Coolant leak...
Coolant leak...
Postby ShAgSTRO [OP] » May 9th 2010, 7:50am
I almost forgot to mention this tonight before I tackle the beast tomorrow in the morning. I was driving to Wal-Mart for some boxes to move back home for summer with and smelt coolant while getting out of the van. I didn't think of it much because it's Wal-Mart...who knows what else is in that parking lot. Well as I was backing out, I saw a pool of coolant in the space I pulled out of and jokingly said to my girlfriend, "I hope that's not from me!" Then I stopped to make sure, given the horrible luck I have had in the past with cars, and sure enough...it was me. I drive to the nearest gas station and pour into my radiator a gallon of water, and then some!
Well, after opening the radiator and pouring the water in, it started leaking right out!!!
I know its not my intake manifold gasket because as I said, it leaks when its not even on...plus I checked for leaks on the engine block and there weren't any at all (including the water pump.)
Crazy right!?! I'm going to check my hoses and radiator tomorrow. I would've popped the shroud out to see if it was as simple as a loose hose but I was with the lady - I didn't want to keep her waiting :P
Just thought I could contribute this almost total loss of engine to the forum! I'm getting better at realizing that my cars are about to die a miserable death.
And what bad luck have I had in the past?
1994 Nissan Altima - had to replace normal things such as alternator, radiator, starter...this thing got old fast
1997 Chevy Tahoe - 2 major, a lot of smalls. Replaced intake manifold gasket then one month later...replaced entire engine DX
1996 Toyota 4-Runner Replaced master cyl, brake booster, had frame damage from PO, then the thing started leaking coolant the day before school was supposed to start (here in Charlotte - home in Raleigh)
1994 Toyota 4-Runner - Bought for $150 as a parts car for my 96' 4-Runner, ended up realizing that it just needs an engine and it'll be in perfect condition, so I gave it to my dad
1990 Chevy Astro - Didn't need ANYTHING!!! First car that I didn't put ANY money into! Except it was my dad's and I gave it back to him. O-rings were worn though so there was a smoke show everytime I cranked it hahaha (used it because the sudden death of my 4-Runner.
1986.5 Toyota Supra - Replaced Idle Air Control, clutch master cyl, slave cyl, brake master cyl, then clutch eventually went bad
1986 Chevy Astro - Nothing...except I need to fix this simple leak
I just realized...I'm 20 this July and have had seven different cars...I think I have a problem hahaha!
1986 Astro...I like my EFI carb ;)
ShAgSTRO
Years of Membership: ShAgSTRO has been a member for 10 full yearsShAgSTRO has been a member for 10 full yearsShAgSTRO has been a member for 10 full yearsShAgSTRO has been a member for 10 full yearsShAgSTRO has been a member for 10 full yearsShAgSTRO has been a member for 10 full yearsShAgSTRO has been a member for 10 full yearsShAgSTRO has been a member for 10 full yearsShAgSTRO has been a member for 10 full yearsShAgSTRO has been a member for 10 full years
Topics: 16
Extra Info: 4.3L
  • Coolant leak
    by Maddog » September 4th 2020, 9:21pm in Engines
    September 22nd 2020, 10:38pm
  • Coolant leak diagnosis
    by Godron629 » September 14th 2020, 3:25am in Engines
    Last post by K-TRON View the latest post
    September 18th 2020, 3:59am
    February 27th 2021, 1:57pm
Re: Coolant leak...
Postby ShAgSTRO [OP] » May 9th 2010, 8:12am
I forgot to say
:feedback: :feedback: :feedback:
Are there any problem hoses or places on the radiator? It's not the original rad but maybe it busted
ShAgSTRO
Topics: 16
Extra Info: 4.3L
Re: Coolant leak...
Postby Astroplane » May 9th 2010, 8:17am
Since it is a major leak, daylight and a fresh start should reveal the source quickly. Hopefully, it is just a split in a hose. :thumbup:
Astroplane
Blue Status (L2)
Blue Status (L2)
Years of Membership: Astroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full years
Extra Info: LT RWD
Re: Coolant leak...
Postby Mr_Bowtie » May 9th 2010, 4:27pm
Let us know what you find or don't find. :D
I'm a freak and check my old Vans for low fluids and leaks once a week. Once they get up there in age you can't turn your back on them. On my '92 I have found tranny, coolant, power steering, & oil leaks before they turned ugly. (tranny cooler line rusting out, coolant temp sensor leaking, power steering cooler rusted 'n' leaking, & oil cooler lines leaking bad) :chevy:
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Van Model Year: 1985
Extra Info: 350 with 700r4
Re: Coolant leak...
Postby ShAgSTRO [OP] » May 9th 2010, 7:41pm
Damn right, daylight gave me a better view on everything. And Bowtie, you're so right! Can't trust these lines for one second haha
So I took off the shroud and filled her up. Didn't take a lot of water to top it off this time. I know for a fact that the car didn't overheat and given the way I drove it I am not worried that I caused engine damage. The radiator is leaking...and its only 2.5 years old! WTF?!?! haha
Since the radiator is kind of new I'm going to have it rebuilt, that's if I can find a place in Charlotte to do it. If not, I'll buy a used rad and have the one that's on now rebuilt and switch it out again.
ShAgSTRO
Topics: 16
Extra Info: 4.3L
Re: Coolant leak...
Postby ShAgSTRO [OP] » May 10th 2010, 3:45am
Alright! I fixed it! I changed the radiator out with a used one with 30 day warranty from the JY. The fins on the on I got were kind of beat up (you know how people don't care about stuff in the JY) but it works! I was worried that my head gasket was blown because before I changed it there were bubbles in the radiator. Once I changed the radiator and let fill up, there were zero bubbles :D
So hopefully I can make it to Raleigh for the summer and I'll have the old radiator rebuilt!
Thanks guys!
ShAgSTRO
Topics: 16
Extra Info: 4.3L
Re: Coolant leak...
Postby Mr_Bowtie » May 10th 2010, 3:58am
ShAgSTRO wrote:Alright! I fixed it! I changed the radiator out with a used one with 30 day warranty from the JY. The fins on the on I got were kind of beat up (you know how people don't care about stuff in the JY) but it works! I was worried that my head gasket was blown because before I changed it there were bubbles in the radiator. Once I changed the radiator and let fill up, there were zero bubbles :D
Thanks guys!
Sweet! Bubbles just mean air in the system....from a leak. The JY radiator will probably run forever that how things work.....junkers run forever and nice stuff breaks. :lol: :chevy:
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Re: Coolant leak...
Postby ShAgSTRO [OP] » May 10th 2010, 5:08am
Thanks Mr.Bowtie! You're so right though about the junkers though :P
ShAgSTRO
Topics: 16
Extra Info: 4.3L
It is currently February 27th 2021, 1:57pm
Ken2.7
Date: Feb 24 '21
Time: 2:02am
MmusicmanMmusicman is online!
Date: Feb 23 '21
Time: 8:38pm
Date: Feb 23 '21
Time: 8:41pm
Attached by: WinnieVan
WinnieVan
Date: Feb 23 '21
Time: 8:07am
Ken2.7
Date: Feb 22 '21
Time: 11:43pm
