken2.7
Date: Feb 24 '21
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Date: Feb 23 '21
Time: 8:41pm
Attached by: WinnieVan
WinnieVan
Date: Feb 23 '21
Time: 8:07am
Ken2.7
Date: Feb 22 '21
Time: 11:43pm
Users browsing this forum: BikleyBikley is online!, MHMMHM is online! and 32 guests
