Ignition randomly cutting out; At wits end
Postby Ball [OP] » July 26th 2015, 12:01am
This is a long-standing issue with this van and I feel no closer to figuring it out than when it first cropped up years ago.
The symptom is the ignition will cut out randomly at which point doing a power cycle (assuming the engine is still turning) will usually get the ignition going again.
I have recently tried connecting the battery directly to the coil via a switch to eliminate any possible issue with wiring or the ignition switch. The van is still having issues.
The ignition module has been recently tested. Also, it can happen on a cold start so it's not due to overheating.
I have two CPUs (one firmware) so if its that, it somehow affects both of them.
HEEEEEEEELP!
Ball
Years of Membership: Ball has been a member for 10 full yearsBall has been a member for 10 full yearsBall has been a member for 10 full yearsBall has been a member for 10 full yearsBall has been a member for 10 full yearsBall has been a member for 10 full yearsBall has been a member for 10 full yearsBall has been a member for 10 full yearsBall has been a member for 10 full yearsBall has been a member for 10 full years
Topics: 5
Extra Info: vin W
  • Randomly losing advance
    by Coaster » February 25th 2021, 3:50pm in Engines
    Last post by Coaster View the latest post
    February 26th 2021, 1:57am
  • Ignition Open Circuit
    by OldSchoolNoe » January 2nd 2021, 6:31am in Engines
    Last post by OldSchoolNoe View the latest post
    January 4th 2021, 12:34am
    9
    83
    March 7th 2021, 2:02pm
Re: Ignition randomly cutting out; At wits end
Postby FrugalAstro » July 26th 2015, 12:30am
Ball wrote:The ignition module has been recently tested.
There is only ONE way to test an ignition module - swap the failing one for a known good one.
Auto parts store testers are a tool, not a guarantee that your possible failing part is good.
FrugalAstro
Years of Membership: FrugalAstro has been a member for 7 full yearsFrugalAstro has been a member for 7 full yearsFrugalAstro has been a member for 7 full yearsFrugalAstro has been a member for 7 full yearsFrugalAstro has been a member for 7 full yearsFrugalAstro has been a member for 7 full yearsFrugalAstro has been a member for 7 full years
Van Model Year: 1987
Postby chevymaherchevymaher is online! » July 26th 2015, 2:09am
I agree with the above. Testing isn't always the best. It may test good and be bad. It is intermittent like you said.
I been testing the silly coil in mine for years. It had a slight surging at steady cruise speed every once in a while. It got worse and popped in the exhaust.
I tested it OHM'ed it and it read fine. Hooked a spark plug and spark plug wire to it and it had a changing color to the spark. Got a new coil because I was just tired of screwing with it. Took a gamble. That was it.
So as previously mentioned only sure test with electrical. Is swap in a known good one.
Postby Lumpy » July 27th 2015, 12:49am
What is a "Power Cycle"?
I recommend working on cars from Wit's beginning, not end.
Postby Ball [OP] » August 2nd 2015, 10:39pm
I think, at long last, I identified and fixed the issue. We'll see on tomorrow's drive.
It appears my alternator was arcing at the terminal. It took hours to remove it (due to the arcing screwing up the threads). Had to rotate the alternator instead of the nut, which did wonders for my back which I threw a week ago. I then re-cut the threads with a die and made a custom nut to fix.
(Power cycle means to turn the power off then on. Used more in computing like power cycling a router)
Ball
Topics: 5
Extra Info: vin W
Postby Lumpy » August 3rd 2015, 12:30am
Zebras are fast becoming extinct around here.
... :bouncy:
Postby Ball [OP] » August 4th 2015, 7:15pm
DAMN IT! :banghead: :banghead: :banghead:
The problem persists!
Ball
Topics: 5
Extra Info: vin W
Postby Sailing_Faith » August 4th 2015, 8:00pm
Ball,
I am sorry you are having this problem... What a PITA!
Sounds like your troubleshooting is sound, I do agree with the others though. I am not a parts changer, but there is no way to test an ignition module for an intermittent fail
Ire like you are having.
