Unknown Port
Unknown Port
Postby LoriB [OP] » June 30th 2015, 8:03pm
Hi,
I’m a new member but I’ve been looking at this site for info since I got my 95 Safari. Thanks for all your posts, many have been very helpful to me so far.
I am in the process of replacing the vacuum hoses as suggested here. My AC doesn’t work and I did find the hose is bad. I was looking around the engine since I had the dog house off and I found a port that looks like a vacuum hose should be attached to it but I don’t find any disconnected hoses nearby. Can anyone tell me what this is and whether a vacuum line or anything should be connected to it?
As you may be able to tell it’s on the top of the engine right behind the distributer cap.
Thanks
95 Safari
LoriB
Years of Membership: LoriB has been a member for 5 full yearsLoriB has been a member for 5 full yearsLoriB has been a member for 5 full yearsLoriB has been a member for 5 full yearsLoriB has been a member for 5 full years
Extra Info: XTL
Re: Unknown Port
Postby Lumpy » June 30th 2015, 8:19pm
There's a port on a western bay
And it serves a hundred ships a day
Lonely sailors pass the time away
And talk about their homes.
Could that be the same one?
Re: Unknown Port
Postby CopperFiremistCopperFiremist is online! » June 30th 2015, 8:25pm
Some of those were blocked off from the factory
Pullin The Pass
Firing on 1 Cylinder (L2)
Topics: 24
Images: 6
Alias (AKA): B
Extra Info: LS Swap
Re: Unknown Port
Postby LoriB [OP] » June 30th 2015, 8:29pm
Could be one of them but I’m not sure. Thanks for the smile and quick reply anyway.
It wasn’t blocked off, of course that does not mean that the cap hasn’t been knocked off but I’m still very curious about it.
I do see the line connected in this post by svennand.
viewtopic.php?f=34&t=57313
Since I still have the AC issue I suspect they are related.
Edit:
I moved the vacuum hose to the unknown port and now have air blowing out of the dash vents :banana: Of course this means no vacuum line to the port under the distributor. Thoughts? I’ve been pouring over vacuum diagrams but I’m not really great at reading them apparently.
Thanks in advance for any advice.
95 Safari
LoriB
Extra Info: XTL
Re: Unknown Port
Postby Big_kid » July 2nd 2015, 4:22am
I wish I had a Looking Glass to see where all the lines are supposed to go but a lass, I do not.
Firing on 6 Cylinders (L7)
Topics: 185
Images: 331
Extra Info: 2WD 5.7 V8
Re: Unknown Port
Postby LoriB [OP] » July 2nd 2015, 5:51am
I've done a lot of searching on-line and the best that I can find is that the port I was wondering about is the vacuum port for the brake booster. The brakes seem ok, not great but they are working so maybe they are getting vacuum from elsewhere? I'm unable to find a brake booster vacuum line diagram but I will be able to spend some time with it tomorrow. Maybe I can find some info that will help someone else.
95 Safari
LoriB
Extra Info: XTL
Re: Unknown Port
Postby Lumpy » July 2nd 2015, 6:24am
Big_kid wrote:I wish I had a Looking Glass to see where all the lines are supposed to go but a lass, I do not.
Excellent! ... :rockon:
Re: Unknown Port
Postby sixsix » July 4th 2015, 10:41am
LoriB wrote:Hi, ... I found a port that looks like a vacuum hose should be attached to it but I don’t find any disconnected hoses nearby. Can anyone tell me what this is and whether a vacuum line or anything should be connected to it? As you may be able to tell it’s on the top of the engine right behind the distributer cap.Thanks
The Vacuum Line / Port you refer to looks like this one ( or these ? ):
585
When I was working on the Cruise Control Servo replacement, I found this Vacuum line setup and subsequent bad lines and fittings/connections.
It's from the build thread:
viewtopic.php?f=127&t=59385&p=695098&#p695098
354.2
Evaporative Canister Vacuum lines, also from the build thread:
viewtopic.php?f=127&t=59385&p=586618&#p586618
355.1
Vacuum Port / LH side of Intake Manifold / Upper Plenum. Evap. system.
Hope these help - Unfortunately, I still have an Evap. Problem - probably always will, till I get the "Correct" Canister in here. They are hard to come by - For the CPI Engine - and expensive when found.
