No start - Odd Problem
Postby rugman [OP] » December 13th 2015, 12:06am
My 04 cargo van won't start - originally had this issue - viewtopic.php?f=43&t=85529
Changed the fuel filter and has been fine. It sat for a while and won't start now. Has fuel - has spark. Fuel pressure 50PSI - spark looks strong. Tried starter fluid to see if would try - nothing. Had a buddy bring over his code reader (its a pro one as he works in a shop) nothing out of the ordinary. Even he is stumped?
rugman
Years of Membership: rugman has been a member for 11 full yearsrugman has been a member for 11 full yearsrugman has been a member for 11 full yearsrugman has been a member for 11 full yearsrugman has been a member for 11 full yearsrugman has been a member for 11 full yearsrugman has been a member for 11 full yearsrugman has been a member for 11 full yearsrugman has been a member for 11 full yearsrugman has been a member for 11 full yearsrugman has been a member for 11 full years
Topics: 12
Alias (AKA): rugman
Extra Info: Cargo Van
  • Hard Cold Start and Rough Idle. No Codes. Diagnosis?
    by AstroTan » October 17th 2020, 5:26am in Engines
    Last post by AstroTan View the latest post
    December 31st 2020, 5:53pm
  • No Start on my '91
    by Sidewinder91 » December 4th 2020, 4:43am in Engines
    December 4th 2020, 1:23pm
    92
    April 17th 2021, 3:19am
Re: No start - Odd Problem
Postby chevymaherchevymaher is online! » December 13th 2015, 12:18am
Pull the plugs and look at them. See if they are fouled, have a ceramic coating on them. Misfiring down in the bottom instead of in the gap. Contaminated by coolant. Flooding during start up will foul the snot out of them and a coating builds on the plug.
Clean and regap see if it fires up.
Take the plenum cover off look for gas puddles. Check the injector connections. Even if it has pressure it wont run if the injector isn't getting a good signal.
Topics: 91
Postby AstroWill » December 13th 2015, 12:33am
If it won't start with starting fluid, it's most likely an ignition problem. Do you get any arching? Spray the spark plug wires with water while letting the engine run at night/in the dark. How do the plugs look?
Is that 50psi key on engine off?
Topics: 109
Images: 473
Postby rugman [OP] » December 13th 2015, 12:50am
50 PSI is when cranking.
Can't check for arcing wires as it won't run. Ran pretty good up until this. It is due for a tune up but I would imagine it would started running crappy before this happened?
rugman
Topics: 12
Alias (AKA): rugman
Postby rugman [OP] » December 13th 2015, 12:52am
chevymaher wrote:Pull the plugs and look at them. See if they are fouled, have a ceramic coating on them. Misfiring down in the bottom instead of in the gap. Contaminated by coolant. Flooding during start up will foul the snot out of them and a coating builds on the plug.
Planning on checking the plugs next. Even if it had bad inj connections wouldn't the starting fluid at least make it try and start?
rugman
Topics: 12
Alias (AKA): rugman
Postby chevymaherchevymaher is online! » December 13th 2015, 12:57am
Not necessarily if the plugs are fouled.
Topics: 91
Postby rugman [OP] » December 13th 2015, 2:33pm
My buddy also mentioned that they have had issues with the chip in the key causing a similar problem. Although - I am pretty sure when I went to get a spare made the guy checked it and said " good - no chip". Wasn't really paying attention though.
rugman
Topics: 12
Alias (AKA): rugman
Postby rugman [OP] » December 14th 2015, 6:43pm
Got a plug out - here is a picture - look sold but OK? not wet at all - I have spark at the plug
rugman
Topics: 12
Alias (AKA): rugman
Postby chevymaherchevymaher is online! » December 14th 2015, 10:14pm
Looks pretty old and nasty to me. What is the gap, bet it has eroded and is bigger than it should be. It has a ceramic layer on it. Bet if you sand the outer electrode it take quite a while to get to shiney metal.
I would toss a new set in gapped and see if it fires up.
Topics: 91
Postby rugman [OP] » December 15th 2015, 2:23am
Yep - new plugs going in and new wires etc - gotta be the worst job ever! At least the left side is. About 3/4 of the way done - had to quit to grab the kiddies. Should be done by tomorrow!
rugman
Topics: 12
Alias (AKA): rugman
Postby Leeann_93 » December 15th 2015, 2:58am
That plug has been toast for a while.
Postby AstroWill » December 15th 2015, 2:58am
rugman wrote:gotta be the worst job ever!
Haven't had to do the engine mounts yet have you?
Topics: 109
Images: 473
Postby rugman [OP] » December 15th 2015, 12:38pm
Don't even want to think about it!
rugman
Topics: 12
Alias (AKA): rugman
Postby AstroWill » December 15th 2015, 5:58pm
Agreed :)
Topics: 109
Images: 473
Postby rugman [OP] » December 15th 2015, 6:36pm
All is good! Running like a champ again - even found a broken vac hose and now my heat works on all settings! Found this sitting on top of my rotor when I took the cap off. Thanks for all the help!!!!
rugman
Topics: 12
Alias (AKA): rugman
Postby AstroWill » December 15th 2015, 6:38pm
rugman wrote:All is good! Running like a champ again - even found a broken vac hose and now my heat works on all settings! Found this sitting on top of my rotor when I took the cap off. Thanks for all the help!!!!
AWESOME! Glad you got it fixed.
Topics: 109
Images: 473
Postby Leeann_93 » December 16th 2015, 2:35am
Hey, two for one!
Nice ;)
It is currently April 17th 2021, 3:19am
Comments: 9
Time: 6:08pm
kvargas1356
Date: Apr 11 '21
Time: 10:20pm
Attached by: jfunkngroove
Comments: 17
Date: Apr 10 '21
Time: 10:38pm
Date: Apr 08 '21
Time: 8:52pm
Comments: 17
Date: Apr 08 '21
Time: 1:55am
Users browsing this forum: Bin_DubaiBin_Dubai is online! and 26 guests
