95 Chevy Astro TDC
95 Chevy Astro TDC
Postby hernrube [OP] » June 15th 2010, 6:57pm
Need some help!!!!!
I had heads serviced.
The heads are mounted onthe block.
I have treaded in rocker arm studs.
I'm trying to find TDC on piston 1.
I'm trying to find TDC so that I can install rockers and adjust them as well as others listed in book.
then rotate balancer a full rotation to install rockers and adjust the remaining valves as listed in book
I have white mark on balancer.
Can I use push rods to assist me in finding TDC if I insert them in for piston 1.
No rockers so valves don't move.
Thanks
hernrube
Years of Membership: hernrube has been a member for 11 full yearshernrube has been a member for 11 full yearshernrube has been a member for 11 full yearshernrube has been a member for 11 full yearshernrube has been a member for 11 full yearshernrube has been a member for 11 full yearshernrube has been a member for 11 full yearshernrube has been a member for 11 full yearshernrube has been a member for 11 full yearshernrube has been a member for 11 full yearshernrube has been a member for 11 full years
Extra Info: V6
  • 2000 Chevy Astro No Fuel Pressure
    by Disarobbry » November 10th 2020, 5:25pm in Engines
    Last post by Disarobbry View the latest post
    November 11th 2020, 7:55pm
  • Alternator Broke off Mount/bracket - 95 Safari SLT
    by elvisjay » June 18th 2020, 1:17pm in Engines
    Last post by elvisjay View the latest post
    June 19th 2020, 3:02pm
    9
    72
    November 25th 2020, 3:12am
Re: 95 Chevy Astro TDC
Postby $uperJoe » June 15th 2010, 7:06pm
couple things. tdc is in reference to timing. not to rocker arms or placement
did you remove the cam or timing chain in the motor. if not it does not matter when installing rocker arms or any of the pertaining nuts or push rods.
once you have the arms installed you will then be able to visually watch the valves come open and closed and also with the timing mark know when tdc is achieved.
this is important to setting the dist timing. i would go ahead with the next step without worry about tdc
Check out my Van build
$uperJoe
Firing on 4 Cylinders (L2)
Years of Membership: $uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years
Topics: 59
It is currently November 25th 2020, 3:12am
Attached by: Slime
Slime
Time: 11:11pm
K-TRON
Comments: 23
Date: Nov 16 '20
Time: 1:07am
Attached by: Devonian
Devonian
Date: Nov 13 '20
Time: 2:19am
K-TRON
Comments: 23
Date: Nov 12 '20
Time: 2:51am
Devonian
Date: Nov 11 '20
Time: 10:25pm
Users browsing this forum: Google [Bot] and 24 guests
