oil cooler leak please help
Postby Astro Eddie [OP] » September 16th 2015, 5:12am
My 2001 astro is leaking from the oil cooler connection on the radiator both the top one and the bottom one. Now am not sure if I have to replace the fittings attached to the radiator or replace the lines. I would prefer to replace everything but money is a problem, so am trying to fix the issue spending as little as possible. Any advice is greatly appreciated and thanks in advance for the help.
I don't know if the fittings attached to the radiator are worn-out or the lines.
Astro Eddie
Years of Membership: Astro Eddie has been a member for 5 full yearsAstro Eddie has been a member for 5 full yearsAstro Eddie has been a member for 5 full yearsAstro Eddie has been a member for 5 full yearsAstro Eddie has been a member for 5 full years
Van Model Year: 2001
Extra Info: cargo
Re: oil cooler leak please help
Postby Astrofarian » September 16th 2015, 7:19am
If I recall correctly, the lines should have O-rings on the male ends that fit into the rad fittings. You should feel some resistance as the lines go in and they should spring back slightly after the retainer clips get slipped into place and locked. Take a look ; I'm sure someone will be along soon with less fuzzy info (it's been a few years since I worked on a Gen II).
-Mike-
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Postby Astro Eddie [OP] » September 16th 2015, 12:50pm
I will be running to advance auto parts and ask them about the o-ring I'll keep you posted thanks
Astro Eddie
Extra Info: cargo
Postby mdconvert » September 16th 2015, 1:08pm
I have a '99 that developed a leak in the line (one of the fittings). After reading too many stories of replaced lines not lasting too long, decided to remove the lines and fitting between the oil filter and engine. It's pretty tough to replace the complete line due to the path that it is run in; very cramped. Your problem may be easier to repair than mine was, so you'll have to decide for yourself, however your line may start leaking eventually as mine did.
It's been less than a year this way, but haven't found it to be a problem.
mdconvert
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: mdconvert has been a member for 12 full yearsmdconvert has been a member for 12 full yearsmdconvert has been a member for 12 full yearsmdconvert has been a member for 12 full yearsmdconvert has been a member for 12 full yearsmdconvert has been a member for 12 full yearsmdconvert has been a member for 12 full yearsmdconvert has been a member for 12 full yearsmdconvert has been a member for 12 full yearsmdconvert has been a member for 12 full yearsmdconvert has been a member for 12 full yearsmdconvert has been a member for 12 full years
Topics: 9
Postby RECox286 » September 16th 2015, 5:44pm
Get ready to replace the O rings and the clips that hold the fittings together. No, changing the flex lines isn't difficult,
but can be somewhat tricky. Usually the flex lines develop leaks before the O rings go out to lunch. Big question:
Has any type of oil additive or any non oil frendly chemical, such as a stop leak, been added to the soup ?
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby Astro Eddie [OP] » September 16th 2015, 5:55pm
Yes I did put an engine stop leak product I don't remember which.
I just drain all the oil and since I couldn't find the o-rings for the connectors I bought both oil cooler line connectors at Napa for $13.46 total am on my way home to replace them I'll keep you guys posted thanks
Astro Eddie
Extra Info: cargo
Postby Lumpy » September 16th 2015, 5:55pm
Astro Eddie wrote:I will be running to advance auto parts and ask them about the o-ring I'll keep you posted thanks
Pull one of the O rings on yours, plus the little clip thing. Take both to LAPS. You can probably find a kit of O rings of all sizes for a few bucks and that's usually more cost effective than buying two singles. They'll have the clips in the Dorman HELP! section.
Start by simply replacing those, cost maybe 5 bucks. That may resolve the entire problem. If not, it's only five bucks.
Postby Astrofarian » September 16th 2015, 6:17pm
As usual, Lumpy's right. Although it sounds like you've already bought the parts, Lumpy's suggestion is the best and cheapest potential solution.
Sorry to "Hijack" your thread here but I have a question.....do the Gen I vans have the same oil-cooler setup as the Gen II arrangement? I've had 4 Gen I vans and none of them had any kind of oil-cooler in them.
-Mike-
Astrofarian
Alias (AKA): M!ke
Postby Lumpy » September 16th 2015, 6:22pm
My 89 does not have an OEM oil cooler.
Postby Leeann_93 » September 16th 2015, 10:45pm
My '93 does have an oil cooler.
Postby smokinjoe » September 17th 2015, 2:30pm
95 has an oil cooler but different connections. Much worse connections at that. Still O ring but threaded instead of pop collars. They are really difficult to do right.
smokinjoe
Firing on 5 Cylinders (L2)
Topics: 268
Alias (AKA): smokinjoe
Van Model Year: 2002
Extra Info: RWD
It is currently December 1st 2020, 3:27pm
Attached by: icebrrg3rd
icebrrg3rd
Date: Today
Time: 12:16am
djpigs
Comments: 42
Date: Nov 26 '20
Time: 11:23pm
Date: Nov 26 '20
Time: 12:43am
Attached by: Slime
Slime
Date: Nov 24 '20
Time: 11:11pm
K-TRON
Comments: 23
Date: Nov 16 '20
Time: 1:07am