And my cruise control still does not work - but vacuum system does not seem to be the problem. I bought new and replaced all but the "small/hard" and colored vacuum lines.
There are a few more photos - at the Vacuum Ball/Reservoir/T connections, etc.
Mike
Well, after all... what would Banacek say ?... “It is only a matter of time before armed citizens, waiting or not for the police, take things into their own hands, fire on the rioters for personal and property prot. & end up hunted like dogs.”
Firing on 2 Cylinders (L5)
Topics: 37
Images: 1272
Re: Unknown Port
Postby sixsix » July 4th 2015, 10:50am
My Goodness - you guys couldn't be more obscure, could ya' ?
"Looking Glass ...Lass..."
Geez.
Mike
Topics: 37
Images: 1272
Re: Unknown Port
Postby paulo57509 » July 4th 2015, 10:57am
Lumpy wrote:There's a port on a western bay
Excellent, Lumpy!
Damn! When I saw the post topic that was the first thing that came to mind as well.
paulo57509
Firing on 7 Cylinders (L1)
Years of Membership: paulo57509 has been a member for 10 full yearspaulo57509 has been a member for 10 full yearspaulo57509 has been a member for 10 full yearspaulo57509 has been a member for 10 full yearspaulo57509 has been a member for 10 full yearspaulo57509 has been a member for 10 full yearspaulo57509 has been a member for 10 full yearspaulo57509 has been a member for 10 full yearspaulo57509 has been a member for 10 full yearspaulo57509 has been a member for 10 full years
Topics: 24
Extra Info: RWD
Re: Unknown Port
Postby paulo57509 » July 4th 2015, 11:02am
LoriB wrote:Could be one of them but I’m not sure. Thanks for the smile and quick reply anyway.
Edit:
If you can't find what is supposed to be connected there, it wouldn't hurt to plug it off with a rubber cap.
With that vacuum leak connected or plugged, your MPG's should improve a little.
paulo57509
Topics: 24
Extra Info: RWD
Re: Unknown Port
Postby Big_kid » July 4th 2015, 9:21pm
So THAT'S where my carbon can is supposed to connect? It's been "faked" since before I got the van. Maybe my idle would smooth out some if I connect it. It's pretty choppy while it's warming up.
Obscure? LOL! We've not even approached obscure!
Topics: 185
Images: 331
Re: Unknown Port
Postby Lumpy » July 4th 2015, 9:27pm
Geez.
Cruel... but it will never show
Re: Unknown Port
Postby Astrofarian » July 4th 2015, 10:37pm
Brandy, anyone? Now where's that 8-track tape at?
-Mike-
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Re: Unknown Port
Postby Big_kid » July 5th 2015, 2:26am
My 8track (and working FM converter) are on the work bench waiting for me to get the buggy back together. Period correct sound system!
Topics: 185
Images: 331
Re: Unknown Port
Postby Lumpy » July 5th 2015, 3:18am
It's under my Chia pet.
Re: Unknown Port
Postby Coaster » July 5th 2015, 4:00am
the vacuum port in the first pic is to run the HVAC. if you dont have AC then this port is blocked from the factory. if you have AC then this port runs to the vacuum canister
I LIVE IN NORTH DAKOTA
Coaster
Topics: 113
Extra Info: 4.3 cargo 2wd
Re: Unknown Port
Postby Lumpy » July 5th 2015, 4:36am
Coaster! You Young Blood. I've been Searchin' for you. You been Down in Mexico?
Re: Unknown Port
Postby Coaster » July 5th 2015, 4:48am
stones throw from canadia my friend. our ND town is full of their smoke, and not the good kind either
Coaster
Topics: 113
Re: Unknown Port
Postby Lumpy » July 5th 2015, 7:24am
Coaster wrote:stones throw from canadia my friend. our ND town is full of their smoke, and not the good kind either
Maybe I was thinking of Charlie Brown. He's always Yackety Yack'in. Don't let that Smoke Get In Your Eyes. It's like Ink Spots.
It is currently September 28th 2020, 12:29pm
bradyalderin
Time: 11:43pm
Comments: 48
Date: Sep 25 '20
Time: 9:45pm
Isuzuguru
Date: Sep 21 '20
Time: 5:20am
Maddog
Comments: 32
Date: Sep 18 '20
Time: 11:15pm
Maddog
Comments: 32
Date: Sep 18 '20
Time: 10:47pm
