I bought a 95 Astro in March with 218k and possibly a bit of a shady history (salvage title). Ran well all summer while I was building out the interior; replaced fuel pump and starter during that time too.
I hit the road three weeks ago, all was well for the first 1k miles or so. Then I started noticing a tranny fluid leak, which got worse to the point that I had to add a quart a day until I could limp it to a friends house. For the last couple days I started noticing a coolant leak as well.
When I got back to civilization I got the van checked out, the diagnosis was a couple bad freeze plugs as well as a leaking tranny fluid filter (not stock, apparently rigged up by the p.o.) and a leaky oil cooler line.
I got a quote of at least $500 to replace the freeze plugs, and of course a speech about how this might only be the tip of the iceberg.
I'm wondering how much permanent damage was done during my efforts to drive the van vs. having it towed. Probably 400 miles since I noticed the coolant leak and closer to 1k since I noticed the tranny fluid leaking.
All told I'm no more than $3500 into this van, and am having serious doubts as to whether I should go through with this.
Thoughts?