Replace the ignition module as the next step.
Good luck!
Sailing_Faith
Images: 5
Alias (AKA): s/v Faith
Extra Info: SLT 4.3l RWD G80
Postby Ball [OP] » August 4th 2015, 11:46pm
So you want me to buy a 3rd ignition module, and if that fails buy a 4th, and 5th...
Ball
Topics: 5
Extra Info: vin W
Postby chevymaherchevymaher is online! » August 4th 2015, 11:52pm
You pretty much covered the spark section. Have you tried running the engine with a fuel pressure tester on it? Checked the injector plugs. There one more connector outside the plenum where it plugs into the wiring harness between the injector and the harness. Could be pressure or connection. Loss of gas causes misses also.
Postby Ball [OP] » August 4th 2015, 11:57pm
Why would the CD box lose signal from the ignition module if the fuel injector stopped working? Honest question
Ball
Topics: 5
Extra Info: vin W
Postby chevymaherchevymaher is online! » August 5th 2015, 12:00am
Ball wrote:Why would the CD box lose signal from the ignition module if the fuel injector stopped working? Honest question
It wouldn't. If it is all new you tell me why isn't it working. I just offering other options.
If your dead set on it being a spark issue. ECU going out, and power supply to everything are the only 2 things left.
Postby Lumpy » August 5th 2015, 12:12am
Again, I recommend getting to the other end of that "Wit's" continuum. Fighting with mechanical devices guarantees failure for one side or the other. Want to guess which side?
Postby Sailing_Faith » August 6th 2015, 7:25pm
Ball wrote:So you want me to buy a 3rd ignition module, and if that fails buy a 4th, and 5th...
You had not said that you had changed it. You said;
....The ignition module has been recently tested. Also, it can happen on a cold start so it's not due to overheating
Easier to help if we have the whole picture.
Best of luck,
Sailing_Faith
Images: 5
Postby Ball [OP] » August 6th 2015, 10:48pm
Yeah, sorry, it's been posted elsewhere and I'm getting them mixed up.
I have two coils plus a CD ignition. I have two CPUs, but only one firmware. I have two distributors. I have two ignition modules, both tested as good.
Ball
Topics: 5
Extra Info: vin W
Postby Ball [OP] » August 7th 2015, 5:30am
So I was in the middle of a long-winded reply when I think I just made a breakthrough.
I've been inspecting the wires for rat gnawings and moving them around with the engine running and managed to kill it! I've tried this before, but never found a way to kill the SOB.
I think I got a bad wire or arc going on. Cautiously optimistic...
Ball
Topics: 5
Extra Info: vin W
Postby Sailing_Faith » August 7th 2015, 6:00am
Hang in there! I can sympathize, I just had to run down this kind of problem in the midst of a road trip!
I hope that you found it!
Sailing_Faith
Images: 5
Postby Ball [OP] » August 7th 2015, 6:32am
Yeah, sounds like my life. I've replaced the water pump, fuel pump, toe link, and many other things on road trips. The worst one was blowing two side walls in a canyon in the mojave. $1,000 error of judgement there :D
I found one bad looking wire. I'm driving out. We'll see what happens (fingers crossed)
Ball
Topics: 5
Extra Info: vin W
Postby Ball [OP] » August 11th 2015, 8:01am
Egh, maybe a need a new van :banghead:
Ball
Topics: 5
Extra Info: vin W
Postby Sailing_Faith » August 11th 2015, 8:08am
Ball wrote:Egh, maybe a need a new van :banghead:
Ok, hang in there< !
What is it doing now? What have you had done?
Any codes? Can you record a short video on your phone of just how it is failing?
Sailing_Faith
Images: 5
It is currently March 7th 2021, 2:02pm
AppaTheAirBison
Time: 8:54pm
Attached by: MHM
MHM
Comments: 22
Date: Mar 02 '21
Time: 2:20pm
Attached by: MHM
MHM
Comments: 22
Date: Mar 01 '21
Time: 7:27pm
Ken2.7
Date: Feb 24 '21
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Users browsing this forum: Yandex [Bot] and 21 guests
