Throttle Body Spacer
Postby 8AD A5TR0 [OP] » September 2nd 2015, 5:39am
Hi everybody :)
Anyone have any experience with installing a throttle body spacer to their 4.3L Z engine? Some of the guys at work are telling me they're sometimes not worth putting on and recommended I check with others before installing one. Any tips? Please advise. Thanks!
Livin' The Dream®
livinthedream1.bandcamp.com
IDDQD™
1DDQD.bandcamp.com
8AD A5TR0
Years of Membership: 8AD A5TR0 has been a member for 5 full years8AD A5TR0 has been a member for 5 full years8AD A5TR0 has been a member for 5 full years8AD A5TR0 has been a member for 5 full years8AD A5TR0 has been a member for 5 full years
Images: 15
Van Model Year: 1991
Extra Info: LT 4.3L V6 EXT RWD
  • Bored throttle body
    by ghettocustoms128 » July 1st 2020, 5:41pm in Engines
    Last post by ghettocustoms128 View the latest post
    July 1st 2020, 6:55pm
  • 4.3 half throttle stalls
    by DAS2020 » October 27th 2020, 12:50am in Engines
    October 27th 2020, 3:23pm
    December 4th 2020, 12:04pm
Re: Throttle Body Spacer
Postby Sailing_Faith » September 2nd 2015, 6:55am
Love to hear the replies..... I suspect some will swear to 50+HP...
Sailing_Faith
Images: 5
Alias (AKA): s/v Faith
Extra Info: SLT 4.3l RWD G80
Postby 97cargocrawler » September 2nd 2015, 8:12am
I installed one years ago. I did the butterfly valve restrictor flap removal at the same time. The shiny aluminum alone added 50hp. My perception added another 50hp but I lost all those gains with 35" tires so my van still just put...put..puts along. Without the throttle spacer...who knows. It does help counteract the body lifted intake to air cleaner box height difference. That adds another 10hp.
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Postby chevymaher » September 2nd 2015, 9:21am
I ported my intake made it a single plane. Basically what the throttle spacers do.
I did it at the same time I ported the heads and exhaust, and a cam. So whatever gain was combined with other things.
Now i have that intake and exhaust on the merc. People think I am full of it. You got to line up next to me, or ride in it to make up your own mind. Once you see it in person you are a believer.
Postby Vandiction » September 2nd 2015, 1:18pm
Dyno proven: no gains.
'05 Astro, AWD| 6.0 LQ4 cam'd/rods/lifters/ Slowhawk tuning| FLT 4L65 Stage VI| Yank Pro Truck 2800| Silverado SS X-fer case| 5" lift body/keys| Ride Rite| Rancho 9000XL| 245/70/16 AT| A/R 23 wheels| The SS Astro GM never made.
Vandiction
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: Vandiction has been a member for 5 full yearsVandiction has been a member for 5 full yearsVandiction has been a member for 5 full yearsVandiction has been a member for 5 full yearsVandiction has been a member for 5 full years
Topics: 13
Images: 36
Postby chevymaher » September 2nd 2015, 1:42pm
Vandiction wrote:Dyno proven: no gains.
Don't know where your getting your information. But in independent test in the 25 runs I saw there was always a gain. Mainly in mid range torque with a small HP increase.
Results varied by type of engine and intake system. 5-20 lb torque gain with a equal HP gain. It also states everywhere this mod does better in connection with other mods. Exhaust and cam.
Cpi type had smallest gains. But dual plane systems like mine had definite larger gains. Mainly due to the single plane effect rocking the torque curve higher.
These test were done on everything 4 cylinder nissans to V-8 corvettes. Always the same results. In one report they did say it would remain relatively the same without other breathing improvements in other areas. But even in their test the car gained in both areas.
Postby markmitch » September 2nd 2015, 2:59pm
Chevymayher is right if you add a better muffler possibly a better breathing cat converter along with the spacer you will see more, simply put what comes in must go out. when I put my V8 in I installed a free flowing single 3 inch exhaust so later (after smog) I can improve breathing on the other end (intake) My suggestion would be a better Y pipe like the one shown-comes from Jegs Magnaflow 10768 - Magnaflow Tru-X, T, U, Y Crossover Pipes welded into the stock Y pipe I plan on this mod later myself.
Firing on 6 Cylinders (L6)
Topics: 615
Images: 20
Extra Info: RS V8
Postby 97cargocrawler » September 2nd 2015, 4:53pm
Like anything else, one simple mod usually does nothing notable. You either go all in and really modify and enhance the performance as a package deal, or just forget it. There is no single bolt on accessory that's gonna make your van move faster.
I modified everything but the block, including the computer.
97cargocrawler
Topics: 42
Postby Lumpy » September 2nd 2015, 5:55pm
97cargocrawler wrote:Like anything else, one simple mod usually does nothing notable. You either go all in and really modify and enhance the performance as a package deal, or just forget it. There is no single bolt on accessory that's gonna make your van move faster.
I took out the crappy Autolite plugs in my Honda and installed NGKs. Only saw about 15 HP increase. Then I added a bigger tail pipe stinger to get the exhaust gasses out and it really took the HP up. I estimate about 35 HP increase.
^^^ Above is an actual quote from a post in a Honda forum.
Postby Astrofarian » September 4th 2015, 6:18pm
His "bigger stinger" was only effective because he didn't notice the big horking potato his next-door neighbour pounded into the exhaust! I "hear" they can be extremely restrictive :whistle:
-Mike-
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Postby Lumpy » September 4th 2015, 9:48pm
-Mike-
They don't call them "Cantelope Shooters" for nothing.
It is currently December 4th 2020, 12:04pm
Attached by: icebrrg3rd
icebrrg3rd
Date: Dec 01 '20
Time: 12:16am
djpigs
Comments: 42
Date: Nov 26 '20
Time: 11:23pm
Date: Nov 26 '20
Time: 12:43am
Attached by: Slime
Slime
Date: Nov 24 '20
Time: 11:11pm
K-TRON
Comments: 23
Date: Nov 16 '20
Time: 1:07am
