ghost changed ignition timing
Postby vulcaninja [OP] » April 30th 2010, 5:49pm
My son brings home the old 1994 w engine astro and says it has no power backfires and has a strange exhaust sound. After replacing some much needed tune up parts along with cpi set, I found that simply turning the distributer counter clockwise fixed it so i put a light on it and put it back on spec at 4 degrees bftdc and all seems well. No code or engine light showed up. Can't figure why that happened. :confused:
Two 1994 ext cl W 1=111K 7pass. 2=230k 8pass. stripped for cargo use.
vulcaninja
Years of Membership: vulcaninja has been a member for 10 full yearsvulcaninja has been a member for 10 full yearsvulcaninja has been a member for 10 full yearsvulcaninja has been a member for 10 full yearsvulcaninja has been a member for 10 full yearsvulcaninja has been a member for 10 full yearsvulcaninja has been a member for 10 full yearsvulcaninja has been a member for 10 full yearsvulcaninja has been a member for 10 full yearsvulcaninja has been a member for 10 full years
Extra Info: ext w
  • Mechanical Ignition Timing Adjustment Procedure (MITAP)
    by Sailing_Faith » May 8th 2020, 7:59pm in Engines
    Last post by pbgbottle View the latest post
    June 28th 2020, 5:28pm
  • Timing Chain in Balance shaft engine
    by JD_GM » July 2nd 2020, 5:58pm in Engines
    Last post by JD_GM View the latest post
    July 2nd 2020, 7:32pm
    9
    22
    September 18th 2020, 1:59pm
Re: ghost changed ignition timing
Postby LEVE » April 30th 2010, 6:00pm
Was the distributor lockdown tight when you first examined it? :confused:
LEVE
Years of Membership: LEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full years
Topics: 18
Extra Info: AWD 4.3L-W
Postby vulcaninja [OP] » April 30th 2010, 9:03pm
Yeah so tight and alittle rusted I had to spray it with Pb. This ones got me ??? I've owned 4 astros and a G 10 all 4.3l and all problems are pretty minor and fairly easy to diagnose -they're about as complex as a lawn mower compared to today's trucks.
vulcaninja
Extra Info: ext w
Postby LEVE » April 30th 2010, 9:05pm
Then, IMHO, it's got to be a problem internal to the distributor....
LEVE
Topics: 18
Postby 1992RS » April 30th 2010, 10:18pm
not very common but did the body of the dist. itself break and allow it to turn? I had this happen on my 4.3 blazer
1992 Astro RS
174,000 miles
Rebuilt top end
stock tranny
1992RS
Years of Membership: 1992RS has been a member for 10 full years1992RS has been a member for 10 full years1992RS has been a member for 10 full years1992RS has been a member for 10 full years1992RS has been a member for 10 full years1992RS has been a member for 10 full years1992RS has been a member for 10 full years1992RS has been a member for 10 full years1992RS has been a member for 10 full years1992RS has been a member for 10 full years
Topics: 38
Alias (AKA): tony
Extra Info: RS 4.3v rwd
Postby vulcaninja [OP] » May 1st 2010, 11:42am
Broken distributor? Went for a 5mile highway/city test run and all seems fine. wouldn't think a broken distro shaft would allow the engine to run at all but it sure beats out any thought of paranormal activity being the culprit. I'll pop the cap and take another look at it anyway .
vulcaninja
Extra Info: ext w
Postby 1992RS » May 1st 2010, 8:04pm
Not the shaft but the housing could have broken at some point where the shaft is fine but the housing could slowly turn causing gradual changes in the timing, also the timing chain could have stretched causing the timing to change over time thus far not being noticable until it got pretty bad I would check that first.
1992 Astro RS
174,000 miles
Rebuilt top end
stock tranny
1992RS
Topics: 38
Alias (AKA): tony
Postby astroturf » May 2nd 2010, 1:44pm
I would like to mention that you may want to pull the Distributor and inspect its bronze drive gear for wear. Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby vulcaninja [OP] » May 2nd 2010, 2:41pm
I guess a good through distributor check would be in order here. Forgot to mention the van only has 111k. My other van(94 w cargo) has 230K with no ignition issues yet. Thanks to all here-great site.
vulcaninja
Extra Info: ext w
Postby Astroplane » May 5th 2010, 6:17am
vulcaninja wrote:I guess a good through distributor check would be in order here.
Check the drive gear and distributor shaft relationship and however it is retained. We just had a similar post here by grandamle91 I think. I'm wondering if a roll pin or such is shearing but only turning so far once it fails.
Astroplane
Blue Status (L2)
Blue Status (L2)
Years of Membership: Astroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full years
Extra Info: LT RWD
It is currently September 18th 2020, 1:59pm
erikw9
Comments: 32
Date: Sep 14 '20
Time: 7:30pm
Attached by: Godron629
Godron629
Date: Sep 14 '20
Time: 3:25am
erikw9
Comments: 32
Date: Sep 12 '20
Time: 11:58pm
erikw9
Comments: 32
Date: Sep 12 '20
Time: 2:28am
djpigs
Date: Sep 11 '20
Time: 4:00am
Users browsing this forum: No registered users and 15 guests
