How to clean egr valve?
Postby alexalexanders [OP] » June 30th 2010, 2:45am
So i have been seeing alot of suggestions to clean your egr valve? My questions are, Where is it located, How do you do it? How do i know if i need to do it? Thanks in advance for the help guys and gals! Btw the van is a 94 chevy astro vin Z with a full tune up done already, 2wd
2000 GMC Safari SLE
alexalexanders
Firing on 8 Cylinders (L1)
Years of Membership: alexalexanders has been a member for 11 full yearsalexalexanders has been a member for 11 full yearsalexalexanders has been a member for 11 full yearsalexalexanders has been a member for 11 full yearsalexalexanders has been a member for 11 full yearsalexalexanders has been a member for 11 full yearsalexalexanders has been a member for 11 full yearsalexalexanders has been a member for 11 full yearsalexalexanders has been a member for 11 full yearsalexalexanders has been a member for 11 full yearsalexalexanders has been a member for 11 full years
Topics: 80
Extra Info: SLE 4.3 Vortec
  • valve rocker stud, bolt.
    by djpigs » September 11th 2020, 4:02am in Engines
    September 11th 2020, 5:53am
  • Coolant in lifter valve valley!
    by roachmon » January 9th 2021, 6:48am in Engines
    Last post by AstroOafAdventurerAstroOafAdventurer is online! View the latest post
    January 12th 2021, 10:48pm
    7
    92
    March 1st 2021, 5:56pm
Re: How to clean egr valve?
Postby Leeann_93 » June 30th 2010, 4:07am
I assume it's in the same place as on my '93 W motor - front, slightly passenger side, behind the belt tensioner and under the air intake. Oh, wait, Z engine...you'll probably have to remove the air cleaner.
Get the kleen screen gasket from your local autoparts place, in the HELP! section (where they have replacement window handles and such) and get the one for GM.
My EGR looked pretty nasty when I took it off - and was stuck almost completely open with those chunks of carbon. Clean out the chunks, then clean the pintle and its seat with sensor-safe cleaner. Gently push in the pintle to clean the seat.
You'll need a 10mm socket with at least 9" of extension (at least, you do on a W motor) for the driver's side bolt and a 10mm ratcheting wrench for the passenger side bolt if you have AC.
On the second pic, I've drawn an arrow to the EGR mounting so you can see what it looks like/approximately where it is.
EGR location.jpg (229.38 KiB) Viewed 15975 times
Postby jeff's93astro » June 30th 2010, 4:18am
its at the back of the intake on the Z motor
95 Astro 5.3L RWD 3/3 drop
03 Suburban 5.3L 2wd 3/5 drop
jeff's93astro
Topics: 55
Images: 19
Extra Info: CS 4.3L V6 RWD
Postby Big_kid » June 30th 2010, 4:24am
The help card I bought had 2 gaskets in it. I gave the Ford one to my neighbor.
Firing on 7 Cylinders (L7)
Topics: 185
Images: 342
Extra Info: 2WD 5.7 V8
Postby alexalexanders [OP] » June 30th 2010, 4:41am
Thanks for the help! Is there anyway to tell if i need to do this? Should i worry about it at 87,000 miles of highway driving?
2000 GMC Safari SLE
alexalexanders
Topics: 80
Postby webcat » June 30th 2010, 6:20am
jeff's93astro wrote:its at the back of the intake on the Z motor
That looks like a stupid place to put it :doh:
webcat
Firing on 3 Cylinders (L3)
Topics: 253
Alias (AKA): Larry aka Rambo
Extra Info: g10 5.7L vortec
Postby Gary » June 30th 2010, 11:09am
A rough idle is a effect of carbon holding open the EGR,but with a 1994 van it wouldn't hurt to put in a screened gasket and check the EGR at the same time.
Gary
Dearly Departed
Firing on 4 Cylinders (L3)
Topics: 136
Extra Info: high top
Postby Mr_Bowtie » June 30th 2010, 11:15am
Clean screen EGR gasket is a must do as its so cheap and it can save you a big headache down the road! :chevy:
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Van Model Year: 1985
Extra Info: 350 with 700r4
Postby astroturf » June 30th 2010, 1:00pm
All good posts Guys...
Can someone ID the location of mine?
It's an 05. Thanks, Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby Br0theralex » June 30th 2010, 5:42pm
if it aint broke - dont fix it :driving:
"@ 150,000 mi - I will not let this Astro Van Die "
Br0theralex
Years of Membership: Br0theralex has been a member for 10 full yearsBr0theralex has been a member for 10 full yearsBr0theralex has been a member for 10 full yearsBr0theralex has been a member for 10 full yearsBr0theralex has been a member for 10 full yearsBr0theralex has been a member for 10 full yearsBr0theralex has been a member for 10 full yearsBr0theralex has been a member for 10 full yearsBr0theralex has been a member for 10 full yearsBr0theralex has been a member for 10 full years
Topics: 7
Extra Info: 4.3L AWD
Postby astroturf » June 30th 2010, 8:19pm
Br0theralex wrote:if it aint broke - dont fix it :driving:
w0w alex, You nailed that one...
I'll have a look when I get home.
Thanks, Jim
astroturf
Topics: 112
Postby jeff's93astro » June 30th 2010, 9:26pm
Thats why they put it there :shhh:
jeff's93astro
Topics: 55
Images: 19
It is currently March 1st 2021, 5:56pm
Ken2.7
Date: Feb 24 '21
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Date: Feb 23 '21
Time: 8:41pm
Attached by: WinnieVan
WinnieVan
Date: Feb 23 '21
Time: 8:07am
Ken2.7
Date: Feb 22 '21
Time: 11:43pm
Users browsing this forum: MHMMHM is online! and 29 guests
